Results 1 to 23 of 23
how do you trailer you Dirtbike/ bike
    Apr 2004
    boston burbs....
    I've always seemed to have a struggle with this (except when I had a kendon)
    Not looking to buy aything new like that. Trying to update my do it all5 x 8 landscape trailer on a budget
    Have a trip to PA and bringing 2 dirtbikes
    My front always seems to slide a bit so I'm thinking this, cheap removeable but I cant find anything other than this online.
    http://https://www.speedaddicts.com/...BoCCDYQAvD_BwE
    As for the rears I've always done the ratchet strap
    like the first pic flat perpendicular to the rear wheel but also get a some wandering of the rear tire and i adjust but cant seem to get it tight enough
    i'm trying this https://www.amazon.com/MOTO4U-Univer...s%2C110&sr=8-1 but with 2 bike, a d ring in the middle.
    any suggestions appreciated... have straps more towards the rear vs perpendiculat etc..
    Id like to get some more fancy options like this.https://www.amazon.com/Risk-Racing-0...7-857e17e03685
    but not in the cards right now.
    Also cant do the bike on the hitch.. Tried it...... almost busted my rear window out taking it off, not worth the riskhow do you trailer you Dirtbike/ bike-dscn1038s-jpg
    hmmmm......
    holland ma.
    Re: how do you trailer you Dirtbike/ bike
    God lord man. Step up and get a chock for the front.
    https://www.harborfreight.com/collec...ock-69026.html
    Then e-track strips on the side.
    https://www.harborfreight.com/5-ft-h...ack-66726.html
    With coupons or a sale it can done for under a hundred. You can get a cheaper wheel chock and do it all for about 50.
    Nov 2016
    Woburn MA
    That’s almost as bad as a Harley owner’s strap job.
    I’ll look in my shed this weekend and see if I have any old chocks I can give you to help. I may have a pair that you can use. Simple HF ones.
    holland ma.
    If he was closer I would give him one of mine. I bought way to many.
    Lifer 01xj's Avatar
    CT
    I have only ever used 4 straps, one off each corner, with the soft side around something structural on the bike. Not as easy as a specialized system like pitbull but I'm not trailering bikes enough for it to matter. I have a Baxley sport chock that will stand up a bike while I secure it. Never had any issues on my 5x8 trailer. If you wanted to borrow the chock your more than welcome to it, I'm right off the highway.
    New Haven-ish, CT
    The previous owner installed two of these on my 4x8 trailer
    https://www.amazon.com/Motorsport-Pr.../dp/B071RXKDJR
    I don’t think I ever used them so I can’t give my personal input, but reviews are good.
    Kyle R (@itgbudeev) has a neat setup on his dirtbike trailer where he DIY’ed something like this
    https://m.youtube.com/watch?v=Ljx07G1enfA
    He has two strips of E-track installed on his trailer underneath the footpegs, and he has an E-track clip with a 12” long piece of flat bar steel attached to it, the bar goes through the footpegs and a cotter pin goes through a hole in the bar above the pegs to keep it in place.
    Apr 2004
    boston burbs....
    Have a couple of chocks actually. Just move a ton of stuff where they'd be in the way.
    Didn't want to keep drilling screws.
    Got to be some simple easy on/offs
    holland ma.
    Mount the chocks to a small sheet of plywood so you can drop it in and lift it out. With your v nose it will hold tight to the front if you cut it right.
    I have a couple chocks that mount to the floor with two wingnut equipped bolts so they can come in/out easily.
    They weren't expensive IIRC.
    These guys:
    https://www.amazon.com/Pit-Posse-110.../dp/B000VD5V5K
    2016 BMW S1000XR
    New Haven-ish, CT
    I use chocks with clevis pins through the trailer deck; large diameter washers on top of the chock and below the deck, and R-clips under the deck. The chock doesn’t need to be fastened super tight since the bike will still be strapped down.
    Apr 2004
    boston burbs....
    great... thx guys
    appreciate it.
    IDK why somehting this simple I'm totally whiffing on.
    hmmmm......
    Lifer 01xj's Avatar
    CT
    Yeah, I don't even secure my chock to the trailer. The weight of the bike and downward pressure from the straps holds it. I always meant to make it set up like Matt described but never got around to it.
    Commit to Pitbull TRS and never look back
    Buy it, use it and then sell it whenever later for nearly what you paid for it while enjoying the benefits in the meantime.
    If I did things over again, I would buy a cheap truck and just haul whatever bike in the bed.
    If not that, I would do Pitbull TRS on a HF trailer. The Kendon was great, but obviously it's only good for trailering bikes
    i'm building out a 5x8 enclosed v-nose right now and went with e-track on floor + AKT Fat Straps to the pegs ... similar to the Risk Lock-N-Load method of securing. you could do something similar for pretty cheap by using e-track o-rings and reg tie-downs.
    i'm not done with the mounting systems yet, need to add plates for the e-track under the floor, but it's pretty stout as is using every screw hole and no chock needed.
    also going to do either vinyl or bedliner floor and paint walls ... heading down to NC to ride next month.
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    this is what i do on my 4x8 trailer.
    Don't have a better picture right now of just the TRS but love the utility of it and being able to transfer bikes between trailers after just having more mount plates with ease
    For the car trailer I use the Grom as a pitbike or local round about vehicle when I'm trailering and don't feel like unhooking trailer.
    As you can see I wouldn't have much room for for extra straps in the tight quarters already
    I absolutely love the system and will swear by it. Never have to stop and retighten anything either and never scared of finding a bike on a side after traveling
    how do you trailer you Dirtbike/ bike-hyuczd5-jpg
    Awesome! What keeps the bikes from moving fore/aft with that setup?
    both ends of the suspension get compressed directly down just a bit, bikes are nice and sturdy. for long hauls like the trip next month, i'll throw some extra tie-downs to the e-track. pretty damn solid without though. mostly for my bike and the 65, the 50 doesn't really budge it's so light.
    i never tie a bike down with excess force or with ratchets, this setup has even less pressure on suspension. super impressed so far + crazy quick to load/unload.
    EDIT: regarding fore/aft movement, i think having the AKT straps so wide helps as well. solid mount from wide peg hold > wide strap > wide e-track mount.
    rides bikes
    Nov 2014
    I've got a HF chock you can have if you're willing to come to Salem MA and grab it.
    There are a few companies that make things like this: https://www.amazon.com/Black-Widow-M...98459994&psc=1
    I like them a lot in my pickups because you get great tie down points. Could work in your trailer too, and you could permanently mount it since it wouldn't take up much space.
    Can I see the trailer?
    It’s not usually that complicated. 2 straps per bike (maybe 3 if you want the rear secured) and 2 chocks
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    Whatever you do, make sure you flick the strap when you're done loading and say "that's not going anywhere".
    how do you trailer you Dirtbike/ bike-106575477_10158840850279406_8445756647696903759_n-jpg
    That's the key right there
