Results 1 to 24 of 24
Improperly weighted tire?
    May 2003
    Lakes Region, NH
    Look about the footguard at the peg. See it "kicking"?
    <embed width="352" height="308" type="application/x-shockwave-flash" src="http://vidmg.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v257/RevLordNikon/NESR/bikechain.flv"></embed>
    Bras cause cancer.
    I think a chain with a tight link
    Lifer union's Avatar
    Blackstone, MA
    Im willing to bet its because the rear wheel is in the air and the transmission isnt under load. My bike does the same exact thing. Not being technically savvy with all the right vocab I believe its cause by the shift dogs not properly engaging. So as the they rotate they come in contact and cause the transmission to bind for a sec.
    On my rc is will even jump a bit from time to time when its engaged with the rear in the air. When its on the ground and under load its as smooth as ever.
    James
    I concur, captain.
    All bikes do that under no-load conditions.
    derek
    May 2003
    Lakes Region, NH
    Originally posted by Degsy
    I concur, captain.
    derek
    Thanks. I've never noticed anything when riding and this was the first time that I have ever had it in gear when it was on the rear stand - makes me nervous to have it running when in the air but I just wanted to give the chain a little once over instead of a full clean due to the dirt roads we got stuck on yesterday. If that's not a run on sentence then I don't know what is .
    Bras cause cancer.
    Blackstone, MA
    I think most of us learned this way. I had just put my wheel back on and decided it would be easier to check the chain to make sure its aligned right and lube it up while it was still on the stand. I thought the bike was going put itself through the roof. First thing I thought was oh shit time for a tranny rebuild. I then sent a message to one of my friends that knows the RC in an out and just did a transmission rebuild on his track bike and then one to Degsy. Both kind of said the same thing. Once I put the bike on the ground and tried it out very cafeully it was just as good as ever.
    James
    Senior Member LiononaLeash's Avatar
    Oct 2005
    You weren't doing the quick cleaning of your chain with the bike running in gear were you I hope?
    Even at an idle, that machine can screw you up real bad.
    If you weren't, then ignore this post!
    May 2003
    Lakes Region, NH
    I did. I admit it. I had it in gear and sprayed the bitch down. Didn't touch it - just sprayed to get the dirt out.
    Bras cause cancer.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Spraying OK from distance
    Cloth or fingers will be grabbed and cut off
    in 0.001 seconds
    Good worrying but looks normal
    If water don't leave a chain just sprayed. A short ride will throw boil moisture off the chain.
    Best chain clean
    Lube
    Clean
    Lube
    Ride
    Glen Beck is John the Baptist
    May 2003
    Lakes Region, NH
    Every 500 mi I get in there with a toothbrush and WD40 (not a spray bottle) and clean it really well then go at it with a cloth to get the gunk out then I spray lube it. None done with bike on or in gear. This time it just needed a little help though due to the dirt/gravel roads we got stuck on the day before so I just went at it with a little WD spray and spray lube as a quick go. I do it for real in a couple hundred more miles. It was just done but that dirt road dried it right out.
    Bras cause cancer.
    KB KB's Avatar
    Manchester NH
    If you bang it off the limiter in aevery gear while on the stand that action will smooth right out.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Bikeless SmokennFasTT's Avatar
    Apr 2006
    ManchVegas, NH
    man u crack me up lol
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    03 XR400 R(TARD) - Sold
    Feb 2004
    Bellingham, MA
    You're seeing a harmonic fequncy of the power pulses.
    Just Registered Doc's Avatar
    Jericho, VT
    Oct 2005
    Yeah.... he's been seeing that stuff since the 80's
    granite state
    Lifer BostonSVkid's Avatar
    Dec 2005
    DO NOT I REPEAT DO NOT use WD40 on your chain. It dries out the O-Rings and you will start to get locked links and replace it sooner than needed.
    If you are gonna clean it use something else man even kerosene is better.
    2006 Ducati Monster S2R800
    Oct 2005
    You left out the most important part of your post.
    What to use to clean your chain!
    You covered rather well what not to use. Unfortunately, that doesn't help.
    (I use Kerosene by the way)
    Dec 2005
    Kerosene for a deep clean and a wet soapy rag otherwise with some degreaser
    May 2003
    Lakes Region, NH
    It's the propellent in the wd40 cans that fucks up the o-rings. Use the big containers in a cup and you're all good.
    Bras cause cancer.
    22k on my last chain, always use WD in the spray can to clean it.
    Of course, I'm the chain lube nazi. I have been known to lube other people's chain just cause it bothers me to see a dry chain.
    I guess I should ask one of the RC51 guys what they use. I'd much prefer to get like 8 or 10 miles out of a chain and sprockets
    2016 BMW S1000XR
    May 2003
    Lakes Region, NH
    Bras cause cancer.
    Apr 2006
    ManchVegas, NH
    i only get 5miles... help me out.. what do i do
    02 R1
    06 WRX STi Sold
    01 RC51-STOLEN
    Feb 2004
    Bellingham, MA
    Buy your chains from me.....
  1. For Sale - Services | $10/tire change + dynamic balance - June 2021 tire changing blowout special (hah)
    By PurplePackage in forum For Sale
    Last Post: 06-24-21, 03:00 PM
  2. Flywheel Weight vs Weighted Flywheel
    Last Post: 11-19-15, 08:06 PM
  3. For Sale - Parts & Tools | Harbor Freight tire changer with motorcycle tire attachment
    By -Dutch- in forum For Sale
    Last Post: 06-21-15, 11:31 AM
  4. Weighted Bar Ends
    By jcbell1007 in forum General Bike Related
    Last Post: 10-24-11, 09:50 PM
  5. Harboir freight tire manual tire changer
    By black in forum For Sale
    Last Post: 09-22-10, 11:38 AM
