Re: Car tires on motorbikes
Quote:
Originally Posted by
Tekime
Would almost definitely go the stud route as it would be mostly street if I did attempt this. Nowhere to ride out of my backyard. Had a set of ice tires but I gave them to a Canadian because he was a really nice fella.
Had no idea how much studs cost - explains the high price tag, but could be worth it..
It depends on who you know, and what you want to do.
If you're just going to hoon around, get some 5200 and screws and run them in at least a week before you intend to ride them so they can cure. Use short screws that won't penetrate the carcass, and once that stuff cures, I can assure you, you won't spit a screw without spitting the whole knob too. Certain races require certain studs, and not screws, but I'm not reading that's your intent.
Well.. I know a lot of people who don't care about motorcycles. But some of them have fancy tools.
So do you think that would be overkill for the street?
Nothing crazy and definitely no plans to race.
We're taking about inserting bits of metal into your tires so you can have 2 wheeled fun in the dead of winter. That is overkill defined.
Just stopping in to say that 5200 is indeed, tits.
capitalcrew
as long as you have acetone to clean up with afterwards. Otherwise it's a NIGHTMARE.
3M marine adhesive sealant 5200? Only asking for a friend...
carsick
yes. Its the strongest silicone known to man. You need a grinder to get rid of the stuff.
Edit: seriously, DO NOT USE IT ON ANYTHING THAT EVER NEEDS TO BE TAKEN APART EVER AGAIN.
This includes putting a transducer on the bottom of your boat. Don't do it.
Good to know.. screws or not I need a tube of this in my cabinet
I followed Randyo around VT on some curvy roads at good speeds
With the flexible side wall of a radial I think the contact patch was actually larger than most MC tires
If I had the opportunity to do ALASKA (I'm not) I would go darkside and do all the roads on 1 setr of tires
Chippertheripper
Can also confirm this. It is PERMANENT. Period. If you get this on your clothes say goodbye, anything you stick with it is STUCK. The working time is pretty long so you've got time to do what you have to, but once it is set, it's there forever. It's very common in jetskis for obvious reasons.
capitalcrew
sounds like eel slime
Does it dry hard like glue or flexible like silicone?
Anybody tried it on ABS
It dries fairly flexible but harder than silicone. It's wicked frustrating to try to remove something stuck with it because you can see it move but it just doesn't let go lol.
I've only ever used it on fiberglass and metal fittings in fiberglass.
