I don't understand what the bennifit would be , please tell me ?
As for diff part #'s on pistons in mototor, has to do with valve relief and the direction they are installed, aslo in some cases in diesel engines, the diameter of one piston is slightly smaller due to more heat and expansion.
Counter wieghting wouldn't be the biggest issue, you can always add wieghbt rather then subtract. Although you usally want Light rotating mass.
2 stage air compressors use 2 diff sizzed cylinders/pistons on the same crank. Jfyi
All of the mechanical issues can be thought out.
Here is one big issue, if you have 2 drastically diff sized cyclinders, and you adjust compression, one size is makeing more power than the other, at one point in the rpm range you might get them to meet and play happy. But one will always be fighting the other , one wants to speed up and the other slow down. Vibration will tear up the bearings or crack the rods or crank. Not saying it won't run, just not for long.
V8 air compressor that you pull behind a truck to supply air to jackhammers , they use 6 cyl to make power and 2 to compress air, and run at a relativly low rpm. Just something to think about.
As for boreing out cyclinders on multi-cylinder engines, small changes don't affect the performance very much. The bigger the displacemet the less effect, smaller = bigger effect . Machine shops do this to cut corners, speed shops don't. You just would NOT do that on a performance motor !
Its not written about because your not supposed to cut corners like that , and would give you a bad rep.
I belive it was gale banks or callaway who did a lot of R&R about this in the late 60's or 70's. Bottom line if I remeber corectly, all the small discrepencies(cc sizesand small flow rate) could be made up by adjusting carb/FI, and a complete exact motor , cyl to cyl, runner to runner, there was no benifit.
By the way what was the planned expected beniffit from this ?
