Re: End of an Era -- "Patina", my '93 M900, dead at 265K
Quote:
Originally Posted by
PhilB
Thanks, y'all. The divorce was, and is, reasonably amicable. I ended up buying her car afterwards as well (the red Mini Cooper S in the picture). I've had it about a year, first car I've bought for transportation since 1988. Last winter I had a job project in Minneapolis; I got there on the bike in October, and thought maybe a car would be a good idea for a Minnesota winter (that got down to -25F!).
Below is a pic of how I got to Minneapolis on the Duc in October, which also shows why I'm looking at sport-tourers. I'm traveling more these days, and carrying more stuff, and the Monster's limits are being pushed hard. And yeah, whatever I buy, which is probably going to be a 939 SuperSport S, I plan to turn over 250K on in about the year 2040.
I was looking hard at the Motus MST, but they've gone out of business. I've checked out pretty much everything else in the current or recent sport-touring field. The MotoGuzzi Norge or Griso are still longshot possibilities. The KTM 1290GT was very tempting, but I can't find *any* data on KTMs with over 100K miles -- apparently nobody does that. The last two I haven't tested yet that I want to are the Kawasaki H2 SX SE, and the Honda VRF1200.
PhilB
Attachment 52336
Wow! How can you see above those tank bags? I think for the kind of miles you do, if you are looking for longevity, get a VFR. If you like the supersport 939, than a 2014-2015 VFR800 should also appeal to you. They look somewhat similar and have similar ergos. The Supersport is more sophisticated and more powerful, but the Honda 800 engine is bulletproof.
dankatz
I can see over the tankbag to ride. It blocks the instrument panel, so I have to lean over and look around it to see the instruments. But on those early Monsters, the only instruments are the speedo, odo, and a few idiot lights.
The VFR800 is a fine bike, I've looked at them. Honda makes good stuff. But they're a bit heavy, and I like twins better than fours. That's largely why I have eliminated all the fours I've looked at from consideration.
If I'm going to ride a four cylinder bike. it had better have something really exceptional about it. The Motus MST did; it was really stonking. The Kawasaki H2 SX SE could fall into that category; that's why I want to test one. The VRF1200A doesn't quite fall into that category for the engine, but the DCT could make a difference.
PhilB
Did the interceptor have Anti-Honda reliability concerns? Regarding the vtec?
Gixxer
I've spoken with a few owners over the years. It sounds like the biggest issue is with the valve clearance check as the VTEC system has certain complications built in. FWIW, none of the 3 had to go in an adjust the valves since everything was still well within spec. One of the owners had somewhere around 50k on his.
butcher bergs
I've had mine for 10 years - bought it on this forum. A 2007 RWB VFR. Did valve check at 16k - was perfect. Don't plan to do at 32k as most owners find it is not needed. Will stretch it out more. These bikes can easily go 100k.
Found this https://www.youtube.com/watch?v=ufW13P2I0nE
Nice comparison. Sounds like the Ducati is the better sports bike. I caution not to look at the specs - the VFR is more than the sum of the part.
