well every time i hit a good sized bump my bike loses power for a sec.. i redid the ground to the battery.. still doing it.. no cuts in the wire anywere. i been looken at the install manual for the PC(i dident install it) but when i disconnected the ground it still had power.. so is there more than 1 ground for the PC? is there a ground where it hooks to the harness? dont kno what else to look for, any help would b awesome thx -Larry
The ground should be directly to your battery. I would also check other connections besides your PC. Look at your kickstand and make sure it doesn't bounce and kill the power also
Be sure your fuel relay switch is held securely in place, where ever it may be...
