Results 1 to 3 of 3
Motorcycle inspection requirements
    So, my wife is on a ninja 250, that well....lets say its fucked up pretty bad. All the front fairings are off of it, and i have installed LED blinkers. The mirrors are there and all the lights work. As do the brakes. What does she need to pass inspection? She was sent away from a shop because they said she had to put the original fairing on...That's not happening as I don't have a fairing for it(was in a crash at some point in the past and was trash).
    What can I do here?
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    Re: Motorcycle inspection requirements
    Pm sent
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Motorcycle inspections are defined starting on page 23 of this document. They can probably fail you on the LED blinkers (they probably don't have SAE stamped on them) and other things, but I don't see anything about original fairings in the procedure.
    Here's the complete section on Body Components. The bold text is the key section.
    (12) Body Components.
    (a) Fenders. Front and rear fenders shall be mounted over both wheels to adequately protect
    rider from road debris and water. All fenders shall cover the width of the tire and a minimum of
    1/4 of a wheel circumference. Reject the motorcycle if fenders come in contact with tires or if
    fenders have sharp edges.
    (b) Exterior Sheet Metal, Moldings and Body Panels. Reject motorcycle if there are sharp edges or
    abnormal protrusions extending beyond normal vehicle extremities so as to constitute a danger to
    pedestrians, rider, passenger or other vehicular traffic. Safety bars or highway bars without sharp
    protrusions and which do not extend beyond the widest portion of the motorcycle and which are
    not further than 15 inches from the foot controls are permitted
    (c) Seats. Each rider shall have a firmly secured seating area. Reject motorcycle if:
    1. Seats are not properly secured or have springs or parts protruding which constitute a
    hazard.
    2. Foot rests for each designated seating position are not provided.
    (d) Chain Driven Motorcycle. Rotate chain to locate tightest position. Inspect chain under
    simulated road condition and reject if:
    1. Not Adjusted to Manufacturers Specifications. If specifications are unavailable the
    following shall apply:
    Rigid frame models: minimum 1/2 inch to maximum one inch total up and down
    movement measured on the lower section of the chain midway between the sprockets.
    Swing arm models: minimum 1/2 inch to maximum two inches total up and down
    2. The chain guard or other covering device is missing, broken, cracked or is not the original
    equipment or equivalent replacement.
    3. Chain or sprockets are excessively worn.
    (e) Side or Center Stand. Inspect and reject if:
    1. The side or center stand will not remain in the stored position.
    2. The side or center stand is cracked, broken or apparent structural weakness is present
    which would not allow the stand to support the motorcycle.
    DanG
    - Blaise Pascal
  1. NH Inspection Requirements
    By SRTie4k in forum General Bike Related
    Last Post: 06-27-14, 09:39 AM
  2. Motorcycle inspection in Maine
    By drowe531 in forum Bike Maintenance
    Last Post: 09-09-13, 10:31 PM
  3. MA Motorcycle Inspection Rules
    By oVTo in forum Bike Maintenance
    Last Post: 05-15-13, 11:54 PM
  4. Motorcycle Inspection North Shore MA
    By flatline in forum General Bike Related
    Last Post: 05-27-10, 11:22 PM
  5. Motorcycle Inspection In CT?
    By RupturedDust in forum General Bike Related
    Last Post: 09-08-08, 06:55 AM
