Results 1 to 4 of 4
Ninja 250 running issue
    Lifer Danz19899's Avatar
    Grafton, Ma
    Alright I helped a friend of mine find her first bike, ended up getting a used 2012 Ninja 250.
    Shes complained about it for a while but I never experianced the issue until yesterday so i though it was rider error (oops) Intermitently it will start idle fine but if you give it any throttle at all it dies almost instantly.
    If you put the choke on it will run fine, once warmed up on the choke for a few minuted the issue goes away. Funny thing is it happens randomly, I experianced it yesterday when it was 95 degrees out, let the bike idle for 30 seconds and it still would die.
    I'm pretty sure its a carb issue of some sort but I know very little about them
    Looking for a few ideas as to what to check out first.
    www.bostonmoto.com
    Ride to live, live to ride
    Member Gman021's Avatar
    Oct 2013
    Wakefield, MA and Storrs, CT
    Re: Ninja 250 running issue
    Maybe the pilot jets or another area of the carb? My 01 had similar issues. Sounds like it needs a hydrosonic clean.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    jets are plugged or partially plugged. Common issues with small jets and Ninja 250's Clean the carbs and it should be all set.
    Posted by Jane in BoxChat
    Senior Member BMMCBR's Avatar
    CT, USA
    Had the same issue with my girlfriend's 250. Carbs were gummed to shit. Use an old guitar string or safety wire to get the really tiny jets. Just make sure the end of the wire isn't sharp. You can damage the metal that way.
  1. For Sale - Motorcycles | 2008 Kawasaki Ninja 250r - Currently not running
    By drowe531 in forum For Sale
    Last Post: 11-05-21, 09:00 PM
  2. Replies: 0
    Last Post: 06-14-16, 05:13 PM
  3. Got it running, throttle/idle issue
    By Gman021 in forum Bike Maintenance
    Last Post: 05-15-15, 05:04 AM
  4. 2007 kawasaki ninja zx6r - running too hot reaching highest temp
    By EASTCOAST_NC in forum Bike Maintenance
    Last Post: 10-06-12, 10:01 AM
