Results 1 to 25 of 26
Looking for help with a small custom sheet aluminum job
    Secoast NH
    I want to make a small flat bracket to mount a RAM mount or Go Pro on a Ducati Supersport, using 3/16" sheet aluminum. The finished piece is about 3 1/4" x 3 1/4, with two holes drilled to 3/8" D.
    This will attach to the two chicago screws attaching the plastic housing around the ignition.
    A crude mock-up using hardboard is shown to illustrate the cutting needed. The critical dimensions and cuts are hole locations and the ears around the holes to avoid the housing.
    Any suggestions where to get this done? (I am in metrowest area, but some travel is OK too.)
    Looking for help with a small custom sheet aluminum job-img_2159-jpg
    Member Johnpewpew's Avatar
    Aug 2017
    Concord, NH
    Re: Looking for help with a small custom sheet aluminum job
    I'll look and see if I got some scrap laying around.
    3 1/4x3 1/4 square. By 3/16 thick. With 2 3/8 holes drilled. Where do you need the holes drilled on the plate?
    2016 triumph street triple R
    "A Journey must begin with one step"
    Secoast NH
    Quote Originally Posted by Johnpewpew View Post
    The critical dimensions are 2x 0.375" holes 2.1" separated and then a 0.575" radius cut around the bottom 1/2 of the holes. The rest of the can be straight and dimensions are less critical, and I could try with a jigsaw.
    Looking for help with a small custom sheet aluminum job-img_2160-jpg
    Aug 2017
    Concord, NH
    Ok let me see what I got laying around
    Aug 2017
    Concord, NH
    No dice on the 3/16" thick aluminum. I got 1/8"
    Secoast NH
    Appreciate you checking.
    Lifer Falko's Avatar
    MoonTown
    How professional do you want it? If you want something that looks factory, I've had things done at ET Duval in Leominster. They have a water jet, they'll CAD it up and cut it out. Pricey though for that one piece. If you want to just cut it out and sand/file/polish it over time to a good look, I might have a chunk of metal lying around here.
    Secoast NH
    How professional do you want it? If you want something that looks factory, I've had things done at ET Duval in Leominster. They have a water jet, they'll CAD it up and cut it out. Pricey though for that one piece. .
    Well, depends upon the Supersport market size.
    FWIW - I was on group ride a week and half back, and there were 4 brand new Supersport Ss on the ride!
    Thanks for the pointer. I will check, does not hurt to ask.
    Aug 2017
    Concord, NH
    I can do it out of steel. I got 12g steel laying around
    Member flippedr6's Avatar
    Jul 2015
    Reading, MA
    If you give me a few other dimensions I can draw it in Solidworks and water jet it out. I have a ton of stock at work I'm sure I have the 3/16
    edit or if you want send me the template I can measure and compare before I send it back.
    2008 Kawasaki Concours 14
    2018 Beta 390 RR-S
    Aug 2017
    Concord, NH
    Quote Originally Posted by flippedr6 View Post
    That's better than what I can do lol
    Secoast NH
    Outstanding offer. I will work up a detailed drawing tonight!
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Aluminum is incredibly easy to cut and file, you could cut it with a jigsaw slightly oversize and then file/drawfile the edges to the line. Drill the holes with a drill press and you're done. You can buy raw material at Home Depot (overpriced but you're buying such a tiny quantity that it doesn't matter).
    Although I agree it is much easier to find someone with scrap and a waterjet cutter.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Secoast NH
    I have attached a PDF with more detailed dimensioning that I think (hope) is sufficient to enter into CAD.
    Thank you very much, and let me know if I missed anything in the drawing.
    Attachment 47811
    Jul 2015
    Reading, MA
    Will do man I should be able to do it tomorrow.
    2018 Beta 390 RR-S
    There's a metal shop in Woburn mass and they sell sheets to bar stock.
    Jul 2015
    Reading, MA
    Quote Originally Posted by imstuner View Post
    If you are talking about Metal Mart on 6th avoid avoid it. They are so over priced its crazy. There is Admiral metal over near BJ's but they dont sell smll stuff.
    2018 Beta 390 RR-S
    Thanks for the tip and I'll go check it out.
    Sep 2006
    Swampscott, MA
    Metal Mart is really pricey, but they're sort of the only game in town for small quantities. I've been curious as to the best place to buy mild sheet steel in the Boston area -- especially 19 gauge.
    Joe
    01 SV650 (Track)
    Quote Originally Posted by joeswamp View Post
    I looked for ages when I lived in Boston proper & never found a good resource. I ended up going to Metal Mart. Yeah, they're pricey, but no one else is willing to bother with such low quantities.
    Lifer Stromper's Avatar
    Eastern Ct
    Mc Master Carr
    You should be ablw to hack that out with a jig saw , and a file
    The calculus of hate
    Secoast NH
    I finally have the bike, bracket, and hard-to-find-dimension-off-the-shelf sex change screws all in the same place today. Installed the bracket, mounted the gopro and took it for a test ride. Worked out great, and I have now have a nicely-centered and stable camera mount for the 2017 Supersport, just in time for track day.
    Huge thank you to flippedr6 for building the bracket for me - perfectly done!
    Bracket installed:
    Looking for help with a small custom sheet aluminum job-img_2325-jpg
    With gopro installed:
    Looking for help with a small custom sheet aluminum job-img_2326-jpg
    Frame grab from test ride video:
    Looking for help with a small custom sheet aluminum job-screen-shot-2017-09-08-a
    5 Not allowed! Not allowed!
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Looks mint. Nice work
    Senior Member AEG's Avatar
    Aug 2012
    Simsbury, CT
    You might want to adjust the camera to not record your speed on the street ... just in case Looking for help with a small custom sheet aluminum job
    Secoast NH
    Quote Originally Posted by AEG View Post
    that is why I posted the frame grab and not the video
  1. Custom aluminum wheel spacers?
    By Tekime in forum General Bike Related
    Last Post: 02-14-19, 08:06 PM
  2. Where to get a small aluminum welding job done?
    By rpete in forum General Bike Related
    Last Post: 06-25-17, 02:32 PM
  3. CNC machining - aluminum proto fab (small quantity)
    By trider143 in forum Bike Maintenance
    Last Post: 09-25-10, 05:13 PM
  4. Aluminum Sheet
    By tom5796 in forum Bike Maintenance
    Last Post: 09-19-08, 02:13 PM
