I rode my bike in to work today, which represents the longest ride I've done on it to date. Overall, I absolutely *love* the bike - comfy and powerful, put together in a nifty package.
It has a rather frightening problem, which I need to figure out soon. When I roll on the throttle, it makes a horrible noise just as it is coming into the power band - it sounds like a steel pail full of bolts being rattled around. I cant find anything vibrating on the chassis, and I intend to disassemble the fairings tonight to look for a battery bolt that had vanished when I picked the bike up, but I just cant imagine where the noise is coming from. I checked the chain when I got to work, and the tension seems to be about perfect.
The noise is not present at less than half throttle, and is not present at all when revved standing still. The only thing that leaves (gulp) is a soon-to-fail-transmission.
Anyone have any encouraging words?
dude thats just the way those things sound! Get over it!
Brent LRRS #772
2006 KTM 560 SMR
I once found a 10mm socket in my front sprocket cover. Made a god awful noise for sure.
Is this a used bike? Are you missing teeth on your sprocket?
Did it *always* make the sound, or did it come and go? Maybe that damn bolt is hiding in my front sprocket cover.....Originally posted by Honclfibr
Very used - 38k miles.Originally posted by hessogood
But the chain and sprockets are new.![]()
Timing chain rattle or valve clatter??? My CBR made a horrible noise at about 5000 rpm until I changed the timing chain tensioner. Good luck...
SSearchVT
I remember that story some idiot left it in there when they were working on it. Whatever happened to THAT guy.Originally posted by Honclfibr
I once found a 10mm socket in my front sprocket cover. Made a god awful noise for sure.![]()
Tlak to the PO and see what tune they are running. Also, very unlikely, but what are you using in it for fuel. Could be detonation.
Cheers, Lee S.
I know i'm slow, you don't have to rub it in.
Why, Yes! I do think you're a Wanker!
Actually, that is what I was thinking. On Friday, it seemed to go away for a while, then return.Originally posted by lee955i
Cheers, Lee S.
If that doesn't cure it, I'm thinking I will install a new cam chain tensioner when I do the valves.![]()
I would go with either the chain jumping because of worn or no teeth on the sprocket or the cam chain being loose and whacking the cases.
