Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 154
Harbor Freight lift table?
  1. #76
    Lifer Pittenger5's Avatar
    Austin
    Re: Harbor Freight lift table?
    Ditto this setup works great even for my Road King.. I use a scissor lift for the Harley. I put a couple of eye bolts closer to the front corners so the tie downs pull the bike into the wheel chock..
    Same
    Zip Tie Alley #505
  2. #77
    Aug 2009
    Off to get some hydraulic fluid. I clearly do not understand how these jacks work. Shouldn't the fluid be under some sore of pressure? There's just a rubber button as a cap.
    You're filling the resi the pump draws off of. No pressure there. It gets drawn from the resi by the pump and shoved unceremoniously into the piston to make the jack do it's thing. Not enough in the resi and you'll only be able to make the jack go so far.
    Aug 2009
    Got it, thanks
    rides bikes
    Nov 2014
    If any of you guys are getting rid of your stock vices, I'll happily take one! Been looking for one to modify.
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    I'v got the stock HF vise that came with my HF lift. Where do you live?
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
  7. #82
    rides bikes
    Nov 2014
    I live in Salem, MA and work in Acton. Either of those anywhere near you?
    Sep 2013
    Jaffrey NH
    I work in fitchburg, about 25-30 minutes away from acton.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
  9. #84
    If any of you guys are getting rid of your vices, I'll happily take one!
    I've been trying to unload onanism, but no one wants to take it off my hands.
  10. #85
    rides bikes
    Nov 2014
    Cool. I'll hit you up next time I have plans to go out there. There's actually a bike on CL that I want to check out in Fitchburg...
    Junior Member Stevie's Avatar
    Apr 2015
    Londonderry, NH
    Harbor Freight lift table?-20170122_182950-jpg
    I ditched the table and went with the Eazy Rizer. More money, but way more versitile, rock steady and takes only about a 3 foot square when not in use. Initial setup is takes a little tweaking, but it's quick & easy afterwards. The Red model is rated for 750 lbs and will do all of that. Blue model uses same lift mechanism but has a slightly larger base so it's good for 1,250, IIRC.
    I like that I can pull the wheels.
    Attached Thumbnails Attached Thumbnails Harbor Freight lift table?-20160322_204809-jpg
    Anyone who lives within their means suffers from a lack of imagination.
    - Oscar Wilde
  12. #87
    Hiram, ME
    That thing is cool, but it looks like it's harder to switch from bike to bike? I actually like having the table under the bike, too, as a workspace, for tools, etc.
    The instances of "Where'd I leave that damned 10mm" have actually reduced since buying this table
    I remember I bought a tool cart at one point that was theoretically supposed to be able to be rolled to a bike to work on it and keep tools handy. The shop has mutated, consuming the tool cart and making it part of itself. Like a scene from Aliens or something.
    Apr 2015
    Londonderry, NH
    Haha! My shop hasn't eaten the cart...yet.
    Yes, there is some adjustment needed to switch bikes, but once you've done it a few times, it's only 5 minutes or so. I wouldn't want this for a commercial shop, but if I had a business, taking up a whole bay with a table wouldn't be an issue.
    Sep 2013
    Jaffrey NH
    Stevie, where did you get that and how stable is it with a bike on it??? I like that.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
  16. #91
    Apr 2015
    Londonderry, NH
    It's very solid. As long as the floor is reasonably flat at the base, I think you would have to purposely try to knock it over. I have it on concrete so no issues at all. I usually lower the bike to torque the wheels or do things that require a lot of force, but it's plenty secure even when all the way up. Normal wrenching is fine; oil changes, chain service, wheel cleaning, etc., are all easy.
    It's made in England, not Asia, and, to my knowledge, Jeff White's company (lifts-and-stands.com) in GA is the sole US distributor. He has been fine to work with. Very responsive and and returned my calls while he was away at Daytona bike week - even seemed sober!
    This thing is well made and rugged so they don't give them away. Price-wise, it's right in the ball park with the medium quality lift tables like the ones sold by NH Pro Equipment in Bow, NH. Quality is definitely better than the Harbor Frightening stuff! Best of all, it takes up very little floor space when not being used. My only wish for improvement would be to add a couple of wheels so I could tilt and roll it instead of dragging across the floor. I'm getting old...
    If you want to check it out in person, I keep mine at my workshop in the Nashua area. PM me and I'll give you a phone # and directions.
    - Oscar Wilde
  17. #92
    Member flippedr6's Avatar
    Jul 2015
    Reading, MA
    I was looking at that HF lift but then I found this and like the features it has over the HF one and without the coupon it's the same price. Mostly the same but better wheel clamp and it uses air.
    MC1000 1,000 LB. Capacity, Air/Hydraulic Motorcycle Lift | GSES
    2008 Kawasaki Concours 14
    2018 Beta 390 RR-S
  18. #93
    Hiram, ME
    Quote Originally Posted by flippedr6 View Post
    Hmmmm...I wish I had seen that one sooner...
    Hiram, ME
    Actually, looking at it, I bet the jack from that one would fit the HF model; they really do look identical. Would you mind getting some good pictures of the pneumatic jack when you have a chance?
    Jul 2015
    Reading, MA
    I will but I have not purchased it yet. I am driving up Saturday am to go buy it.
    2018 Beta 390 RR-S
  21. #96
    Sep 2013
    Jaffrey NH
    I've been to their business to pick up some side extensions for one of my brothers table lifts. Wish I had a pocketful of money when I went. I would have come back with a truck load of stuff.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
  22. #97
    Jul 2015
    Reading, MA
    Thanks for the heads up I'll bring exact change and leave the wallet at home
    2018 Beta 390 RR-S
  23. #98
    Hiram, ME
    Harbor Freight has the lift table in their latest ad for $330.
    Y'all suck. I had myself convinced I didn't need one of those. Now I am seriously questioning my previous decision....
    Sep 2013
    Jaffrey NH
    Sorry Mike but if you're paying more than $300 then you're getting took. I just might have a few coupons for $279 or $299, I'd have to check.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
  1. For Sale - Parts & Tools | Harbor Freight Motorcycle Lift
    By Twheat18 in forum For Sale
    Last Post: 07-02-19, 10:26 AM
  2. For Sale - Parts & Tools | Harbor Freight Lift Table $100 come and get it
    By SteveM in forum For Sale
    Last Post: 08-14-18, 09:55 AM
  3. For Sale - Parts & Tools | Full bike lift, harbor freight(i think) need this thing gone by Sat 10/06 10-11am!!!!
    By lak-o-wits in forum For Sale
    Last Post: 12-04-14, 11:45 AM
  4. Harbor Freight Lift
    By Pittenger5 in forum General Bike Related
    Last Post: 01-09-14, 11:04 AM
