I have about 1000 miles so far on the MOSFET voltage regulator I upgraded to on my V-strom
with the oem SCR type regulator on my V-strom, voltage fluctuated from 13v-15v depending on how much electrics I had turned on, cooling fins on the regulator got so hot you couldn't touch them
wet the MOSFET regulator, my voltmeter stays consistently at 14.5 and thecooling fins are barely warm to the touch
and it was actually less expensive than the oem
the oem RR for the V-strom is only rated at 30 amps, and the Shindengen MOSFET FH012AA is rated at 50 amps
