Results 1 to 9 of 9
ok i need some help.
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    i cant get the 50 to start.
    i think the problem is the new, bigger, carb. It has spark. Gas and air is getting into the carb. Its just not starting. I am 99% sure the ignition is fully wired properly.
    my leg is tired of kicking starting it.
    the only paperwork that came with the new carb is in japanese.
    anyone free today that knows carbs real well?
    i have new points and condenser for it too, but i didn't put them in cause its sparking nice and bright, so i am guessing the ignition is working properly? is this poor judgement?
    Brent LRRS #772
    2006 KTM 560 SMR
    "aaah!" Matt K's Avatar
    Oct 2002
    Acton MA
    does the 50 have an automatic fuel petcock? Sometimes if you get real big carbs the vacuum pressure isn't enough to open the automatic ones... I'm not a huge carb expert, so that's about all I can think of, aside from the carbs not being set up right, but if that's the case, I'm not much help good luck.
    "Balls," I said. "Never mind the track. The track is for punks. We are Road People. We are Cafe Racers."
    - Hunter S Thompson
    2 x 82 GS 650, '94 RM 80
    Newbie
    Sep 2002
    southern NH
    I'm not exactly sure how those are put together, but this might help. Check to make sure ignition timing is right, should fire approximately 2mm (.080) before top of compression stroke. Check compression, a finger over plug hole will tell a lot, gage is better. Make sure fuel is getting to carb, pulling the fuel line at the carb is probably the easiest way to check. Also check idle screw setting, usually 1-2 turns out from fully (lightly) seated. Is it a mikuni? Did you take anything apart? If petcock has two lines it is probably vacuum operated. Try using prime setting if it has one.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    put a few drops of gas in da cil.
    see if she kicks
    Mar 2002
    Amherst, NH
    the carb is a new one from kitaco racing, its actually a keihin 20mm. the stock one is 13mm
    i checked.... its getting plenty o'gas.
    i tried ether right into the cylinder to bybass the carb, but still no go, that really surprised me, i thought that should have ignited.
    i checked the timing as best i could, it looks right.
    there is spark when i pull the plug out and check it, but it seems like its not sparking when i reinstall it.
    i checked for compression, i dont have a guage but its air in just fine and definitely pressurizing the cylinder.
    so it would lead me to beilieve it might be sparking on the wrong stroke or something like that.
    i dont know. next thing for me, i am thinking i will pull apart the generator/alternator and install teh new condenser and points and verify the timing so i am 100% sure thats not the problem.
    Brent LRRS #772
    2006 KTM 560 SMR
    May 2002
    Meriden CT
    you got spark gas comp. fucking thing should kick
    re check your timimg you got nice blue spark ???
    Mar 2002
    Amherst, NH
    I Won't disagree with ya!
    Know where he's hiding these days?
    Brent LRRS #772
    2006 KTM 560 SMR
    Newbie
    Sep 2002
    southern NH
    180 degrees off, is kinda what I was thinking, just not sure if its possible. I've been messing with an XL125 flat tracker. Think maybe all these "H" things are sorta the same. Overly conflagritated for something that should be real simple.
    Northshore/Beverly, MA
    Hey! I'm here....now and then....
    send me an EMail, and lets see what we can do...
    The wife and I are back together, but I don't want to make too many waves! LOL
