Results 1 to 5 of 5
Headlight question
    Senior Member marshdrummer's Avatar
    Nov 2006
    Southington, CT
    Headlight question
    I want to put projectors on my TLR. The stock harness is for H4 bulbs, the projectors are H1's. Can I just plug them in the stock harness, or do I need to some type of mod so not to blow fuses?
    Senior Member MsHap's Avatar
    Headlight question
    Well the H4s are full Lamps and regular beam and the H1s are just one beam plus the bases are different
    My Name is Chrissy
    This is Jello
    Have you hugged a corner today?
    Lifer JohnnyV's Avatar
    Westborough, MA
    Headlight question
    On tlplanet.com there are a bunch of projector conversions that have been done, I'm sure you could do a search there and find what you're looking for.
    With that being said, do you mean PROJECTOR, or HID? because it is possible to retro a HID kit into a convensional housing.
    Nov 2006
    Southington, CT
    Headlight question
    It's a halogen projector. Eventually I'll do a hid kit, but right now, I don't want to burn my bike up!
    Lifer ZX-12R's Avatar
    Candia, NH
    Headlight question
    You will have to modify your harness to use H1 bulbs. H4 bulbs have 3 pin connections (high, low, common) where the H1 has only one pin for power and its metal base is the return. This means you have to have a ground connection from the base of the bulb to your battery's negative terminal. Most fully faired bikes have plastic headlight assemblies which means there is no ground connection for the lights. You will have to make sure the new lense assembly you are getting has a place where you can bond a return wire otherwise your H1 will not turn on.
  1. Replies: 2
    Last Post: 10-12-16, 04:08 PM
  2. '02 F4i headlight
    By Kazinator in forum Wanted
    Last Post: 08-06-11, 03:31 PM
  3. Headlight question
    By EFD 05 1K in forum General Bike Related
    Last Post: 03-09-10, 09:09 AM
  4. CBR600RR Upper/Headlight bracket question
    By wylee in forum General Bike Related
    Last Post: 09-10-07, 01:05 PM
  5. ZX6R - headlight question
    By neek in forum General Bike Related
    Last Post: 07-14-06, 04:10 PM
