Results 1 to 25 of 45
Tying a bike down with no wheel chock
    Lifer Pittenger5's Avatar
    Austin
    Thinking of jamming a bike or two in our moving van if space allows so I have less weight in the trailer. Problem is I obviously wont have a wheel chock. Was thinking of a 4 point tie down, 2 on the front forks and 2 off the rear subframe or something. Is that going to hold the bike for the trip? Or can the wheel still move around without a chock holding it in place?
    Zip Tie Alley #505
    Waterbury, VT
    Re: Tying a bike down with no wheel chock
    If the van has a plywood floor - place the front wheel against a wall, screw 2x4 scraps to the floor parallel to the wheel to help out.
    SSearchVT
    Lifer Expat's Avatar
    Mar 2007
    Or use a 2' x 2' piece of 1/2" ply with 2' x 4" pieces the width of the front tire screwed from underneath. The weight of the bike will hold it in place and the 2x4's will stop the front wheel from sliding sideways. I would still use 4 straps though.
    Lifer 03Worc9R's Avatar
    Worcester, MA
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    When I transport in my truck I never use a chock. Just strap it against the front of the truck bed. Never once had a problem.
    Austin
    No way to screw anything into the floor.
    Zip Tie Alley #505
    Austin
    I usually do this as well, not sure how well Ill be able to get it against a wall though, depends on how the tie downs are situated.
    Zip Tie Alley #505
    Been trailering my bikes for almost 20 years without a wheel chock... 2 tie downs pull forward and 2 pull rearward.
    Any one can let go and the bike will stay up, if done right.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Lifer ThisBitch's Avatar
    Tucson, AZ
    Make sure you cover the bikes in blankets. We moved mine in the moving truck and put a nice gouge in the tank paint because it ended up rubbing on something that shifted during the move.
    Original
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Moving van or actual moving truck? I brought 5 bikes across country in a 26' moving box truck. They were all in there 'sideways' with 4 tie downs per bike, covered with blankets.
    Austin
    POD situation.
    Zip Tie Alley #505
    Waterbury, VT
    There's always a way... It's just a question of how creative you want to get!
    SSearchVT
    Tucson, AZ
    POD situation.
    Do they still lift those onto the trucks with cranes or is there a different way?
    Original
    Austin
    Cranes I guess, I dunno, its not here yet.
    Zip Tie Alley #505
    Lifer DuncanMoto's Avatar
    Some PODS have a special new flatbed that delivers and picks up the pods perfectly straight.
    Dec 2003
    Ma
    You can probably just get a couple of guys to lift it up.
    Senior Member JalopySiR's Avatar
    Dec 2008
    Charleston, SC
    I'm in a similar situation, and have decided to build myself a "pallet" type thingy.
    I'm thinkin' a 2x4 on either side of the wheels screwed to two 2x4 cross beams. Sorta like a double ended cross, with one cross beam in front of the front wheel and the other behind the rear wheel. The ends of the cross beams will have the D or O ring screws in em'. Sprinkle liberally with 4 tie downs.
    I'll be doing it to 3 bikes, so I may bolt em all together so it doesn't move at all.
    2002 RVT1000R
    1998 VFR800Fi
    2002 CR80RB
    Tucson, AZ
    In the case of a Pod where you won't see it or be in control of it, I think the plywood and 2x4 method in expat's photo is probably your best option. I'd be a little sketched out about just letting someone drive off with the bikes no matter how securely they are in there.
    Also, check with Pods, I don't know if they inspect the contents of them before picking them up and loading them, but I was told by them that I couldn't move a motorcycle in it because it was considered combustible material, even with the gas tank emptied.
    Original
    Austin
    Probably mexicans from Home Depot. No Americans want to do that job.
    Zip Tie Alley #505
    Austin
    Shit, youre right. Hmm, well that sucks. Not sure what I will do now.
    Zip Tie Alley #505
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Get a shipping company? It won't be horribly expensive to ship from MIA to Texas
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    I found renting a box truck / car trailer a cheaper option than PODs.
    Austin
    I looked into this, wasnt a LOT cheaper, and doing that would mean Leeza and I would both have to drive. We both HATE driving that much, so with the Pod we can at least take 1 car and split up the driving.
    Zip Tie Alley #505
    Dec 2003
    Ma
    You can likely buy a box truck that will get you and your stuff there for cheaper than renting a pod, then make all or most of your money back. Some hassle, but you're broke and jobless aren't you, so you have time?
    Austin
    Negative and negative. And like I say, the extra money a pod costs (not too much more) is worth it so we can split driving duties.
    Zip Tie Alley #505
  1. For Sale - Parts & Tools | Wheel Chock
    By DucatiGuy in forum For Sale
    Last Post: 06-29-20, 02:39 PM
  2. Wheel Chock
    By Half Squid in forum Wanted
    Last Post: 09-13-12, 05:34 AM
  3. Wheel chock
    By j4eric in forum Wanted
    Last Post: 08-15-11, 10:15 AM
  4. Tip for tying down bike in truck bed.
    Last Post: 11-09-07, 05:33 PM
  5. Wheel Chock
    By Rye in forum General Bike Related
    Last Post: 06-25-06, 07:17 PM
