Results 1 to 23 of 23
Ducati rear wheel socket
    Branford CT
    So I have decided to invest in one of these for my Multistrada 1200. My question to those who have one, what brand do you own? I am hesitant to get the aluminum ones. Was thinking of the speedymoto one because it claims its impact safe. Anyway, what do you have?
    #277
    Arlington MA 02474
    Re: Ducati rear wheel socket
    For my Hyper 796, I ordered a socket from ToolTopia.com
    3/4" drive 6-point impact socket, plus a 1/2" adapter.
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    Speedy moto. Quality used it on both my big hub ducats
    Mine is from Heartland Products and is aluminum. Seems pretty good so far, though I've only used it once.
    Branford CT
    Found a few 55mm 12 pt sockets online for $20.... hesitant to pull the trigger
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    I ended up getting the one from motomfg.com. Was on the pricey side but seemed like the best I could find. Came in two days without any issues... they're based out of NY.
    Branford CT
    I had one of their aluminum ones for my 848, it was garbage. Glad they offer a steel version now.
    Oct 2007
    Peabody Ma
    You also need a Torque wrench that rips out 170 ft lbs.
    Canterbury, NH
    Yea that's the exact reason I chose that one over cheaper options. Thought it was kinda slick having both sockets in one as well.
    Branford CT
    Adding new torque wrench to my list of item's.
    $40 is not bad for the steel version. The speedymoto one is 70
    Lifer NPDCPA's Avatar
    Mar 2011
    I had/have a steel Speedymoto for the tool box and an aluminum one I keep in my pack in case I get stuck somewhere. I expect a Japanese bike to have tires in stock, but not Ducati rear wheels sockets.
    Branford CT
    That's probably what I will do too
    Hypertarded
    RI / CT border
    Was going to recommend the TPO parts one I have, unfortunately it appears they have gone out of business
    Branford CT
    xxaarraa
    Guest
    You are better off with this one:
    http://www.northerntool.com/shop/too...9444_200639444
    Impact-wrench ready (you do have an impact right? makes taking off the SSA nut a lot easier). And 6 point is safer for high torque nuts like that.
    Canterbury, NH
    Can you even use a 6 point on a 12 point nut? I thought you could only go the other way around.
    Branford CT
    I do, I have a ryobi one. Did not know about the 6 point. Will it work on a 12?
    I might just order the mfgmoto one.
    xxaarraa
    Guest
    Oh I didn't know the nut was a 12 pointer. I thought the stock axle nut was a 6 point nut? Maybe that's only for the 848..
    I do not know if a 6 point socket will work on a 12 point nut - someone else would have to weigh in on that one.
    Branford CT
    Yeah in true Ducati form, it's different than a small hub Ducati.
    My '08 Hyper has a 6-point on the rear axle.
    Lifer ZX-12R's Avatar
    Candia, NH
    A 6 point socket will not drive a 12 point bolt. A 12 point bolt will have a vertex in the middle of every flat side of a 6 point socket. To fit the 6 point, you would have to go up in size so the flat areas will span the gap between 2 of the vertices. If you can even find a socket in a fractional size that would be adequate, the contact area will be small enough to make applying any appreciable torque a near impossibility.
    6 points sockets are for 6 point bolts. 12 point sockets will drive 12, 6, and 4 point bolts.
    Canterbury, NH
    That was my understanding. That said... I own exactly one overly priced 55mm 12 point socket.
    Branford CT
    Went with the motomfg tool. Good quality.
  1. Offset of ducati 748/916/996/998 rear wheel??
    By soofle616 in forum Bike Maintenance
    Last Post: 09-24-14, 09:37 AM
  2. For Sale - Parts & Tools | Ducati 848 rear wheel $300
    By jbmass in forum For Sale
    Last Post: 04-05-14, 06:12 AM
  3. Ducati 1098 MARCHESINI ALUMINUM REAR WHEEL
    By DZircher in forum For Sale
    Last Post: 10-13-13, 08:35 AM
  4. 94-98 Ducati m900 rear wheel
    By customfighterer in forum Wanted
    Last Post: 07-11-10, 10:54 AM
  5. Ducati 4.5" rear wheel
    By Paul_E_D in forum For Sale
    Last Post: 09-15-08, 04:39 PM
