Results 1 to 25 of 35
Looking for steel braided brake lines
    Any recommendations for brake lines for my CBR?
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Happy with Spieglers
    You also may think about going direct to each caliper from the master instead of a cross over hose, if you have one
    Bleed bleed bleed ... wait 2 weeks bleed some more.
    Glen Beck is John the Baptist
    Lifer union's Avatar
    Blackstone, MA
    I think most aftermarket braided lines are ment to go direct instead of through the cross over. Might as well do the rear while youre at it too.
    James
    I had planned on it. I'll be needing new front pads, so I'll probably do all of it at once.
    I found Gafler lines, here:
    Gafler Stainless Steel Brake Lines . How are they compared to Spiegler?
    Blackstone, MA
    People I know that used Gafler have been happy with them. Not that Ive heard anything bad about Spiegler either. I also have my clutch done as well. Some people might say its a bit overkill but if you have the extra money might as well get that done too if you have a hydrolic clutch. If you want to see my setup let me know. I dont think Im too far from you , maybe 30min.
    As for brake pads. Im running Vesrahs right now. They work great.
    As Ive said in a couple of threads I purchase most of my stuff from Brian Van at www.sportbiketrackgear.com. Hes a very easy guy to deal with and he wont sell you something that you dont need.
    James
    .... duey's Avatar
    Wilmington MA
    lines on my SV are Galfer, with ebc pads (which i'm changing soon).
    2021 Ducati Panigale V2
    2020 Honda Grom
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Keep in mind that if you do the rear, you run the risk of locking up the rear more because of the increased braking power.
    Blackstone, MA
    hmm never had that problem. The rear shouldnt get a lot of use anyway let alone get stomped on enough to lock up. I suppose if you really had to stop fast like say something was in your way I guess its possible but even when I have stood on the rear brake it never locked on me.
    James
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    is there fluid in your rear brake line?
    its SO easy to lock up the rear
    Blackstone, MA
    Yep freshly changed too. Even brakepads in the real caliper. Ive seen my rear lock up once and it was when the dude inspecting my bike decided to take it for a ride around the parking lot. And then he blamed me for the patch in my tire that he made.
    Like I said Ive never locked up my rear. It is used sparingly but I have yet to lock it.
    James
    Central VT
    +1 on the Galfer lines.
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    there is no increase in braking power with stainless steel lines, only a difference in feel
    braking power is determined by the area and material in your pads
    there really isn't that much differnece in feel either unless your comparing to old rubber lines
    Aug 2004
    Baltic,CT
    I always nag about solvent cleaning your rotors of road spooge. Best way to return 1 finger braking.
    People have been known to play with rear brakes to prevent lock up including deliberately not bleeding them well.
    I got stainless line to increase the length when I put on my ape hangers. I still used the crossover.
    Spiegler will come with a little wrench that allows you to rotate the banjo if need be I don't know that from gaffer..
    Lifer Punjistick's Avatar
    Norwell, MA
    +1
    I might actually let some air in my rear as it seems to be locking all the time when I brake.
    Mar 2003
    Lee, MA
    i disagree ... the pressure you apply is all going into the calipers instead of expanding the rubber lines and going into the calipers ... that should have some effect on the force of braking.
    Lifer Evil_Weasel's Avatar
    Over the Highside
    exactly with steel lines you get the same power with less lever travel, or more power for the same amount of lever travel.... however you prefer to look at it.
    anyways i've used mostly gaffler stuff in the past... loved their lines, pads, and rotors. i think the NSR has EBC pads and goodrich lines...no complaints there either.
    personally i like a crisp and effective rear brake, some people don't...depends on riding style i guess. i use the rear for things other than just stopping though. like keeping the front down when cresting hills hard on the gas.
    1000psi hydraulic force is 1000psi force regardless of type of lines
    the only way to get more braking force out of the potential of your master cylinder is to change the area or material of your pads
    again, lines don't change the amount of force, maybe travel, but that's not force
    disabling the rear brake by admitting air into the system is STUPID btw
    learn to use brakes properly
    Lifer LuvDog's Avatar
    Ashland, MA
    I've got Spiegler brake lines on my 7R.
