Results 26 to 50 of 58
[probably dumb question] checking oil by yourself?
    Ma
    Wow...what did you do to it this time........getting new rims??? Is that a current picture? I see you took the front rotors off too...
    I like cats.......but I can't eat a whole one by myself.
    Lifer ZX-12R's Avatar
    Candia, NH
    (Btw, I tried the balancing thing. Couldnt find it. Bike fell over 4 times - once on me. I'm OK though. Maybe I need new tires???)
    Actually old tires work the best. To make it even more stable, give your rear tire a healthy burn-out before checking. This squares off the profile and gives you extra stability.
    May 2007
    Southern NH
    Makes sense...thanks
    Muhammad Ali.
    Lifer BostonSVkid's Avatar
    Dec 2005
    umm when the bike is on the sidestand kneel down on the side the site glass is on. grab the seat and the handlebar/clip ons and pull the bike toward you or push it away depending on which side you are on. balance you bike on its balance point and check site glass. If bike starts to tip one way or the other pull it or push it in the direction of the side stand so if it does go over it will stop on the sidestand. If you cant check your oil give me your SV and I will take good care of it.
    2006 Ducati Monster S2R800
    I Dance With Will
    Oct 2002
    unknown
    Quote Originally Posted by noudidnt View Post
    that was couple years ago changing tires.
    "fuckit!"
    Lifer markbvt's Avatar
    Georgia, VT
    Quote Originally Posted by spicy View Post
    and why would it matter having the oil sit around? i'll be starting it periodically, but i can't imagine having oil sitting around for 3mo being any different than oil sitting around for a couple days, even if it has 3k mi... i might be wrong, though.
    3000-mile-old oil has a lot of noxious combustion byproducts in it. If you leave it in over the winter, these can begin to eat away at internal engine components, shortening the life of the engine.
    Also, you want to avoid starting the bike during the winter unless you're going to be riding it long enough to thoroughly heat the oil (usually around 20 miles, to be safe). If you don't get the oil hot enough, water condensation will be trapped and can further contribute to engine deterioration.
    --mark
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Go in front of a police station
    Due a 20 second burn out smoke show.
    Stop the motor and wait 5 minutes.
    The now flat rear tire will glue itself to the pavement and hold the bike up.
    Get off and check the oil level.
    Glen Beck is John the Baptist
    If you are worried, just get a friend to hold it level while you look. Takes all of 2 seconds....
    I'f your always serious then why to fuck did you respond to a thread where the guy wants to be able to do it by himself
    I'd be willing to bet he already knows how to check the oil when help is available
    I Dance With Will
    Oct 2002
    unknown
    --mark
    idling for 20minutes or so is not hot enough? 20 miles ride?
    im gonna not follow this procedure and just idle and maybe put on the stand in gear.
    "fuckit!"
    Everybody to the limit!
    Winchester, MA
    Just rev it up in sixth gear and dump the clutch, you'll have covered those 20 miles in like 5 minutes.
    Idling will not put out enuf electricity to recharge the battery the amount that was drained just starting it
    Georgia, VT
    Also, idling an engine for 20 minutes is not very good for it.
    --mark
    Just Registered Doc's Avatar
    Jericho, VT
    But if he does it in a closed unventilated garage it might be good for the rest of us.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    hey Al, you got zx10 don't you?
    wow, you are a daring fellow. I'd atleast up jackstands under the cases
    I Dance With Will
    Oct 2002
    unknown
    true!
    i did it all winters since i got the bike. sometimes once in two weeks. battery is still pretty strong.
    "fuckit!"
    Nov 2007
    Change the oil at the end of the fall... then just let the bike sit for the winter with battery on a tender and none of this 'start and warm it up for 20 minutes every few weeks' business. Then in the spring, ride it for several hundred miles then change the oil again.
    nice.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    I Dance With Will
    Oct 2002
    unknown
    actually i think i tried to start it up once a month just so i don't feel out of touch. i've been feeling not interested lately. anybody feel this way?
    "fuckit!"
    Winchester, MA
    You don't bring me flowers anymore
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    yes it is;
    Possible and a dumb question.
    Read your owner's manual per chance?
    The sv650 will either have a sight glass or a dipstick. Not sure which.
    Seems this bike has a sight glass & a dipstick.
    www.bostonmoto.com
    Forum Rules
    Ma
    Dont worry Kham...we can get you hooked up with some Ciallis...It should bring your interest back up
  21. #46
    I Dance With Will
    Oct 2002
    unknown
    i'll send you flowers, a thong, and bra. what size do you wear?
    "fuckit!"
  22. #47
    Winchester, MA
    Extra medium.
    Foxboro, MA
    Extra medium.
    that's not a size.
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
  24. #49
    OP: I used to have this problem too, and while I never solved it, I did change the oil frequently enough, with the correct amount of oil, that never leaked out, that I was confident there was enough oil to begin with. So if you can't get a friend to hold it/check it, can't get stands to hold it up straight, can't get some ratcheting tie downs on rafters, then just prep the bike for winter, and change the oil (with the right amount) come spring.
    Lifer Currently's Avatar
    Ooltewah, TN
    Quote Originally Posted by beet View Post
    Sight Glass is located on right side of engine.
    Dipstick is on the seat holding the throttle.
  1. Another dumb question....
    By sdog30 in forum General Track Day Talk
    Last Post: 06-22-10, 08:55 AM
  2. maybe a dumb question
    By johnnym in forum General Track Day Talk
    Last Post: 04-13-10, 10:18 AM
  3. Dumb Track Day question
    By The Snowman in forum Track Day Forums
    Last Post: 01-18-07, 10:41 PM
