Results 1 to 9 of 9
fuel tank question
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    fuel tank question
    i got a bigger fuel tank for the yz450...
    it straddles the bike and the sides go pretty low for capacity. that part is fine.
    it came with two right angle fittings. each fitting is threaded on one side and barbed on the other for hooking fuel line to.
    the directions say to screw one of them into the bottom of each side of the saddle of the tank, and connect them to each other with a piece of fuel line. this is all cool, it will make sure the two sides stay equal with fuel.
    the question... how do i just "screw" these things into the plastic of the tank? there are no marks or indicators for where these things go... and i am hesitant to drill holes into a brand new gas tank when i have no experience with these fittings in plastic and am not 100% sure they will seal well?
    Brent LRRS #772
    2006 KTM 560 SMR
    Lifer bbhzx10's Avatar
    Jul 2004
    North shore
    fuel tank question
    They didn't come with any bulkhead fitting or anything?
    Can you reach the bottom of the tank from the filler? I'm guessing not.
    2001 Silver ZX-12R... RIP
    2005 KDX 200
    Mar 2002
    Amherst, NH
    fuel tank question
    nope, no bulk head fittings. and ya cant reach it from the filler neck.
    its kinda weird, the directions are real specific about everything... except this.
    Brent LRRS #772
    2006 KTM 560 SMR
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    i would think you can put it where it's needed
    cookie make sure it's not going 2 interfere with the frame or any other of the stuff .
    www.bostonmoto.com
    Forum Rules
    Mar 2002
    Amherst, NH
    fuel tank question
    also... the bottom of the tank is just smooth plastic.
    and this is the type of fittings it came with.
    Brent LRRS #772
    2006 KTM 560 SMR
    May 2002
    Meriden CT
    is that a pipe tread cookie ?
    pipe treads are tapered
    www.bostonmoto.com
    Forum Rules
    Mar 2002
    Amherst, NH
    fuel tank question
    no its not tapered.
    i am gonna hit up the auto parts store on teh way home and see if i can find something that is tapered, or something with a flange so i can get a gasket/o-ring in there.
    if not, its just getting teflon taped.
    Brent LRRS #772
    2006 KTM 560 SMR
    Mar 2002
    Amherst, NH
    HA! HA!
    Ok i called IMS, they said i got the new tank and the old directions and parts kit. Don't use the goofy old equalizer set up.
    Now for the funny part...
    What the guy said:
    they redeisigned these tanks so that every time you accelerate, the gas sloshes back and equalizes itself between the two sides of the tank.
    What i heard: Wheely the 'tard out of every stop light.
    Brent LRRS #772
    2006 KTM 560 SMR
    fuel tank question
    The gas will equalize itself without any fancy insides or equalizer tubes, that stuff splashes all over at the littlest bumps.
    I should get something bigger for the KTM
  1. Fuel tank welder?
    By Garrett in forum Bike Maintenance
    Last Post: 11-04-13, 10:15 PM
  2. Fuel Tank Repair
    By gregp in forum Bike Maintenance
    Last Post: 02-06-10, 07:35 AM
  3. X-tra line from fuel tank??help...
    By wastedincome420 in forum Bike Maintenance
    Last Post: 10-01-03, 11:14 AM
