It's time to check, grease, replace those wheel bearings.. When did you last grease and check? Even twice a season is not too much!
Just a couple of weeks back helping a friend pick out his ride....
After purchase and trailing it back along 495 in MA at 70 mph sitting in the back seat I heard a bad noise out back, turned around to see smoke pouring from a partially locking rear trailer wheel...
Luckily only a few miles to my place, limped there, and with some major driveway surgery cutting off now welded bearing races and a trip to AutoZone got it all running again... Could have been ugly... trailers normally go up with a grease fire.... in this case so much rusty water with the grease probably saved the day...
Checking
http://www.youtube.com/watch?v=or2lS1QNLZE
If they need further inspection or replacing.
http://www.youtube.com/watch?v=HsCH1d6R7J0
If you go to the trouble to pull your wheel – I would replace the bearings and races – AutoZone has the STD 1" axle kits for about $12 per wheel
We want you to make it to our track days!
