Page 3 of 7 FirstFirst 1234567 LastLast
Results 51 to 75 of 154
Harbor Freight lift table?
  1. #51
    Re: Harbor Freight lift table?
    I have a 2 car. I only park the truck in the garage when I expect snow as it does not fit easily. The other bay is open, but getting crowded with a workbench, chest and such.
    My coworker points out that if you do not put a tall wheel chock on the lift even his 2WD Tacoma will straddle the lift just fine. Meaning one could unload the lift, unbolt any wheel chock, and park the truck indoors when one expects snow. My goal is to try to use the lift without a permanent chock at all. Overall I'm not worried about losing the floor space. I expect not having to kneel or lay on the floor to change oil or service chains anymore will be worth it.
    Probably should go ahead and buy a set of tie downs and soft loops to dedicate to the lift now.
    I think I do enough bike maint to make the lift worthwhile, but not enough to make a professional one worth it. Typical HF customer, I think.
    I have their tire changer and it's easily paid for itself by now. Hopefully I'll be saying the same about the lift in a couple years.
    I have no air supply in my shop. Not seen the need to add it. I have an electric impact which is plenty for my needs. Pneumatic operation is actually a con for me, not a pro.
  2. #52
    Lifer LuvDog's Avatar
    Ashland, MA
    The HF lift is easy enough to move around. It has casters under it that allow you to slide it around when necessary
    2003 ZX7R
    1995 916
  3. #53
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    The floor space thing is the only reason I'd consider getting rid of mine...if you leave space to work alongside it on both sides, it takes about half a bay of prime real estate right in front of the workbench. Plus it demands orientation where you have some run up area to wheel bikes onto it, so there's another half bay, almost. As I said before though, it's damn sweet to use once set up. It's really nice to be able to set tools and parts right on the table as soon as they are used or needed, rather than reaching and running for every little thing that's needed during a job. I just wheel my toolbox over within reach of where I need it and it definitely speeds everything up.
    When the lift is collapsed and there's no bike on it, can you drive/park a car over it? Or is it still too "high"?
  5. #55
    Sep 2012
    Southwick,MA
    I've never tried; none of our cars usually end up in the garage. The front of the wheel vice would probably hit the bumper, and there's the air cord to avoid too. Besides those concerns a car could drive over it, but why do it that way when you have to store a bike somewhere anyway, may as well have the bike and lift share the same space, I figure.
    My lift is pretty heavy; no casters and I can manage slide it around myself (barely) but it's not something I'd want to do all the time.
    Put all these things together and you really need at least a couple toys that need wrenching and regular maintenance, along with at least a half bay to dedicate to it, or I could see it being more hassle than it saves, not even counting the expense. But if you have those things, it's awesome. I definitely feel like I'm better about maintenance, cleaning, and inspection of my bikes with the lift around just because I wasn't a fan of doing those things bent over or on my hands and knees. I swapped a frame on a cbr600rr and that worldve SUCKED without the lift. With it, it just took a while but was kinda fun.
    Bought the table. Exactly what I wanted, so far.
    Typical low-buck skimpage. Needs 2x as many washers, maybe some nice fender washers for the front wheel stop. Hardware feels like brie left out in the sun. Nothing that can't be fixed with a stop at the home center.
    But it works. Lifts higher than I expected. Dirty-toy oil changes just got crazy easy!
    Now on the hunt for a scissor jack to use with it. Something like this.
    Sep 2012
    Southwick,MA
    That dude in Bow NH supplied a jack like that with my lift, might sell separately. Link in my previous post in this thread
    I'm interested.. does it have the cradle ears like the one I posted? Need those
    Sep 2012
    Southwick,MA
    Yup. Im glad you posted the pic, i took them off and forgot what they are for!
    Mine looks very similar, except its black and where you crank it there's a big hex to attach a wrench with leverage. The jack is heavy as hell, challenging to lift without using both hands
    I use a car scissor jack as it was free. That double cradle looks like it would cup the ol' frame rails gently though.
  11. #61
    Newbie
    Oct 2016
    FRAMINGHAM
    Great question. I'm considering one, too. Also, Doc posted a great idea for a rolling work bench/table. I am planning on building something very much like that, only now it will be rolling with locking wheels. Great thread, thanks everyone.
    As far as Harbor Freight goes, their stuff is generally OK for the DIY, but definitely not recommended for professionals or heavy user.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    congrats Bubs. You're going to love that with your growing fleet. If I had my way I would have a table for each bike to sit on for it's due love and attention...
    Sep 2012
    Southwick,MA
    Haha that reminds me to check my powerball numbers! 350 mil!
    Reminds me to check my 401k and rebalance.
    One will do. Already used it to swap the gear oil on he two hunny. Easy. Almost effortless, having the cases right up there at belt height. For the first time in recent memory I got the whole oil change done without spilling so much as a drop. I dig it.
