Results 1 to 17 of 17
Fuel question
    Fuel question
    What negatives could happen, if any, if you put a gallon of what might be 50:1 two stroke mix in the tank of a pick-up truck, then drove to the gas station & filled up to dilute it even more?
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    no trouble pete i do that all the time
    truck bike car no shit marval in the tank is advised
    not at 50 to 1
    www.bostonmoto.com
    Forum Rules
    Fuel question
    Werd, that's what Alex & I kinda figured but he asked me to tripple check to make sure. He called me & asked since he doesn't have 'net access where he is right now.
    wtf u mean by "marval in the tank is advised" though?
    May 2002
    Meriden CT
    its good 2 lube you cylinder/ s
    www.bostonmoto.com
    Forum Rules
    May 2002
    Meriden CT
    read the can
    it's in the instuctions
    www.bostonmoto.com
    Forum Rules
    May 2002
    Meriden CT
    www.bostonmoto.com
    Forum Rules
    Fuel question
    ah, cool... so that marval stuff is basically 2 stroke oil?
    May 2002
    Meriden CT
    no
    more thin tranny oil
    www.bostonmoto.com
    Forum Rules
    May 2002
    Meriden CT
    clean combution chamber & valves
    ive used it for years
    www.bostonmoto.com
    Forum Rules
    Fuel question
    aight, well wudever, as long as puttin a gallon of 50:1 fuel mix in Alex's truck is cool
    May 2002
    Meriden CT
    a little water works good 2
    feed through vac line
    www.bostonmoto.com
    Forum Rules
    May 2002
    Meriden CT
    not at 50:1 mix
    thats excesive IMO but it should work
    www.bostonmoto.com
    Forum Rules
    May 2002
    Meriden CT
    ive run kerosine in my tractors
    white smoke but it works .
    i had a old olds. desel that blew up so i talked a buddy it to none desel car he was pissed @ me lol smoked like a 2 stroke he he
    i din't what 2 dump it on the ground
    www.bostonmoto.com
    Forum Rules
    Fuel question
    beet... stop giving me a headach w/ all this friggin information I don't need ... i just want to make sure that if he puts ONE gallon of 50:1 two stroke pre-mix into his tank, drives to the gas station & fills it up w/ regular gasoline that it's ok. A simple "yes" or "no" answer w/ a quick explaination of why will do just fine
    Just Registered
    Is it not obvious?
    Fuel question
    you haven't read the webcrush thread huh?
    Last week on mythbusters they ran cooking oil through a mb diesel with no ill effects. 50:1 shouldnt screw up the truck so long as running two stroke oil it won't hurt it. So I'd say if it's not a problem it should be fine. I'd try to check and see if it will cause any problems and if it won't then it will probably be ok.
    Waterbury, VT
    Fuel question
    Mixing in a gallon of 50:1 two stroke with the gas already in the tank won't hurt the engine at all.
    SSearchVT
    Providence,RI
    Fuel question
    I have done it in my truck. That is how I get rid of all of my waste gas. I wouldn't do it with less than a quarter of a tank to start with.
    Mike Green
    LRRS #450 novice
    http://www.mikegreensculpture.com
    '06 svx550
    '04 cr500 af le
    '04 525 smr
    '02 660 sms
    '01 drz 450 sm streetbike
    '99 r7
    '99 sv650
    '86 rg500
  1. Race Fuel question
    By theducman in forum Pit Area
    Last Post: 04-18-22, 03:16 PM
  2. Fuel Used
    Last Post: 04-21-08, 10:24 PM
  3. Fuel so far?
    By Karaya One in forum Pit Area
    Last Post: 05-21-07, 05:59 PM
  4. fuel tank question
    By oreo_n2 in forum General Bike Related
    Last Post: 05-01-06, 04:34 PM
  5. Fuel stablizer question....
    Last Post: 11-16-04, 07:09 PM
