Re: Harbor Freight lift table?
Quote:
Originally Posted by
MUZ720
Ditto this setup works great even for my Road King.. I use a scissor lift for the Harley. I put a couple of eye bolts closer to the front corners so the tie downs pull the bike into the wheel chock..
Same
Off to get some hydraulic fluid. I clearly do not understand how these jacks work. Shouldn't the fluid be under some sore of pressure? There's just a rubber button as a cap.
You're filling the resi the pump draws off of. No pressure there. It gets drawn from the resi by the pump and shoved unceremoniously into the piston to make the jack do it's thing. Not enough in the resi and you'll only be able to make the jack go so far.
Kurlon
Got it, thanks
If any of you guys are getting rid of your stock vices, I'll happily take one! Been looking for one to modify.
nick5446
I'v got the stock HF vise that came with my HF lift. Where do you live?
Tas
I live in Salem, MA and work in Acton. Either of those anywhere near you?
I work in fitchburg, about 25-30 minutes away from acton.
nick5446
If any of you guys are getting rid of your vices, I'll happily take one!
I've been trying to unload onanism, but no one wants to take it off my hands.
Tas
Cool. I'll hit you up next time I have plans to go out there. There's actually a bike on CL that I want to check out in Fitchburg...
2 Attachment(s)
Attachment 46813
I ditched the table and went with the Eazy Rizer. More money, but way more versitile, rock steady and takes only about a 3 foot square when not in use. Initial setup is takes a little tweaking, but it's quick & easy afterwards. The Red model is rated for 750 lbs and will do all of that. Blue model uses same lift mechanism but has a slightly larger base so it's good for 1,250, IIRC.
I like that I can pull the wheels.
That thing is cool, but it looks like it's harder to switch from bike to bike? I actually like having the table under the bike, too, as a workspace, for tools, etc.
:stupid: The instances of "Where'd I leave that damned 10mm" have actually reduced since buying this table
I remember I bought a tool cart at one point that was theoretically supposed to be able to be rolled to a bike to work on it and keep tools handy. The shop has mutated, consuming the tool cart and making it part of itself. Like a scene from Aliens or something.
Haha! My shop hasn't eaten the cart...yet.
Yes, there is some adjustment needed to switch bikes, but once you've done it a few times, it's only 5 minutes or so. I wouldn't want this for a commercial shop, but if I had a business, taking up a whole bay with a table wouldn't be an issue.
Stevie, where did you get that and how stable is it with a bike on it??? I like that.
Tas
It's very solid. As long as the floor is reasonably flat at the base, I think you would have to purposely try to knock it over. I have it on concrete so no issues at all. I usually lower the bike to torque the wheels or do things that require a lot of force, but it's plenty secure even when all the way up. Normal wrenching is fine; oil changes, chain service, wheel cleaning, etc., are all easy.
It's made in England, not Asia, and, to my knowledge, Jeff White's company (lifts-and-stands.com) in GA is the sole US distributor. He has been fine to work with. Very responsive and and returned my calls while he was away at Daytona bike week - even seemed sober!
This thing is well made and rugged so they don't give them away. Price-wise, it's right in the ball park with the medium quality lift tables like the ones sold by NH Pro Equipment in Bow, NH. Quality is definitely better than the Harbor Frightening stuff! Best of all, it takes up very little floor space when not being used. My only wish for improvement would be to add a couple of wheels so I could tilt and roll it instead of dragging across the floor. I'm getting old...
If you want to check it out in person, I keep mine at my workshop in the Nashua area. PM me and I'll give you a phone # and directions.
I was looking at that HF lift but then I found this and like the features it has over the HF one and without the coupon it's the same price. Mostly the same but better wheel clamp and it uses air.
MC1000 1,000 LB. Capacity, Air/Hydraulic Motorcycle Lift | GSES
flippedr6
Hmmmm...I wish I had seen that one sooner...
flippedr6
Actually, looking at it, I bet the jack from that one would fit the HF model; they really do look identical. Would you mind getting some good pictures of the pneumatic jack when you have a chance?
Mr. Kurtz
I will but I have not purchased it yet. I am driving up Saturday am to go buy it.
flippedr6
I've been to their business to pick up some side extensions for one of my brothers table lifts. Wish I had a pocketful of money when I went. I would have come back with a truck load of stuff.
Tas
Thanks for the heads up I'll bring exact change and leave the wallet at home
Harbor Freight has the lift table in their latest ad for $330.
flippedr6
Y'all suck. I had myself convinced I didn't need one of those. Now I am seriously questioning my previous decision....
Mr. Kurtz
Sorry Mike but if you're paying more than $300 then you're getting took. I just might have a few coupons for $279 or $299, I'd have to check.
