Results 1 to 7 of 7
Crank -> Wheel HP losses?
    Oct 2001
    Bedford, MA
    Question Crank -> Wheel HP losses?
    Why is it that people say all bikes lose 10-15% of the power going from the engine -> rear wheel?
    Why is it a percentage..
    My question is this...
    If an SV650/EX-500/whatver has a six speed transmission, and a chain drive...
    And a Gixxer 1000 has a six speed transmission and chain drive...
    What is it that causes the Gixxer to lose a greater amount of horsepower going from the engine to the wheel? The transmission and chain are going to work similarly and have about the same amount of friction and inertia right? Where are the extra losses coming from?
    E.x. if the smaller bike loses 10hp, what makes the bigger bike lose 20hp. Why wouldn't they both lose 10hp?
    (Note I'm not comparing a chain drive bike to a shaft drive bike, or a car)
    So why do we say, "Bikes lose 10-15% of the power, rather than, all chain drive bikes lose 10hp" ??
    Ben?
    Member Zero's Avatar
    Nov 2002
    Attleboro, MA
    Probably because the more power you put through it, the more friction you are going to generate. If you think in extremes cases say a bike has 10HP, then how can it lose 10HP. I know there will be better explanations, but the percentage makes sense to me. Just like when a speedometer is off by 10%.
    Oct 2001
    Bedford, MA
    I was told by someone else it has to do with the horsepower being made at a higher RPM as well.
    Should have thought of that.
    Ben
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    its drag all drag
    ben
    Senior Member JJ's Avatar
    Aug 2002
    Ashland NH
    Drivetrain robs hp. The more hp you make, the more % you will lose.
    It's the same as cars/trucks/bikes/snowmobiles/etc... The more power you make it puts more strain on chain (stretching)/clutch (more of a chance to slip) and all out wear and tear.
    Not a real scientific answer but it should get the job done.
    Edit
    You make more power at higher rpm's so back to the more power creates more strain and slippage=more of a loss in hp.
    That thing got a KAWI in it?????? SWEEEEEET!!!!!!!
    1997 ZX7R LATER JJ
    I am not familiar with calculating drive train losses, but I am familiar with fluid dynamics in calculating dymanic heads for shit system pumps, in theory, the principle is the same, so the more faster you go, the more friction loss, all the way from the rolling friction of the tire on the pavement to the gearbox losses
    Senior Member jsven007's Avatar
    CA
    Very good question, interesting article:
    http://www.superstang.com/horsepower.htm
    14" Biceps. So what if I am weak...
  1. For Sale - Parts & Tools | Tools: Tusk Crank Puller, Motion Pro Spanners/Ringer/Fork Drivers
    By Tekime in forum For Sale
    Last Post: 10-31-20, 11:15 AM
  2. Wanted - Parts & Tools | Sv1000 front wheel, ideally silver. Or a GSXR wheel that interchanges
    By juha_teuvonnen in forum Wanted
    Last Post: 05-20-18, 10:03 AM
  3. Recommend a shop that can split cases/rebuild crank?
    By nick5446 in forum Bike Maintenance
    Last Post: 02-26-16, 03:38 PM
  4. Crank or RW HP?
    By ShredHed in forum General Bike Related
    Last Post: 11-19-02, 03:48 PM
