I picked up a 2001 R1 over the weekend (from Half Squid), and it has a bit of a carburetion issue - it runs like dog shit above 7-8K RPMs. I imagine it just needs to have the carbs synched, but I wonder if the MIG pipe is messing things up as well....is a pipe like that too extreme (not enough back pressure) for the factory jetting?
I would honestly prefer to buy a stock exhaust if that were the case, but if the pipe isn't too much for the stock jetting than I would likely just leave it on there.
Anybody know?![]()
Thanks!![]()
I have a 2000 R1 with a High Mount MIG and have not jetted it. I have about 20000 miles on it and it is fine. Try http://www.r1-forum.com
for more info.
Nathan
Hey bro, the rule of thumb has always been if you install an aftermarket exhaust system, the entire thing, not just a slip-on, than you should see the said exhaust manufacturer for jetting reccomendations. Chances are 9 of 10 times they reccomed going up a size or two. Also, does it have a power commander? If so, which map is loaded in to it? See the power commander site to look up jetting spec's too. But only if you have one on the bike.
Good luck bro!
Heath-
Heath Smith
LRRS/CCS #337
Low Down Racing
www.racetireservice.com
www.motorbikesplus.com
Power by Dr. Hillsgrove
Traction by Franimal Racing Syndicate
05' KTM 525SMR,
01' YZ426F
05' Reiju RS1
Says Vale to Colin at the end of the 2002 8 Hours of Suzuka: "Ok Colin, you better go out there and win. Because it is the ONLY way we will NEVER have to come here again!"
Power commanders are for FI bikes.
Also, I assumed it was a slip on system like I have. These bikes have the EXUP valve in the exhaust header that controls back pressure. I have been told that with the stock header and a slip on jetting is not needed most of the time because of this valve. Maybe the valve is not working correctly???
I adjusted the air/fuel screws due to something I found on the R1-Forum. I didn't notice any difference.
Good Luck.
Nathan
Um, the Yammy I sold to Clay who sold it to Chris(I believe) has a power commander. So that would be incorrect info bro. The newer ones that you can load maps in to are obviously for FI bikes, but I still believe you MAY possibly be able to find jetting reccomendation's for the 01 somewhere out there. Hit the site of the exhaust mfr and contact their tech supprot mailbox and ask. That's where I'd start. Google usually finds me what i am looking for. That forum Nate posted looks real good too! Great link Nate! I'm new to Yammy ownership, so you got any YZ426 type forums to share with me?
Hey Nathan, by the way, that wouldn't happen to be you beating the ever living hell outta the bike in your avatar? Cuz if it is, that's fuggin awesome dude! Sign me up!!!
Heath Smith
LRRS/CCS #337
Low Down Racing
05' KTM 525SMR,
01' YZ426F
05' Reiju RS1
The Franken-bike in the avatar (the NESR whore that has belonged to gixxer6 and TheIglu) has some sort of trick ignition box, although I dont know that its a Power Commander? I'll have to look when I get home.....Originally posted by gixxer6
I signed up for the R1 forum, thanks for the link. I'll have to behave over there, they seem to have some draconian rules about posting![]()
Thanks guys!![]()
Get the exup
get it working best thing for the street
stock setting plus maybe 1 turn on the cables more open
better than fool exhaust system except maybe at maximum throttle at 10,500 rpms
Glen Beck is John the Baptist
The EXUP is the stock exhaust??Originally posted by richw
Get the exup
Got me? Good question?Originally posted by highsider
What is the "exup" anywho?
OH I BET I KNOW!!! It's a secret device that gives you like 300 rear wheel HP! Hey, HIGHSIDER, I WANT ONE TOO!!!!!!
Heath Smith
LRRS/CCS #337
Low Down Racing
05' KTM 525SMR,
01' YZ426F
05' Reiju RS1
The EXUP (EXhaust Ultimate Power) valve is very easy to adjust on that R1, if you've got the service manual -- there are plenty of .PDF versions posted around the web.
BTW, I've got a never-used Factory Pro jet kit if you're interested, model # CRB-Y68-1.0 I traded the bike before I got around to installing it.
As seen here:
http://www.factorypro.com/Prod_Pages/prody68.html
Service Manuals can be found here:
http://yzf-r1forum.net/manuals/index.html
I also believe the bike sat for a while so the first thing to do is clean the carbs.
I rode it on the track day and as the day went on it got progressively better and I suspect you have some old gas that has varnished itself and so partially blocking your venturi tubes
good luck
eat me
Check the airfilter for any rodents nesting in it.....![]()
So i get a rental car in White River Junction, then tow crap, spend days on the road like a lonely truck driver doing lines between all-nights East-West on I-40.........
Then Pooch goes HUGE with an R-1?
You wanna play with the BlackBird huh?
Highsider, do you trade everything in within months?
DO YOU HAVE YOUR OWN LINE AT THE DMV?
Your married right??????????? LOL
J/K -Suf Daddy![]()
Suf Daddy.
I shall spank your BlackbirdOriginally posted by Suf Daddy
J/K -Suf Daddy![]()
like a red-headed stepchild.
Well, maybe not......![]()
