Results 1 to 20 of 20
Fuel stablizer question....
    Littering and........
    Jul 2004
    Vermont
    Is it better to drain the gas out of your bike, or to put fuel stabilizer in a full tank? I am hoping to run a track day in February, and I wondered if the fuel stablizer (Sta-Bil) is not the best stuff for use on the track?
    clack clack Ducrappy's Avatar
    Feb 2004
    New Ipswich, NH
    Re: Fuel stablizer question....
    I've never drained my tank, and always use fuel stabilizers. I've never had a problem, though I've also never owned a bike long enough to see if not emptying the tank will aid in rusting the tank from the inside.
    What I do is put the Sta-Bil into the tank when its rather low, ride to the gas station, fill up with 93 octane, then ride it back and park it (I do this as an attempt to mix the stabilizer thoroughly with the fuel). Then I top off the tank so there is no room for condensation to build up. Some people also use Dry Gas, though I've seen information somewhere that showed the Dry Gas just holds the moisture in suspension within the tank and never burns off, it just stays in the tank creating a mess. I am not however going to say this is the truth, just something I read somewhere.
    EDIT: The only adverse effect I've had from using the Sta-Bil is a strange smell as it burned with the fuel. I've never noticed any sort of performance issues like sputtering or backfiring.
    you seem to be related to nikon. so fuckyou too! go suck a cock./1
    2012 R1200GS Rallye
    Oct 2001
    Bedford, MA
    I did all kinds of riding with stabilized fuel last winter with no issue.
    I was basically adding stabil each time I filled up. I never knew whether or not I was going to be riding. It all depended on the weather. So after a while I was just riding around with fuel with stabilizer in it all the time. I'd just keep adding it at each fill up under the assumption that it would snow and stop my riding for a while.
    Didn't seem to cause any issues at all.
    I prefer this strategy, as draining everything for sure seems like more work, and then you have firmly commited yourself to staying off the bike.
    Member cexley's Avatar
    Aug 2003
    Canterbury CT
    I have heard that a few months of sitting is not long enough for
    the fuel to brake down any way. How true is this? I have never used any stab-il, and never had issues. Fill up then Sitting for 3 months tops. Start up in spring and ride. No problem
    '03 VFR SILVER
    I am the Plate, Step Up to Me
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    full tank of gas, add sta-bil, ride for a few minutes to allow it to get into the fuel lines/carbs, and yer done.
    if'n ya feel like it, top it off with fuel after the brief ride. full tank is a non rusty tank.
    cheers,
    chris
    Super Moderator legalspeed's Avatar
    Somersworth, NH
    I think it matters a lot if you are running traditional carbs, the needles tend to gum up because there is little fuel in the float bowls, you have to evap a lot to gum up your fuel tank resevoir. I know the needles in fuel injection are issues too, I'm not a mechanic by any means, so I use the stabil, fill 'er up, and don';t worry.
    I should think you will burn a little off riding around before your track day, the rest will be gone by 11am assuming you ride it hard in the morning sessions.
    Use the stabil, forget the worrying.
    LRRS\CCS\WERA #486
    Feb 2004
    New Ipswich, NH
    This might be a great arguement if Sta-Bil had a $200 price tag per ounce, but this shit is cheap. Why chance it? Fuel will start to degrade after a few months. If it sits too long, the shit will smell like terpentine and will wreak havock on your fuel system (ie stuck floats in carbs). Don't chance it. Sta-bil works wonders Its easier to pour some of this shit in your tank at the end of the season than it is to have to flush your fuel system if the fuel goes bad in the spring
    2012 R1200GS Rallye
    granite state
    good point tim. i just put some in the vfr last weekend but forgot to top it off. i'll have to do that this weekend.
    Gasoline begins to deteriorate the minute you pump it. How soon it affects the combustion in your vehicle depends on tuning, compression, etc.
    I've always just topped the tank off with the manu's recommended fuel and added stabilizer. No problems so far...
    Just be sure to run the bike long enough to get the stabilized fuel through the carbs/injectors. I usually just take like, a 5 minute rip around the hood to be safe...
