I sat on a few NT700v's. No way that bike is worth anything close to $10k. Not in my eye. Salesman actually agreed. And he had a marked down demo. On paper it sounds perfect. In the flesh it isn't. I can't even put my finger on what I don't like about it, it's just the package. I'd forever be kicking myself for not buying a lightly used ST1300 instead.
I've been following the speculation thread on stromtrooper.com. Anyone see this being such a scorching announcement that existing owners rush to dump their bikes... or dealers their inventory? Otherwise I am not sure I care, personally.
I guess we'll see; I am not exactly acting fast here.
The only thing of interest I could see them doing is adding a shaft drive. But that would drive up costs. The appeal of this thing is that it is cheap 'n easy.
I have to admit: I want to use this thing 'wrong'. So improvements for off-highway use do not appeal to me at all. I could care less about spoke wheels and improved ground clearance. Almost the opposite in fact. I am definitely not their target buyer. In fact the 19" front almost drove me to Kawasaki.
I've half been stalling until after bike week to see if used selection goes up and prices go down... or if that doesn't happen until September. It's been a long while since I've shopped for a bike.
That said, chains aren't really that bad, are they?
I've never had a bike with anything but a chain.
Meh, grow a set!
Yeah, I see that. On the other hand, I'll take a chain drive if it means a thou or two shaved off the MSRP.
Every 300 miles. Gebus, what do you do to those chains?!
Speaking of chain service. Turnoff for the Kawi Versys: Chain drive + no centerstand, even from the aftermarket thanks to the under-it all exhaust routing. WTF were they thinking.
Now, you can keep asking these questions here for the 10 of us to answer, or you can just go read the 50 existing threads on each of these subjects on stromtrooper.....
The new 800's from BMW and Triumph are using chains. BMW has created a lot of new chain enthusiasts, one reason why about 50% of V-Strom owners are former BMW owners. Super Tenere has a shaft - got $14K?
Keep in mind that a chain on a 65hp V-Strom is a lot different than a chain on a 1000cc sportbike - literally 1/2 to 1/3rd the HP. Also, most people put a center stand on a V-Strom while sport bike riders only have a side stand.
V-Strom riders usually get 15-20,000 miles on a chain, some as much as 40,000.
Maintenance is absolutely trivial. I keep a can of lube in my pannier. Every other tank of gas is roughly 500 miles, so at that time I go to the back of the bike and spray the rear sprocket and links - I colored one of the links orange so I know when I've gone all the way around. I never clean it nor do most other V-Strom riders: cleaning doesn't seem to adversely affect life. The new dry lubes and waxes don't pick up much dirt anyway so there wouldn't be all that much cleaning to do.
CN: chain maintenance consumes approximately 100 seconds per week.
They were thinking that it is a standard that competes (not very successfully) with the SV650. SV650 versus Versys.
Even easier?
Scottoiler. Just upgraded mine to the dual nozzle.
I give the reservior a fill every 500-700 miles. That's it. Chain is happy, I'm happy.
That being said, my newest addition is also my first shaft drive and I LOVE it. I'd be all about shaft drive on the new Wee-strom.
Oooookay. Just looking for a little discussion is all. You're more than welcome to not participate.
For the record my chain Q was rhetorical. Was simply trying to push home that shaft drive for an all-new V-Strom is not required. I believe you were making a similar point with the BMW/Triumph comparo.
I know chain maintenance isn't that bad.
But thanks for the chain mileage guestimates. I hadn't read that yet. Quite frankly I don't consider chain maintenance to be a deal breaker. I'm pretty used to getting at least 2 seasons out of a chain. Sounds like a 'strom chain is no different.
Dana can come across as crass and sassy, but I assure you, he's a luvbug.
Well they are supposed to unveil the NEW strom tomorrow.
If it is a significant improvement there will be a large number of reliable used Weestroms on the market
For the record... I got over 30,000 miles on my original Wee-Strom chain. Never cleaned it, just lubed it religiously using the Dupont Teflon stuff. Lubing it is a simple matter of putting the bike on the centerstand and letting it run in first gear while spraying the chain with lube. Takes all of about 30 seconds.
--mark
When is the announcement????
Consider the GSX650F for comfort and fairly upright position. For $4k you can get a 2008 used one. Better for the road. The DL650 seems like would handle better the road the the DL1000 and would be my vote.
Why do you say that about the Versys? Turnoffs from what I've read include: slightly more vibey I2 engine, less aftermarket support, and less heft for highway riding. Price is right though. I've sat on several, they fit fine. Can't find anyone willing to let me test ride though..
