Results 1 to 8 of 8
need help! engine noise, skyrocketing RPMs
    martyk martyk's Avatar
    canton ma
    ok so looking for someone to possibly give me a hand. Heres the story:
    I have an 03 kawasaki 636 with under 12,000 on it, over the winter i decided to tear down and sandblast the frame, subframe, and upgraded rear swingarm (its off an 07 636) as well as upgrade the rims (from an 05 636) . only real "mods" i did was manual CCT and block off plates for the top of the motor and changed the oil. ok....
    the dilemma:
    turn the key to power up and i get alot of mechanical noise from the right side just under the airbox where the throttle bodies are, there is a little motor there which buzzes, which it is supposed to do but it goes a little haywire and abnormal then stops, ok whatever
    i go to start the bike and it starts then the RPMs skyrocket within seconds so i hit the kill switch, (the bike is currently sitting upright on front/rear stands) thinking maybe the idle adjuster is off i back it out a few turns then try again, same result, get to the point where there is no pressure on the point where the idle adjuster contacts. seems like it is also running very rich? pretty much stinks like a lawn mower. So this is here I stop and decide i am going to post on here and hope someone more mechanically inclined may be able to help me. i am more then willing to pay if it ends up being something where you get your hands dirty (i guess at least i can spring for a case of beer of your liking). So if anyone is near norwood or feel like making the drive here post up or send me a PM. i work nights so sleep from about 8am till 4pm with tuesday thru friday off , technically.
    thanks in advance to anyone who may be able to help
    Just Registered Origin's Avatar
    Lynn, Ma.
    Re: need help! engine noise, skyrocketing RPMs
    Have you checked to make sure the throttle cable isn't being pinched?
    - TJ
    canton ma
    i havent but will check, however i dont think it would do what its doing if it was wouldnt explain the smell, this is fahking annoying
    Newbie Linteau's Avatar
    May 2012
    Somersworth, NH
    Do you have a after market pipe? I have a feeling that when you did the block off, that's what's making it run rich. The reason I think this is, I did block offs on mine and it's also running rich.
    I need to find a dyno around me get a good tune. Again, this is just my thoughts.
    As for the idle and noise, could you cct be to tight?
    Jumper mod, kleen air mod,
    Gold ZXR Bar ends, Akra slipon
    Zero G. DB windscreen, Skidmarx tire hugger
    Integrated Tail light, Driven Axle Blocks, Speedo Healer
    K&N Air & Oil Filter, -1/+2 SuperLite Sprockets
    PC3, Galfer SS Front & Rear lines, Shorty levers
    Powder Coating done by, Myself
    SHIFT!
    2016 BMW S1000XR
    canton ma
    oki should specify maybe...im not even riding at this point , bike is up on stands.
    i just have a chopped yoshi pipe, i think its gotta be throttle bodies, im about to go out to the garage to check on that
    canton ma
    pulled the code, code 62: subthrottle valve actuator malfunction, wiring open or short
    figure this is my problem...time to trouble shoot this
    canton ma
    problem resolved, subthrottle actuator unplugged, secondary butterflies removed
  1. KTM LC4 640 Engine Noise
    By LXnastynotch93 in forum General Bike Related
    Last Post: 07-31-14, 10:28 PM
  2. SV popping at low rpms
    By McBiggity in forum Bike Maintenance
    Last Post: 08-26-11, 10:05 AM
  3. Mixture Problems and RPMs out of control
    By demo19 in forum Bike Maintenance
    Last Post: 09-20-08, 01:15 PM
  4. Popping noises coming down from high RPMS?
    By joberly in forum Bike Maintenance
    Last Post: 08-06-04, 09:34 PM
  5. Engine Noise???
    By SSearchVT in forum Bike Maintenance
    Last Post: 06-16-04, 06:49 AM
