Results 1 to 19 of 19
can't pick up my own bike
    Oct 2003
    nh
    Brings up a question...how does a girl get her bike back up w/o help? I dropped my bike when I was by myself(stopped in soft sand/gravel drive, foot slid and over it went) I was lucky that it was near enuf to a road and someone saw my predicament. Stopped and helped me. I tried but no way could I have done it w/o help. But I ride by myself most of the time. The guys at the race track said there was a trick. What would that be? Bet it sounds easier than it is, that bike is heavy!
    Still grinnin!
    High maintenance priss
    Central MA
    The only 'trick' i know of is this: get in a low squat position with your lower back against the top of the tank (top of tank because the bike is over). Grab the bars with one hand and something strong on the other side of the bike (seat, grab bar if possible, rear subframe). Once you've got a good grip, push up with your legs. You will get more leverage this way than if you had your stomach against the tank while trying to lift it. Just be really careful as you get close to upright...you don't want to lift it so fast or uncontrolled that the bike falls over to the other side.
    crash squid elaineo's Avatar
    Oct 2003
    in my opinion, the "squat" method doesn't work on sport bikes, because sport bikes have a high center of mass and when they fall down, they lay down flat so it's really difficult to get your hips under the tank.
    i practiced droppping and picking up my bike a lot when i got it, and could never lift it using the squat method.
    after much thought and analysis, i figured out my own method that works for me (and would probably work well for most sportbikes):
    squat, facing the bike, near the handlebars/tank. grab the lower grip with your left hand, and the upper grip with your right hand. wedge your left elbow between your rib cage and your hip bone. Then, lift with your knees! Once you get the bike off the ground a few inches. wedge both knees under the tank/fairing. Then, PUSH! make sure you're grabbing the front brakes, and the bike should go up.
    i practiced this on a flat, concrete surface and used every ounce of power inside of me to get the bike up. Not sure if i could do it on a gravel surface or whatever. definitely practice though, because it took me several attempts using several different methods before i found what worked for my bike. tape up your fairings and remove your mirror/turn signal first, too
    i am less than 100 pounds and have the muscle strength of a fly... if i can pick up a 370-lb bike all by myself, ANYONE CAN!
    I Dance With Will
    Oct 2002
    unknown
    let me get this straight. sport bikes have high center of mass compare to what goldwing? any other confirmation?
    "fuckit!"
    Waterbury, VT
    In addition to locking the front brake, don't bother trying to keep the handlebars straight. Let the steering rest against its stop so you can focus all of the energy into lifting the bike.
    SSearchVT
    Oct 2003
    nh
    Thanks for the input. I have a ZX6E and it weighs almost 500 lbs.(I had just filled the tank) and I weigh about 135 so... I'm no light weight (for a girl) but! Also when I dropped it it was nearer to the edge of the drive and was laying downhill just a bit. It had rained and the surface had gotten soft which made it harder as it slid when I tried to stand it up. My back is still feeling it. But yeah I need to lay the bike down and practice standin it up. I'll have to invite somebody over for an xtra set of hands in case I can't.
    Hey Elaine, glad to hear you're ok!
    Still grinnin!
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    my big ninja was a bear once
    fell on a hill what i did was pushed it up 600 lbs (tires up hill) waterbury
    i was avoiding the copps so i think that helped me
    still sore back next day
    www.bostonmoto.com
    Forum Rules
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Re: my big ninja was a bear once
    lol..nice
    I would say try not to pull onthe subframe as much as possible...IMO they aren't that sturdy.
    I usually don't have a problem picking a bike up...I'll just yank on the bars until the bike is high enough to get my knee under..stable the bike..re-grip and stand it up all they way... eat your wheaties?..lol j/k
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    Re: Re: my big ninja was a bear once
    I thought about this and figured leaning way back while pulling on the bars should give you the most leverage to at least tip it up? -Suf Daddy
    Suf Daddy.
    squidtastic cyberxen's Avatar
    Oct 2001
    Massachusetts
    Hmmmm, you live near the Kangie, don't you ?.......
    No, Donny, these men are nihilists. There's nothing to be afraid of.
    - Mike
    CBR 1000 RR
    CBR 600 F4
    Apr 2004
    Cambridge
    suddenly being a big fat guy is good.
    I dropped my bike a few times, not moving, and catching it so it did not hit full force, never scratched it or anything, but i will tell you being 6 foot 1 and 230 pounds makes getting it up pretty easy....my brother is even bigger, 340 pounds and he must be able to pick it up like a bicycle.
    Arguing on the internet is like winning a gold medal in the special olympics......whether you win or lose you are still retarded!
    May 2002
    Meriden CT
    Re: Re: Re: my big ninja was a bear once
    sorry i should a said back 2 the bike
    pushed it not pulled
    www.bostonmoto.com
    Forum Rules
    watched an AMA Superbike race today on On Demand... a Yamaha rider picked his bike up & when he got it upright he was at the front of the bike facing the rear w/ his hands on the bars. Didn't look like he had too much trouble gettin her up... almost like he had alot of practice
    oh, & he was in 2nd place before the red flag came out for another rider... ended up in 5th after the re-start & that's when he went down.... Tommy Hayden happened to lead every... single... lap... of that race all the way to the win
    Lifer greenmonster's Avatar
    Aug 2003
    Run into the nearest bar and yell "free beers for those who help me get my bike up off the ground!" You'll be amazed at how quick and effortless it is to get that bike back up!!
    Posting Freak
    Aug 2003
    Coudersport, PA
    I wish I could remember how I hefted my bike up...but I did it. Rock and JJ were coming to help me and I just lifted it off the ground. I definatly did it with adrenilen though because I was in the middle of the road and wanted to get out of the way quick!!
    Mine is only a 500, but I'm not a big person either....
    Getting back into the game! Looking for my next bike!
    Senior Member JJ's Avatar
    Aug 2002
    Ashland NH
    You was like HULK picking that bike up over your head. Best thing I can say is try to get your thigh/leg/quad (whatever you want to call it) under the tank after you lift it a little and use your legs as much as you can to push it upright.
    That thing got a KAWI in it?????? SWEEEEEET!!!!!!!
    1997 ZX7R LATER JJ
    Oct 2003
    nh
    Thanks for the input, now I just need a little practice. Though just thinking about laying it down even on purpose makes my back hurt! I do like the fix that greenmonster suggested, sounds good to me!
    "Run into the nearest bar and yell "free beers for those who help me get my bike up off the ground!" You'll be amazed at how quick and effortless it is to get that bike back up!! "
    Still grinnin!
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    or just call the nearest ape.
    i know of a few, gimme a call next time!
    Oct 2003
    nh
    Be careful, I might just take you up on that!
    Then you'd have to ride all the way up here.....
    Still grinnin!
  1. Need Help! with a bike pick up!
    By Vawn in forum General Bike Related
    Last Post: 05-11-09, 02:55 PM
  2. Pick DBs next bike!
    Last Post: 09-01-08, 11:01 AM
  3. Can someone help me pick up a bike?
    By hqp921 in forum General Bike Related
    Last Post: 01-07-08, 06:24 PM
  4. Help me pick my first bike
    Last Post: 08-17-06, 08:43 PM
  5. Help me pick out my next bike!!!
    By PatSV650 in forum General Bike Related
    Last Post: 07-08-05, 08:17 AM