    Casters are fine for small moves or medium moves of small bikes. I pushed the WR around the garage up on the lift and it was fine. Little tight with the fire wood and all the crap in my garage for winter mode, even tighter with the truck in. But we'll make do. The convenience is worth it with this much maint to do. I am thus far happy with the lift for the $ spent. Well worth it.
  15. #65
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    So this thing stays on the casters, even when up? No stanchions or anything?
    Stays on the casters. Rear wheels are fixed, front are casters. There are feet that can be screwed down outboard of the front casters to immobilize and maybe provide just a bit more stability. For big bikes 2-wheeled winnebagos I would not extend all the way.. or I would weld on outriggers or something.. or buy a more substantial lift.
    Buddy of mine had a couple of these. He rolled up today with a new one in the box. Early Christmas gift from the wife.
    Aug 2009
    I bought one yesterday and have two questions.
    1. Is it necessary to check/bleed the hydraulic jack and why does it seem it is only a rubber button and not a bolt for the fluid?
    2. How do you keep the bike from rolling backwards off the front wheel stop and out of position with regard to the wheel chock when putting the bike on the centersand?
    Jan 2017
    Worcester, MA
    Absolutely check the oil level in the hydraulic jack as they tend to come only half filled. I had to top mine off and pretty much everyone I've spoken to had to as well. Easy enough and no bleeding involved.
    The bike will roll back a bit out of the front wheel vice when you put it on the center stand. There's really no way to avoid this. I recommend using ratcheting tie-downs to secure the bike when you have it on the center stand. It would be wise to add at least a second pair of U-bolts on the back end of the lift so that you can tie down 4 points when necessary.
    Maybe it was already mentioned in the first page or two of this thread, but I highly recommend tossing the HF wheel vise. Buy a real one online that will do the job properly. They can be had for around $100 - here's the one I bought: Motorcycle Lifts W-Vise Derek Weaver Co., Inc.
    I have the same scissor jack shown up above and I use it with the lift all the time. It's quite handy for pulling front wheels or forks.
    With 9 old bikes needing periodic maintenance, I use my lift all the time and have found it to be a great investment. And it isn't that hard to move around with a bike on it, as long as you take your time and move it slowly. Definitely have the bike tied down!
  20. #70
    Aug 2009
    Quote Originally Posted by tomk1960 View Post
    Thanks,
    I'll check the hydraulic oil tonight. It came with two sets of tie downs. I'll live with the vise, as it seems less critical with a center stand than if I was using it with only tie-downs to stand the bike up.
    I'm going to look into moving the wheel stop forward a bit and adjusting the position of the vise. The VFR1200X is a long bike.
    I'm using the built in vise with tie downs too. Good enough for my needs, for now.
    Love love love having a lift table.
    Hiram, ME
    I picked one up Friday, and used it a bunch on Saturday.
    I didn't even bolt on the wheel clamp(yet?). Saturday I swapped ice wheels off three bikes, so I rolled them onto the lift, and then used a dirt bike lift to get them up off the table. I've always found dirt bike stands to be a bit wobbly, and lifting them on a table to chest high didn't create more confidence, so I actually used straps to the rafters to steady them(keep them from rocking back and forth when heavy ice wheels were removed).
    My R6 is on the table now, for that I just rolled it up and put it on front and rear stands, since the forks are coming off.
    What scenario do you guys use the wheel clamp? For bikes you just want on the table, wheels down, straight up and down? I have a Baxley sport chock I used to stick a bike on just to test the lift out. I think I'd use that for regular maintenance where wheels aren't coming off.
    I'm trying to find the parts to convert this thing to pneumatic lift...
    I'd love to read how you go about this. Keep us posted!
  24. #74
    Lifer Pittenger5's Avatar
    Austin
    I replaced the clamp with a wheel chock. Then just tie downs to keep it in there. Also throw a rear stand under it. Works for 95% of the maintenance I need to do, and for the other 5% Ill deal without the lift.
    Zip Tie Alley #505
  25. #75
    Ditto this setup works great even for my Road King.. I use a scissor lift for the Harley. I put a couple of eye bolts closer to the front corners so the tie downs pull the bike into the wheel chock..
  1. For Sale - Parts & Tools | Harbor Freight Motorcycle Lift
    By Twheat18 in forum For Sale
    Last Post: 07-02-19, 10:26 AM
  2. For Sale - Parts & Tools | Harbor Freight Lift Table $100 come and get it
    By SteveM in forum For Sale
    Last Post: 08-14-18, 09:55 AM
  3. For Sale - Parts & Tools | Full bike lift, harbor freight(i think) need this thing gone by Sat 10/06 10-11am!!!!
    By lak-o-wits in forum For Sale
    Last Post: 12-04-14, 11:45 AM
  4. Harbor Freight Lift
    By Pittenger5 in forum General Bike Related
    Last Post: 01-09-14, 11:04 AM
