Page 3 of 3 FirstFirst 123
Results 51 to 75 of 75
Grom build
  1. #51
    Re: Grom build
    At the wheel, on a reputable dyno? I'm really curious, I was around for the early 220cc+ Honda Wave platform motors with similar claims and actual dyno numbers ended up coming back much lower. 16hp is enough to push that grom to triple digits so I wouldn't be upset by it if that was the number. 25hp at the wheel from 180cc, 2v aircooled single without it being a grenade is... well, I'm going to be very impressed if it pans out.
    there are 2 reputable Grom builders on the east coast. the one i went with, i was his 68th 2v 181NEO kit and he had 2 waiting after me. they both work with a dyno tuner in FL that only works on mini bikes that came from specific shops. i'd say it's pretty accurate that i'll be around 24hp. if you read up the 2v 181 NEO kits, you'll see that they get 21+ horsepower. the 4v 181 NEO's will get close to 30hp.
  2. #52
    Re: Grom build
    I'm told the ZS190 in my K-Pipe puts out 17hp and I'm scared to use it all, I'm on 17" wheels, and about 65-70 is where fright takes over, I scooted up to 75 once, but I started to tremble and backed right down to 60, I cannot imagine going speeds approaching triple digits on 12" wheels but I'm a huge barn door with limited range of motion
  3. #53
    Re: Grom build
    It's not the size of the tires, it's the geometry of the setup that makes the difference.
    Re: Grom build
    Re: Grom build
    unless there was a 2nd one made, the bike blew up almost right after it was built.
    that pic is a 2014-2016 model, so i'm thinking it might be the same one
  6. #56
    Re: Grom build
    It couldn't use all that power.
  7. #57
    Re: Grom build
    that Grom race was a ton of fun. pics just came in
    Grom build-dsc_0761-jpg Grom build-dsc_0878-jpg
    now the unfun part was flying back to the pits to move the transponder onto the GSXR, take the warmers off, and go right back out for back-to-back races with something of slightly higher horsepower. took a lap or two to relearn how to ride it.
    Grom build-dsc_0942-jpg
  8. #58
    Re: Grom build
    I love the comments...
  9. #59
    Hypertarded
    RI / CT border
    Re: Grom build
    WTF is the deal with the handlebars?!? look slightly less comfortable than ape hangers....internally rotates wrists...
    Re: Grom build
    They're meant for an infant's short arms.
    Or maybe a T rex.
  11. #61
    Re: Grom build
    at the dyno today in Orlando. this shop specializes in Grom tuning
  12. #62
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Grom build
    good luck!
    Feb 2011
    Somerville MA
    Re: Grom build
    Grom build-screenshot-2023-10-18-12-a
    -Jared
  14. #64
    Re: Grom build
    Bought a CBR250 kickstand, cut off the feeler, and new powder coating. Can see in the left the CBR kickstand is more upright and helps the Grom from leaning over too much. When adding the Ohlins suspension, it raises the bike up and leans too much on an OEM kickstand.
  15. #65
    Re: Grom build
    Any updated numbers?
  16. #66
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    Re: Grom build
    +1. Never thought I would be anxiously awaiting Grom dyno numbers, but here I am.
    Re: Grom build
    very disappointing. 20.5hpnon 90 ethanol free pump gas. the amazon pipe is killing it. could change the cam with something with a different pipe and get to 24hp with ethanol free 93 pump gas.
  18. #68
    Feb 2011
    Somerville MA
    Re: Grom build
    That's still (I think?) about the same power that either of my stock CRF250L's made, so not too shabby!
    -Jared
  19. #69
    Central Maine
    Re: Grom build
    I never not been disappointed by a dyno! Still solid numbers on such a small bike!
    Lifer obsolete's Avatar
    Norf Sho
    Re: Grom build
    Butt dyno for the street, time slips for the track.
    -Alex
  21. #71
    Re: Grom build
    still 125cc? I wouldn't be disappointed. 4 valve head? my ZS190 (2 valve) is allegedly 17hp
  22. #72
    Re: Grom build
    181cc 2v. the 4v kits arent as reliable
  23. #73
    Re: Grom build
    good to know
  24. #74
    Re: Grom build
    good to know
    i believe there is some modifications needed for the 4v to fit properly as well. they make crazy power but not for the average rider that's not checking valves on the regular.
  25. #75
    Re: Grom build
    the 17 hp is plenty for the spaghetti frame on my K-Pipe, 4valve engines are available for quite a bit more cake, maybe a racer could justify the cost
