Page 1 of 4 1234 LastLast
Results 1 to 25 of 87
Loading a bike in a pick-up
    .... Manik's Avatar
    Ipswich, MA
    How easy is it to secure a bike in a pick up truck without a stand?
    I'm looking to pick up a bike in maine, 5 hours from me and will be renting a truck to do so.
    I have no experience with this and expect the dealership will help me load it.
    Do I need a stand? should the stand be bolted?
    09 Ex500- totalled
    08 SV650s!!!
    Cages: Ford Excursion
    Ford Mustang Gt
    Toyota Rav4
    Re: Loading a bike in a pick-up
    Nope it's easy. Pull the bike in straight and use tie downs that are wrapped around the bottom triple clamp so as to not damage the plastics. Or you can put the tie down around the clip on if there is room and it won't hit the plastics. Get them snug, but don't overtighten the tie downs after the bike is secure. If you do, you run the risk of damaging the fork seals. If you wish you can also run two tie downs to the passenger peg mounts to secure it on the rear as well. Again, don't crank them down too tight.
    Senior Member SVenpointsixtwo's Avatar
    Jeffersonville, VT
    You don't need a stand. Just put the side stand down and use ratchet straps around the steering head and subframe/footpeg brackets to compress the suspension against the side stand so it doesn't bounce around too much.
    ...at least, that's what I've done and I've never had an issue; I'm sure there are folks with a lot more experience and insight that will chime in!
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Lifer Dip Dungles's Avatar
    Ashland, MA
    Also depending on how long your ramps are you may need to park the truck behind a decline in the drive way. Reason for this is if you have 6 foot ramps the height can be kind of scary to load. If you park after the decline your bed will be much closer to the ground. But if yo have nice long ramps then you are golden.
    Shannon
    .... Manik's Avatar
    Ipswich, MA
    Thanks guys. Huge help. I have a place to offload it at home, and will use the dealers ramps when I'm picking it up.
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
    Life is good! gadget's Avatar
    Nov 2008
    Londonderry
    just get a couple of guys to lift it.....sorry, couldn't resist
    Sam
    Lifer JettaJayGLS's Avatar
    Tahoe City
    If you're purchasing a bike from the dealer, they will for sure help you load it into the truck...
    Mar 2004
    Lynn, MA
    Hey, Im in Danvers next town over. You can use my ramps...and I can help you unload it too. I worked at a bike shop for yeqrs and have loaded and unloaded hundreds of bikes. Let me know.
    Don't use a stand NOR the side stand! I know it sounds sketchy, but living so close to Bike Week activities I can't tell you how many times I've stopped to help knuckleheads pulled over whose bikes had fallen over BECAUSE they used side stand even though they used tie-downs. Just get the thing as squared up verticle as you can and use 2 ratcheting straps up front, two in the rear and you're good. I'd be willing to wager that the stealership will help you do it properly...
    6 Not allowed! Not allowed!
    .... Manik's Avatar
    Ipswich, MA
    Thanks! Will do.
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
    .... Manik's Avatar
    Ipswich, MA
    This would be a great help. Thanks! I'm hoping to pick it up on saturday, at the very least ill radio your knowledge.
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Lotsa good advice here. On the tightening of straps be careful. Christian mentioned this, but it is worth repeating. You want the suspension partially, not fully compressed. Give it room to bounce with bumps without bottoming out, but put enough pressure so that the wheels aren't "bouncing around".
    Get it as straight up and down as possible.
    Plan a stop 10-20 minutes after leaving. Just check the straps, make sure things aren't moving around. After that you should be pretty much good to go.
    Congrats on the new bike.
    yer compressing springs, not oil
    as you compress springs, oil moves from one side of the valves to the other just like sitting on it and riding or adjusting preload, seals are no more likley to blow than when you ride it
    the only problem with compressing too much is weak tie downs or weak tie down points
    .... Manik's Avatar
    Ipswich, MA
    Thanks guys. Will do. Appreciate all the help!
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
    When I sold my last the buyer and 2 friends wheeled it up into the bed of a fullsize 4x4 pickup. I was shocked how easily it went in with extra hands.
    Compress the forks enough so it doesn't bounce around, but do not bottom the forks out, as that will ruin the seals, as indicated.
    Do not use the hooks on the tie downs, but rather pass the loops through the eye of the hook. This way the ends wont' come off as easy.
    I tie off to the grips on my non-sport bike (which has bars, not clipons). Some say that's instant death by fire, but I've lived so far.
    This guy has it down:
    Nice VFR too...
    So there is no compression of the air gap and no extra pressure when compressed? You sure?
    no more than when yer riding it, and your also not hitting abrupt potholes
    as I said, the biggest danger of compressing too much is breaking straps or pulling tie down hooks out of the truck bed
    I always recommend sitting on bike, snug straps, get off bike
    Explain the fork fluid all over the back of my truck last time I tied it down back there?
    Nov 2008
    Londonderry
    maybe you drive so badly that you scared it into pissing itself... (just kidding.... )
    Sam
    Nice VFR too...
    mother f'r!!!
    I've tried this many times....the moment it gets up the ramp one of 3 things have happened to me:
    1.) the bike gets too much gas and shoots into the front of the bed, and crashes sideways
    2.) the bike gets too much gas (or clutch popped), ramp shot out from underneath me, and crashed off the end of the bed
    3.) the bike doesn't get enough momentum, stops halfway, and falls off the side and crashes
    I found the best way is - bike off, have one (or two people) behind the truck push, and one person on the front steering it in.
    I'm almost tempted to ride it up though...wide center ramp (tied down to the tailgate), and paddle walking it with two more ramps on the side seems most natural to me
    Super-Dooper User ɹǝʍoןandɹǝʍoן's Avatar
    Salem NH
    hey I was just wondering OP how did your first bike get totaled? my friend dropped his off the ride up to the bed of a truck! and it was pretty hurt...
    current: 06 zx6r, 03 450exc
    sold: 01 gsxr750, 01 RC51, 96 cr500, 98 superhawk, 00 sv650, 78 cb750, 98 dr350, 74 cb125
    you had leaky seals to begin with
    This guy is good.
    mother f'r!!!
    Note the strap holding the ramp in place. That keeps the ramp from moving on you, which is part of the battle.
    Me, I'm such a klutz I'd trip over myself and do a face plant into the tailgate.
    It helps that doode must be 7'8" or something. Stepping up into the bed of a 4WD Tundra like that.
    exactly! m-f'r!!!
    dirt bikes on the other hand, I'll do day and night...and ride out the truck without a ramp...and drop on purpose and just laugh when all I need is a clutch lever
  1. Replies: 22
    Last Post: 04-16-13, 12:47 PM
  2. FS: alum. bike loading ramp
    By jc r6 in forum For Sale
    Last Post: 10-30-08, 09:56 AM
  3. loading bike w' 3 ramps?
    Last Post: 11-16-07, 08:45 PM
  4. Truck ramps for bike loading?
    By Honclfibr in forum General Bike Related
    Last Post: 02-02-05, 05:48 PM