Ulysses are even harder to find than clean V-Stroms. Book value is much higher too. Wish I was shopping last year (or was it 2 years ago already) when they were blowing them out at the dealers.
Triumph scares me. Way too much money anyway.
I'm really hooked on the idea of a "naturally balanced" 90-deg V-twin. Have spent the last couple years telling anyone that would listen that I thought the SV650 was the bike to have. Then I discovered the V-Strom 650. Everybody says the SV/DL 650 is a sweet engine.
Today.. or not. Suzi is playing marketing games. Very silly.
Interesting. Hadn't seen them. On paper they have a lot more lean and an I4. Seems very Bandit-like. I just moved on from a Bandit because of the lean angle, 4-cylinder vibes, and complexity. Isn't this basically a replacement for the old Bandit 600?
Can't find any used on the 'net.
I had a Versys for a few months and it was a really good bike. Comfortable, just enough power to do anything, surprisingly good stock suspension (if you're a bigger guy), easy to wrench on, etc. With that being said, it was (in my opinion) completely devoid of any sort of character. It was a tool that worked very well, but didn't do much for the soul. That's why I got rid of it.
Because it's similar to the Wee-Strom in terms of riding position, comfort, and power, but handles quicker due to the 17" front wheel.
Why? You are aware, I assume, that the "new" Hinckley Triumph is a totally different animal from the oil-leaking old Meriden Triumphs of the '70s and earlier? They're on par with the Japanese for reliability.Originally Posted by nhbubba
It may be "naturally balanced," but it still vibrates a lot more than the inline triple in my new Tiger 800.Originally Posted by nhbubba
I took my Wee-Strom out for a ride about two weeks after getting the Tiger. I was shocked at how unrefined it seemed in comparison. It looked and felt like it had been designed by a fifth grader compared to the Tiger. It was like riding a Tonka toy.
This is a perfect description of the Wee-Strom as well.Originally Posted by schleppy
By all objective measures, it's an excellent budget-priced bike. But it's got no personality. I put nearly 40,000 miles on mine in three years, but once I got the Tiger, I stopped giving the Strom a second thought.
--mark
Nothing wrong with a chain - and this is coming from a shaft-drive lover. You *do* have to do things to a shaft drive unit - less frequently, but be prepared for a bit of a hassle when you do. Greasing the splines on the driveshaft and changing the final drive oil on the GS series isnt exactly hard, but you arent going to be doing it easily on the side of the road either.....
And there's the fact I can *see* if my chain is getting shitty, while my shaft drive gears a a mystery inside their housing.
the best driveline imho is an enclosed chain, best of both worlds, my XV920R has over 60,000 miles on the original non o-ring chain, only maintneance is replace the grease every 30,000, rewewing the grease can be messy, it's not a heavy oil it's grease so it don't drain out the drain, you have to take the housing apart, scrape it out, wash the parts in kerosene, clean the chain then reassemble and pump in 3 liters of moly grease, good for another 30k, wish the starters would last that long
I have a VEE 1000 Strom because I view the local tertiary roads as paved dirt roads so the longer suspension ala hyper motard.
I once bought a nice Toyota Supra. Then a month later had to move my old Turbo Capri, after being in the Supra, I said this is farm equipment
Maybe they are all wacky nerds but almost every Vstrom rider loves it but then there are many low mileage ones for sale. I guess its polarizing.
Can't find any used on the 'net.[/QUOTE]
Yes, the GSX650F is bandit like and same engine as the Bandit 650. The motor is smooth and torquie, but the riding position is not as upright as the DL. It is still very comfortable. The price on them is right and the styling in my opinion is spot on. It also has a one piece seat that should be comfortable for occasional two up riding. Just threw one more bike into the mix...from all you mentioned DL650 would be worth while checking out. I agree that the Vtwin engine on these bikes is nice. I rented a naked SV650 and enjoyed it, even two up with my wife.
Meh. Bandit, Bandit Jr, GSX650, whatever they call it, I think it's time for something new and different for me. It's a bitch too. Sat on the new Bandit (or whatever they're calling it now) at a stealer the other day. Water cooled, EFI, available ABS, nice plastics. Thing has grown up to be a helluva bike.
Damn you. Mom's has two now. I think I need to make a day of it and head down.
Price. Parts cost. Price. Maintenance costs. Price. Dealer network. And oh yeah, price.
Oh yeah? I know a guy with a Speed Triple. Maybe I need to track him down.. Give the big T a chance.
Oh I hear that! Its no wonder so many of my neighbors drive SUVs these days.
