Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
looking track prep advice
    Feb 2011
    Somerville MA
    Re: looking track prep advice
    There is some racing component to this whole NESBC thing though, right? That would necessitate warmers.
    Yeah, the NESBC angle is (as I understand it) a mini race series tacked onto the end of a track day. There are a couple classes for non-racers, with relaxed tech requirements compared to novice/am LRRS/CCS tech. The NESBC "teams" are also designed to match up noobs with more experienced nov/am racers with an expert "coach." Sounds like an awesome way to get better, not least because competition should help push me to lean over further and stay on the gas longer.
    -Jared
    Haverhill, MA
    90 minutes is plenty close enough. Thanks.
    If you are in Somerville then Seacoast is not an hour and a half from you unless you are talking round trip and yes it is worth the trip.
    Sinking firm lever while holding brakes is an internal master leak IF there is no external line/caliper leak. All the fancy fluid/bleeding/bling pads/braided lines/resurfaced rotors won't fix it.
    Floating/warped rotors can knock the pads back in when conditions are right, which will give the same "Oh shit" feeling as the first pump fails to produce stopping power.
    Ahhh if you're doing racing then I'd invest in warmers for sure.
    Feb 2011
    Somerville MA
    First pump is always fine with good initial bite; my concern is sustained pressure after the first full second or so.
    -Jared
    Branford CT
    Sent you a pm for some sv stuff,, don't know if you got it or not, my phone sucks.
    #277
    Oooh, yeah, refer to Doug's comment then. You could always send the master to Acosatto for an eval/repair/rebuild?
    Mar 2004
    Lynn, MA
    Riverside Ducati has Dainese and RevIt suits in stock last time I was there. Bought my Dainese from them!
    Feb 2011
    Somerville MA
    Put the back protector and shoulder pads back into the Vanson hybrid, but omitted the giant foam aero hump. Noticeably more comfortable both upright and crouched. Strike one big expense off the list.
    -Jared
    go faster cdovego's Avatar
    Weymouth
    Shave the bottom side (where it touches your back) of the foam aero hump down a little
    Central Mass Powersports #123
    I'm told the hump can provide some protection from some neck injuries. Maybe worth trying to make work. Maybe not entirely "silly".
    I think I'd be shopping a hit-air vest though.
    Feb 2011
    Somerville MA
    Something like this?
    Race/Track vest: SaferMoto Hit-Air Jackets and Vests
    If it works worn over the existing suit, I'm interested.
    -Jared
    Yes, like that. Seeing them more and more with LRRS and @ track days. Seems more flexible than the Leatt brace route I went. More comfortable too. Just more expensive. Probably a wash in terms of protection.
    But if I were doing it over again, that's the route I'd go.
    Feb 2011
    Somerville MA
    The time and cost to acquire/service/replace seems a lot more reasonable than the airbag-equipped suits. They really need to beef up their online product descriptions and documentation though. A $500 piece of safety equipment should have a PDF manual online imo.
    -Jared
    Want to switch to Motul for the Tiger 1050. What product? 7100?
  1. track prep for a Husky 701?
    By feralchimp in forum General Bike Related
    Last Post: 04-10-18, 01:44 PM
  2. track day prep Q's
    By aneweira in forum General Track Day Talk
    Last Post: 11-28-09, 11:50 PM
  3. track day prep
    By black in forum General Bike Related
    Last Post: 07-12-05, 04:39 PM
  4. Track day prep.
    By Jank in forum General Bike Related
    Last Post: 05-15-03, 08:50 PM