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Yes stabil
    Yes to 1 to 2 oz of oil per gallon
    Also the alchohol in modern gas is dry gas
    yes blahblah ethanol vs methanol but it will suspend the moisture
    If your really finicky make sure the bike is HOT before final put up
    Shut off gas tank run the bike till the bike stops. no gas no problem.
    Then in the spring spend $500 and a tow to diagnose mysterious starting problem
    Glen Beck is John the Baptist
    Someone shit on the coats PatSV650's Avatar
    Apr 2004
    Just my $.02...
    If it uses gas, put Sta-Bil in it!! I put the stuff in the fuel for the mower, snow blower (that thing sits for at least 9 months), generator, weed wacker .... etc... blah blah blah.
    My father just spent about $150 at a shop having the carb on his quad un-gummed..... geuss he shoulda put fuel stabilizer in it!
    From what I understand, it only takes about a month for fuel to degrade.
    ibanezfourstring from that other
    site
    my blog
    '79 CB750 K (crash victim)
    '82 CB750 F Supersport (project: done! )
    "What is it about driving cars that makes you all such assh*les?!"
    "I could have said "YOU'RE ABOUT TO BE STRUCK BY A VEHICLE!! " but instead, it came out more like a concerned moan " Dane Cook
    Originally posted by PatSV650
    Just my $.02...
    I do the same. But it takes a lot less than a month for fuel to degrade. Usually, the higher the octane, the quicker it is to degrade...
    Also, avoid the temptation to go out and start your bike every once in a while during storage. Bad, very bad. Pull the battery and let it sit...
    Somersworth, NH
    Originally posted by richw
    Yes stabil
    Couldn't you just turn the valve back on?
    LRRS\CCS\WERA #486
    Dec 2003
    Massachusetts
    Just a side note, don't drain the tank, your inviting condensation and rust. Best bet is to full it to the neck.
    StumpyNB
    '11 Kawasaki Ninja 1000
    Waterbury, VT
    I use Stabil in all the toys and tools put away for the winter. It is cheap insurance. If you are worried about a track day early in the year try this.
    Like mentioned before, put the stabil in the tank at the gas station, fill up and ride home. This gets it all mixed in, and into the fuel system. In the spring, syphon the stored gas out (as much as you can), and use it in the lawnmower, splitter, etc. Fill the bike with new 93 or better. Hope this helps. Good Luck...
    SSearchVT
    Wow! I've always just run the tank of treated gas through come spring. Then I usually mix some injector/carb cleaner additive with the next tank of gas and run that through...
    FYI-Only put the high octane stuff in if the manufacturer says to, or if you're engine was built to run it. Almost everything I've ever read about gas/octane says that generally the higher the octane the quicker it is to degrade...
    Waterbury, VT
    Stoneman, The first post was a concern about using the Stabil laced old fuel on track day, that's why I suggested syphoning it out and replacing it.
    I also run the old gas and stabil through the toys and tools in the spring with some drygas in it. I am usually more concerned about the sand left in the road then overall performance of the bike or car.
    SSearchVT
    Mar 2004
    SS MA
    Here's a pretty good HowTo for storing a bike....Ducati dealer but applies to all.
    http://www.bcmducati.com/article.cfm?id=62&type=15
    '02 MS4
    I understood that. I've just never heard of syphoning it out like that. I guess I shoulda said something more akin to, "...the little amount of Sta-bil you'll use will have no ill effect as far as use on the track is concerned..."
    It's like, what? 2 ounces to every 5 gal. for storage? I use about half that (1 ounce per 5 gal.), and that seems to do me fine too...
  1. Fuel question
    Last Post: 05-20-06, 09:03 AM
  2. Motard Fuel Range
    By oreo_n2 in forum General Bike Related
    Last Post: 05-01-06, 10:26 PM
  3. fuel tank question
    Last Post: 05-01-06, 04:34 PM
  4. vp racing fuel
    By double agent in forum General Bike Related
    Last Post: 03-18-04, 07:33 PM
