Results 51 to 75 of 87
Loading a bike in a pick-up
  1. #51
    Re: Loading a bike in a pick-up
    Quote Originally Posted by Manik View Post
    Going to have to buy one of these in the future. looks good.
    Gotcha, guess i was thinking that in my situation i dont want the tire up against the bed because the truck is a rental..
    It's a truck not a show vehicle. Go fer it dude!
    I am Dead now
    Oct 2009
    The tax State of the Nation
    Only the ones I bought from Advance Auto stretch, so no problems for anyone else on this forum then I guess.
    tie downs that stretch when wet ? none that I have ever seen
    .... Manik's Avatar
    Ipswich, MA
    dude...this chock discussion is epic
    this is the epitome of what it means to have a forum discussion
    And this is the epitomy of a side conversation. (this comment included)
    09 Ex500- totalled
    08 SV650s!!!
    Cages: Ford Excursion
    Ford Mustang Gt
    Toyota Rav4
  4. #54
    .... Manik's Avatar
    Ipswich, MA
    I see your logic, and raise you unnecessary concern.
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
  5. #55
    Can you throw an old towel or rag between the tire and the truck bed? Would that work?
    I use a stake side utility trailer now and then. I usually lash the front wheel to the front wall of the trailer. Bringing the V-Strom home I went so far as to lash a 2x4 vertically to the front of the trailer and lash to that.. effectively the same thing as a wheel chock. I'd use deck screws to do that semi permanently, but the trailer isn't mine.
    I also used a total of 6 straps on the bike like a paranoid fool. Finding points to lash to on an 'adventure' bike with crash bars is trivial.
    Bike didn't move an inch though.
  6. #56
    .... Manik's Avatar
    Ipswich, MA
    I'm bringing up 6 tie downs. Will I use them all? Who knows. I was planning to cover some of the plastics anyway with towel.. Ill bring a few and see how well I can secure one between bike and truck.
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
  7. #57
    .... Manik's Avatar
    Ipswich, MA
    On a similar note, is the rear seat handle a good tie down point? Will it be strong enough?
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
  8. #58
    Just Registered drop's Avatar
    Bradford, MA
    i use the passenger peg brackets on mine, which you may or may not be able to use (or even have).
    - Jamie
    2009 K 1300 S
  9. #59
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Quote Originally Posted by drop View Post
    Yea, peg brackets are better if you have them. Passenger grab handles could rub finish off depending on the material of them (most are some sort of "grainy" plastic). Metal frame like bits are the best if you can get to them. Grab handles should be strong enough if you can't get to anything else, but I'd wrap them with a towel or something first.
    Mar 2004
    Lynn, MA
    Canynon Dancer handelbar strap and 2 more on the rear passenger pegs is all you need for straps.
    Like I said Ive loaded and unloaded many many bikes and I have ramps. Im heading to CT sat morning but if you want I canhelp you unload sat night or sunday morning. Send a pm if you need me.
    Careful with Canyon Dancers, especially on Ducs... the like to strip the throttle off the bar, breaking the locating pin in the housing.
    The passenger grab handle on my bike is part of the rear parcel shelf, which is all bolted to the rear frame in several places. Not to the body. Although I thought most bike's grab handles were bolted to the frame.
    On a sport bike I might put a loop through the rear wheel to keep the rear from moving around instead. I've seen that done successfully.
    .... Manik's Avatar
    Ipswich, MA
    Dont have a canyon dancer strap, but ill look into them for the future. I'm going to go with one strap outer clipon and then two more at the rear pegs.
    Appreciate the offer jwm2k3.
    I have a concrete pad in my back yard which should be the same hight as the truck bed, ill use two 3/4 inch plywood boards to walk on roll the bike right off.
    Again my pickup was delayed by a week and is next friday now.
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
  14. #64
    .... Manik's Avatar
    Ipswich, MA
    Picking up this bike tomorrow. Should 6ft bed, 6'8" bike.
    Should i leave the tailgate open, or kiddie corner the bike?
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
  15. #65
    I would not worry about leaving the gate down... IMO.
    Westford, MA
    Yeah, you can leave the gate open.
    Just remember to bring your straps! Or else this'll happen to ya.
    Mar 2012
    Chichester, NH
    Is the wheelbase 6'8" or the bike? Bike, you're prolly ok.
    Wheelbase, buy an 8' 2"x10" and put under it to be safe.
    You'll prolly be fine without the 2x, but technically the gate isn't rated for this.
    .... Manik's Avatar
    Ipswich, MA
    Length. Wheel base is 58 inches
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
  19. #69
    Mar 2012
    Chichester, NH
    You'll be fine. Leave the gate down and roll.
    I am Dead now
    Oct 2009
    The tailgate is rated for at least 500 Lbs.
    Mar 2012
    Chichester, NH
    Technically the tailgate isn't rated at all. What will it hold is a different question and depends on how adverse you are to risk .
    http://www.discountramps.com/article...ate-cables.htm
    Quote Originally Posted by Rossco View Post
    That bike looks better on it's side. .
    okay, so I want to make loading a 1995 FZR600 into a lifted 2001 F150...
    and I saw this: winch assisted motorcycle loading:
    http://www.youtube.com/watch?v=znM7ZPONGow
    cliff notes: buy a 2000lb winch from harbor freight for $60, a soft loop strap from harbor freight for $10, let the winch pull your bike as you slowly guide it
    I want to do this, except I would put the winch on the floor of the bed so I can still use my bed cover...any problem with a winch cable dragging against a tailgate?
    would the cable fray and break?
    edit: I also don't see a $60 winch....cheapest is $80 for the 2000lb winch, and a separate wireless control is around $25 bucks on newegg
    good? bad? genius?
    Ashford, CT
    I've got a wide folding arched aluminum ramp and just ride the bike into the truck. I have loaded my Daytona into my 2500 Ram and never bottomed it out. The ramp gets used for a lot of other things also.
    Jeff
  25. #75
    Jan 2009
    Middletown, Ct.
    good? bad? genius?
    No need to worry about a metal rope. Use a synthetic line.
    http://www.amazon.com/WARN-73599-Syn...tic+winch+rope
    But seriously, just put the bike in gear and ride the clutch as you walk next to the bike.
  1. Replies: 22
    Last Post: 04-16-13, 12:47 PM
  2. FS: alum. bike loading ramp
    By jc r6 in forum For Sale
    Last Post: 10-30-08, 09:56 AM
  3. loading bike w' 3 ramps?
    Last Post: 11-16-07, 08:45 PM
  4. Truck ramps for bike loading?
    By Honclfibr in forum General Bike Related
    Last Post: 02-02-05, 05:48 PM
