Results 1 to 6 of 6
Help on clutch perch/lever to clear aftermarket handlebar controls
    High maintenance priss
    Central MA
    I'm making a Yamaha WR road-worthy. I installed a new handlebar control, but it interferes with the current clutch lever. It's an ASV lever on what appears to be an OEM clutch perch. The clutch lever's adjuster (threaded screw & locknut) hits the handlebar switch.
    What are my options? I cannot move or grind the switch. The solution has to involve a new clutch perch or a new lever. Anyone hit this problem before? Would any clutch lever work? Is there a reason I wouldn't want to use one from a street bike?
    I can get pictures if it helps.
    Re: Help on clutch perch/lever to clear aftermarket handlebar controls
    Hmmm Pics if ya got em....... and I have a 04 WR if you want a OEM pic to help
    could be the ASV leaver....
    Central MA
    Here's a pic. The chrome locknut for the adjuster screw hits the aftermarket light switch.
    Help on clutch perch/lever to clear aftermarket handlebar controls-img_20150611_235358_553-jpg
    Even removing the locknut and tweaking the adjuster, the lever will still hit the switch. Its like I need the pivot to be away from the bars just another 1/2" to clear or a lever w/ different style (no adjuster). Also wondering a regular sport bike clutch would work, just don't know if the cable travel and lever ratio would work.
    Derry NH
    Not the cheapest option, but CRG makes a couple pretty killer clutch perches that should give you plenty of clearance for that switch. Or maybe just a new lever that doesn't have the adjuster on the inside of the lever like that ASV one.
    Or put the switch on the other side of the perch?
    Central MA
    Moving the switch isn't an option unfortunately.
    Looks like other mfr clutch levers have more clearance vs. ASV, so I'm probably gonna try that route.
    I also found perch spacers by RSC...had no idea such a thing existed until i stumbled on their site. This would probably let me use the current ASV lever & perch. I might give RSC's entire clutch lever a try - they have a modified ratio which reduced pull effort. Found some WR450 folks using them with good results.
  1. Wanted - Parts & Tools | Clutch perch bolt for 03+ SV650 (or complete perch) also 00-03 GSXR clutch perch
    By juha_teuvonnen in forum Wanted
    Last Post: 05-22-18, 10:57 AM
  2. No clutch lever? No shift lever? No footpeg? No problem.
    Last Post: 08-29-11, 01:25 PM
  3. WTB: Ninja Levers + clutch perch
    By scottfromboston in forum Wanted
    Last Post: 10-14-10, 09:37 PM
  4. Wanted: 06+ R6 Clutch perch
    By Kitt in forum For Sale
    Last Post: 06-22-09, 12:28 PM
  5. Anybody got a spare clutch lever + perch?
    By Honclfibr in forum Pit Area
    Last Post: 04-20-06, 07:54 PM
