Results 1 to 25 of 25
new project is a 2003 SV1000
    Member stpierre's Avatar
    Sep 2011
    Laconia N.H.
    My new project is a 2003 SV1000. I just got this for $500 so now I can keep the Hawk.
    What up, bitches?
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Re: new project is a 2003 SV1000
    What are the plans with this one? Is it going to be another bike I dream about like your Hawk?
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Haverhill, MA
    Ahhhhhhh an SV1000! Much different than the TL1000S as far as suspension goes. Have fun with your project. I'm sure you'll love the bike, they make great street bikes.
    Joel
    Sep 2011
    Laconia N.H.
    So what is different between the TL and the SV?
    What up, bitches?
    Sep 2011
    Laconia N.H.
    Yup going for a new look I'M just not sure what? (maybe this)
    http://2wheeltuesday.com/2010/06/apc...-circus-tp199/
    What up, bitches?
    Senior Member SVenpointsixtwo's Avatar
    Jeffersonville, VT
    Quote Originally Posted by stpierre View Post
    Power. TLR and TLS made more HP + torque with different heads and cams. They have a reputation for poor handling though, whereas the SV does reasonably well out of the box, and can be set up to handle very well with not a lot of effort.
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Massachusetts' Noth Shoah
    What's different? Effectively everything but the bottom end!
    Edit: I've got engine parts if needed.
    Sep 2011
    Laconia N.H.
    Quote Originally Posted by dontpanic View Post
    Thank you I'M sure I will.
    Quote Originally Posted by SVenpointsixtwo View Post
    Thanks for the info.
    What up, bitches?
    Sep 2011
    Laconia N.H.
    It is a 2003 SV1000 it got stolen and striped and has been sitting for the pass 5 or 6 years. This is how I got it now what do I do?
    What up, bitches?
    Sep 2011
    Laconia N.H.
    Just cleaned it up best I could.
    What up, bitches?
    Sep 2011
    Laconia N.H.
    I need to pull the jugs to make sure it's ok. I have never done this only on two strokes so this should be fun it will never run again.
    What up, bitches?
    Sep 2011
    Laconia N.H.
    I have to put some $ in the SV. It was going to be fun as hell.
    http://cgi.ebay.com/ebaymotors/Yamah...item1e712004b5
    What up, bitches?
    Sep 2011
    Laconia N.H.
    Here are the pics of the eng. This is how I got it. It has not been cleaned. It had no speedo so not sure how many miles it has but from the looks of it it's low.
    I will post more pics next week when the parts get here.
    What up, bitches?
    Wirelessly posted (GS3)
    Nice. I don't know if TL heads or came would fit bit it might be worth a look since you've got of torn apart.
    That's my dream one day. Build a decent bobbed type of bike with a sportbike v twin
    Sep 2011
    Laconia N.H.
    Thanks for the tip.
    What up, bitches?
    Sep 2011
    Laconia N.H.
    For now it will be stock for the most part I have a set of 05 gsxr forks. Yes it will turn heads when I'm done more then the Hawk.
    What up, bitches?
    Sep 2011
    Laconia N.H.
    I just got this I have to make it work wish me luck.
    http://www.ebay.com/itm/300513938662...84.m1439.l2649
    What up, bitches?
    Sep 2011
    Providence
    this used to be MY 1997 TL1000S, sold it to the owner of Demon's back in 200? Couple years back I stopped by the shop and WTF? This looks familiar...
    one thing is they could have done a better job hiding wire harness
    Sep 2011
    Laconia N.H.
    Love the look but frame's are big $ and tons of work. The frame I like is $2,500 just the frame I have to pass on that for now.
    What up, bitches?
    Sep 2011
    Providence
    That is a rigid frame so it's probably under $1000, problem is that it's RIGID! ever rode one?
    second problem is all the fabrication you have to do
    Sep 2011
    Laconia N.H.
    Duc swinger just got here.
    What up, bitches?
    Sep 2011
    Laconia N.H.
    How hard would it be to take off 4mm on one side and 9mm on the other?
    What up, bitches?
    Sep 2011
    Laconia N.H.
    I am still wondering how I will manage shock, linkage, and swingarm connection. The Duc had the linkage above the swingarm at the top shock mount and the SV has it below. There are no provisions for linkage below because the shock bolted directly to the swingarm. They also used different lower mounts on the shocks. The SV uses a clevice mount and the Duc uses a heim joint. I guess if you have the right types of shocks you could swap them if they both were adjustable ride height units with removable connectors?
    What up, bitches?
    Sep 2011
    Laconia N.H.
    All the eng parts are in now! woohoo.
    What up, bitches?
  1. Wanted - Parts & Tools | GSXR or SV1000 wheels (01-04 GSXR 1000 or 01-05 GSXR 600/750 or any SV1000 )
    By juha_teuvonnen in forum Wanted
    Last Post: 08-24-15, 12:25 AM
  2. For Sale - Motorcycles | 2003 Suzuki Vstrom 1000 with SV1000 engine
    By superbikejunkie in forum For Sale
    Last Post: 03-31-14, 09:37 PM
  3. 2003 YZ250F PROJECT
    By roadracer685 in forum For Sale
    Last Post: 09-28-11, 09:53 AM
  4. sv1000 sv 650 radiator
    By frenchy21 in forum Pit Area
    Last Post: 08-09-10, 08:23 AM
  5. SV1000; orange
    By legalspeed in forum General Bike Related
    Last Post: 09-23-02, 01:50 PM
