Results 1 to 14 of 14
Dead Battery or ???
    May 2011
    Northern MA
    Dead Battery or ???
    Bike started fine all day, seven sessions at the track. Drove home, tried to start it: starter motor turns over slowly (battery voltage 12.5V or so) and continues to turn over after releasing the starter button (it stops when the key is turned off).
    Trickle charger now has the voltage at 13.1V. Starter motor turns quicker, but still keeps going after releasing starter button.
    Ducati 749. Just starter looking over for loose connections. Lets hear your ideas.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Dead Battery or ???
    I know nothing about a 749. I'd be looking into stater relays or solenoids.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Sticky starter button too.
    its in my blood
    Jan 2012
    Doesn't sound like a battery.. sounds like a bad starter and or solenoid
    Mar 2012
    Chichester, NH
    Sticky starter button... Possibly. Good call.
    Starter... Maybe. Lower on my list of things to check, but possible.
    May 2011
    Northern MA
    Thanks guys. I was hoping battery (something simple). I'm leaving in the morning for another track, I'll use the street bike.
    The starter button isn't sticking.
    Mar 2012
    Chichester, NH
    Starter button could stick internally, without sticking externally. I had this happen with my fog lights on the GL.
    Just something to look for.
    A way to check the starter button is to take it apart and jump it with a homemade pin connector and see if it keeps cranking after you pull the pin out.....To bench test the solenoid if it is internal in the starter would be to connect the starter to jumper cables and touch the solenoid connection via a wire to the positive side of the battery. After you pull the wire off it should stop spinning. If this bike only has one wire to the starter then it has a external relay/solenoid.
    It is tough describing electrical things. Putting thoughts into words while keeping it simple is very hard. Too bad we can't draw pictures.
    One thing to remember is with a sticky button after the engine starts the starter would still be spinning. Just like not letting go of the button. It would be making a awful noise.
    Lifer SwiftTone's Avatar
    Norwood, MA
    Might be different but On my 2006 Monster when the start button is pushed and released, the starter will keep turning until the engine fires up. Maybe you've always held down the button until the engine fires up so you've never noticed this. If that's the case I'd check the fuel pump starting with the fuse and working your way up the electrical system.
    Correct, the button just starts the starter, the ECU controls the cutoff.
    May 2011
    Northern MA
    Strange, the bike started fine this morning. Loaded on the trailer for an eight hour ride, starts up fine after the ride.
    Loose connection?
    its in my blood
    Jan 2012
    Slow cranking is a sign of resistance or weak battery... If the battery is ok then I would say a bad starter motor or relay.. a loose connection is possible but unlikely... Typically a loose connection would give you a no start condition intermittently
    Lifer Stromper's Avatar
    Eastern Ct
    I have to be that guy, check the gas?
    The calculus of hate
  1. Dead battery troubleshooting.
    By backinthesaddle in forum Bike Maintenance
    Last Post: 09-03-12, 10:16 AM
  2. Looks like dead battery...but its not...
    By Romeo in forum Bike Maintenance
    Last Post: 05-29-11, 03:44 PM
  3. Dead Battery?
    By Mike02048 in forum General Bike Related
    Last Post: 03-20-11, 08:57 PM
  4. Dead battery
    Last Post: 03-07-11, 08:21 PM
  5. dead friggin' battery
    By Awesome in forum Bike Maintenance
    Last Post: 10-31-04, 09:26 PM
