I'm going to NH Dragway with my SV650 and I wanted some advice on doing a burnout. I've read the best way to do a stationary burnout is to put it in first gear, grab the front brake, put weight over the front forks, rev it up to about 6k and pop the clutch. Then to stop ease the clutch lever in while rolling off the throttle.
Is that about right?
I don't want to be a "that guy".
Also as far as the best launch technique, Normally I'd rev to between 3-4k and then ease out the clutch as fast as possible while keeping the front wheel down... is that about right?
thanks,
atek3
