Results 1 to 21 of 21
Rattle on high rpm
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Rattle on high rpm
    Hey all,
    I have a bike that just recently started making a weird noise.
    When in neutral, if you bring the RPMs up and then roll off, you hear a rattle noise coming from the clutch/transmission area.
    Same thing if you're cruising along and use engine breaking to slow down (rattle, rattle, rattle).
    Has anyone seen this before? Any suggestions on what it is?
    Any mechanical types want to take a peek at it one night this week, or over the weekend?
    Thanks!
    --Pat
    Re: Rattle on high rpm
    CCT
    But what is the Bike in Q....may help
    Apr 2008
    Boston, MA
    CCT?
    It's a 97 Sukuzi Marauder VZ800
    Don't know if they have one but the CCT is a Cam-chain tensioner they tend to rattle a bunch on High RPM's and then quiet down low???? Just a thought
    Apr 2008
    Boston, MA
    Okay, I'll dig out the pdf manual and see if that's in there. I hope it's not a miserable thing ti replace as I was hoping to sell the bike next week.
    I looked on bike bandit and it seem as there is one 30+ bucks for it... but its a place to start...I am not very familar with the Marauder soooo.....but def sounds like a cct cause my F4i was the exact same thing...
    also how many miles on her???
    Apr 2008
    Boston, MA
    24k got it ... five years ago or so and it hasn't seen many miles since then. before that service history is non-existent.
    Had the same symptom on my new-to-me CBR600RR down at VIR yesterday. Timing Disc Bolt backed out, pushed against the timing cover, busted a quarter-sized hole in it and then broke. Take off the clutch cover and look around, and make sure everything is torqued.
    CCS/LRRS #83
    Lifer Evil_Weasel's Avatar
    Over the Highside
    24K...have you had the valve clearnce checked and adjusted lately cause you are about due. a sloppy valve train can be noisy...though you can often hear it at idle as well.
    As usual, your post displays a complete lacking in any fucking idea what you're talking about.
    Hey, at least you're consistent.
    Apr 2008
    Boston, MA
    honestly, I've done nothing to this bike since we got it. I just changed the oil for the first time last weekend.
    Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    Quote Originally Posted by scottieducati
    Scottie. Shut up.
    Lancaster
    same problem with my bike, pretty sure its the CCT, hoping anyway, going to have it listened to by a local buddy of mine tomorrow and if that is the problem i will be having degsy help me fix it
    Corey
    CCTL issues on CBR's have a distinctive sound.
    The best way I have heard it described is like ball bearings in a coffee can. It is more prevalent when the bike is cold and goes away when the bike is warm and it is louder at higher RPMs.
    The more stress on the CCTL the worse. My F4i race bike had HRC valve springs and I had to replace the CCTL and camchain every race weekend.
    It gradually gets worse over the weeks but usually doesn't cause any mechanical issues if you don't let it stay like that until the camchain jumps a tooth.
    There are two fixes.
    1. Get a manual cam chain tensioner lifter like this one. That way, when the camchain stretches or the spring gets worn, you can adjust it to take up the slack.
    2. Install a new Honda one and pray it fixes it permamently.....but it probably won't.
    Lancaster
    ok so found out it isn't my CCT, not sure what my problem is, seems to have a rattle in high rpms or when engine breaking, got it checked out today and guy seemed to thing my drive chain is a little out of wack, not sure whats wrong, seems to only have a noise when the bike is warmed up, when its cold or at idle there isn't anything so maybe just my exhaust or something and i am overreacting
    Corey
    Lol. Only when hot? High rpms and on overrun? It's an exhaust join or heat shield rattling.
    Over the Highside
    Apr 2008
    Boston, MA
    so, any of you mechanical types wanna help me out this weekend?
    I've never ripped into a bike that far.
    Lifer DuncanMoto's Avatar
    Quote Originally Posted by noxin View Post
    Where are you now? at work?
    Lancaster
    thanks Degsy, makes sense, my exhaust did have a leak ill tighten the t-bolt clamps and see what that does
    Corey
    Apr 2008
    Boston, MA
    Quote Originally Posted by DuncanMoto View Post
    The bike is in storage near the house, but I have no problem trailering it anywhere. I just don't have a garage to work in anymore.
    NorthShore
    All I'm good for is moral support, beer, smokes and lobsters.. I don't know shit about fixin' bikes.
  1. Finishing rattle can paint
    By Garandman in forum Bike Maintenance
    Last Post: 05-25-19, 05:09 PM
  2. Rattle can paint job
    By 01xj in forum General Bike Related
    Last Post: 04-20-18, 12:19 PM
  3. SV Gas tank rattle, no start
    By Tekime in forum Bike Maintenance
    Last Post: 03-22-18, 11:18 AM
  4. heat shields rattle
    By SNIPER in forum Bike Maintenance
    Last Post: 06-13-09, 10:24 PM
  5. Cam chain rattle
    By PaulB in forum Bike Maintenance
    Last Post: 08-18-02, 03:42 AM
