I need some help..
I mounted a fiberglass belly pan that ended up pressing against the exhaust and burning the pan. The burn mark shows on the outside of the pan.
My question is:
Can I sand that spot and repaint (rattle can)or should I just cut it out? The spot is pretty low on the belly pan so it is hard to see.
I have since redone/rebent the brackets so that there is no contact and have wrapped that area of pipe in Tinfoil to try and create a little buffer.
Thoughts?
Thanks