    Wolford brake lines and Galfer clutch line on my 916.
    I don't notice ANY increased tendency to lock up the rear wheel with the SS verus the old rubber.
    With both bikes I went away from the cross over front and went with the double banjo direct line to each caliper.
    2003 ZX7R
    1995 916
    Jun 2005
    HEL brakelines use stainless fittings, FWIW...
    This is what happens when you use AL fittings and stainless lines:
    Electrolytic corrosion, yo, electrolytic corrosion... Most metals don't play well together in the presence of a liquid... even those that don't rust.
    HEL USA website
    Blackstone, MA
    +1 to this. The time you need your rear the most is when the sir bubble will come back to haunt you.
    As I said I have had 0 issues with locking my rear. Can it happen? Sure it can the tard that decided to ride my bike around the parking lot durning the inspection did it. You can lock the rear with the stock lines. Its all in weight transfer and how you apply the brake. If you just stomp on it while having the fronts pinned down youre going to lock it up. If you brake properly you shouldnt have an issue especially on the street.
    James
    Randy's right. Force is force. The difference in steel brake lines is feel, which is VERY important in performance riding. I'm not with Randy on the rear brake thing, though. I believe there is never a need for rear brake on a modern bike unless you are backing it in or trying to settle the rear suspension. In both of those cases, you need very very little rear brake. I run with a bubble in my rear brakes for that reason (to get more play so the brakes engage slower).
    Jun 2005
    that's an interesting idea... does it ever work it's way back into the reservoir and firm up again?
    My current sole use for rear brake to keep from rolling backwards at stoplights... that's about it... well, that and reigning in the ocasssional wheelie about to loop... not that I ever wheelie
    modern bike.... sure if it's got the latest in suspension,
    I have a SV, using the front brake only with stock suspension is asking for disaster, but with proper application of front AND rear, the suspension settles evenly and you stop quicker
    and as you know Degs, I only use my brakes when I am stopping
    I actually prefer a drum brake in rear on my XV, it has solid linkage to the shoes, I have no problem locking the rear if I want to and it's much easier to modulate the drum/shoe without locking
    Feb 2006
    Metro West, MA
    Union,
    Keep in mind you have a pretty heavy bike so it's probably harder to lock up your rear.
    On my F4 I was always locking up my rear even with the slightest touch (with the SS lines). It got to the point where I just didn't use it no more. Before when they were the OEM rubber lines, I never locked them up.
    Blackstone, MA
    Union,
    Ya its a bit heavy. Listed as 439lbs dry stock. Mine has been on a bit of the diet so Id say more in the 415-420ish dryarea. Most of the weight came off the ass end in forms on pipe(big loss), under tail and a new link which are much smaller losses but as still losses in weight. Id say both sides of my satos weight less then one side of the stock exhaust. Add in the about 6lbs per gallon up front in the tank so thats another 30lbs closer to the front wheel.
    The brakes do lock up and if you have little feel for the brakes you can lock them easily especially when all the weight is transfered to the front end when actually braking. Its a feel thing and I have yet to experience the rear locking up on me but I dont stand on the rear brake and like most sportbikes I really dont need to use it often at all. I dont have to put much pressure on the rear to get them to do their job.
    You can run an air bubble in the hose like Degsy but its not something I would do unless it was a track only bike and even then I doubt I would do it. Just when you need them to stop the most it will come back and bite you in the ass.
    James
  1. Steel brake lines on 07 CBR600rr?
    By TTD in forum General Bike Related
    Last Post: 04-23-11, 09:07 PM
  2. FS: Steel Braided Brake Lines Goodridge $40
    By Crash Dummy Denno in forum For Sale
    Last Post: 01-04-10, 07:32 PM
  3. Braided brake lines..
    By toocrazy2yoo in forum Bike Maintenance
    Last Post: 05-30-09, 03:10 PM
  4. Repair steel-braided lines?
    By zx-stewie in forum Bike Maintenance
    Last Post: 04-14-02, 06:33 PM
