Results 1 to 10 of 10
f3+f4i subframes
    san fran
    f3+f4i subframes
    for you older cbr pro's, can you tell me if the subframes on the 600f3s are the same as the ones on the f4i with the split seat? i believe the ones with the split seat are from 01-03? ive seen a few people swap the tail from an f4i to an f3 but none mentioned anything about the subframes. just wondering if the plastic will swap cleanly or if i will have to make a new subframe.
    Tuono
    Dic on
    f3+f4i subframes
    F4i subframe is required.
    "Too bad ponies are assholes."
    OXX
    san fran
    f3+f4i subframes
    k looks like ill just fab my own and buy a race tail. will making the sub frame from aluminum (3/4" square stock) be fine for strength? i only weigh about 180 and wont be riding 2 up
    Tuono
    Dic on
    f3+f4i subframes
    You can pick up a perfect condition f4i subframe for about $100 on ebay. That would be the route I would go if I were you.
    OXX
    san fran
    f3+f4i subframes
    i see, so the f4i subframe will bolt up to the f3? i must have misunderstood you for saying that the frame wont bolt up.
    also i think 01-03 had the split seat and after that they went back to the fat banana seat. Are all the f4i subframes the same or do i need to find a subframe within the split seat years?
    Tuono
    Lifer JohnnyV's Avatar
    Westborough, MA
    f3+f4i subframes
    I believe some customization is required. I was looking into this when I had my F2(same frame/subframe as your bike) and there was some welding required. Let me look back on the cbr forum I was on. I know there's a "how to" writeup somewhere
    san fran
    f3+f4i subframes
    thank you much
    Tuono
    san fran
    f3+f4i subframes
    so basically what i have seen is that some people use the f4i subframe and others modify the f3 frame. guess ill just get the plastic first, fit it and go from there. thanks for the help
    Tuono
    Westborough, MA
    f3+f4i subframes
    No problem
  1. f3 and f4i subframes
    By catch2otwo in forum Bike Maintenance
    Last Post: 12-10-07, 07:37 AM
