Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
RC8R valv stem ruined
    TWINS! xrocket21's Avatar
    Central Maine
    Re: RC8R valv stem ruined
    My friend was sick this weekend so I couldn't get down too use his tire machine, so I frigged around with it more last night.
    With an ez out I was able to get the red part out. Air still didn't come out of the stem. I poke at it some, and tried installing a valve, when I backed the valve out, that third part, a tiny tip came out. Very little air leaked, so I poked at it and cleaned it out and was able to get the valve in, but the tire filled VERY slowly. Took the valve out and cleaned the hole more. Filled it again and it still didn't seem right. Took the valve out and let the air out. Partway, some gunk shot out. Put the valve back in and set it to 38 psi and left it last night and it is holding air!!!
    Hypertarded
    RI / CT border
    nice work.... no scratches?!? that orange is a BITCH to match....
    Central Maine
    nah, I never broke the bead. It is hard not to to smack the brake caliper when taking the wheel off though.
    nice job! can't beat an easier fix, hope it holds.
    Central Maine
    I will definitely keep an eye on pressures, but I tend to check before every ride anyway since i ride infrequently. It didn't even lose 0.1 psi over night with no cap on it.
    why not get the 90 degree ones from Kurvey Girl? those are the preferred ones for racers
    Central Maine
    I'll check em out! I'll definitely change them out next time change.
    https://www.kurveygirl.com/collections/valve-stems
    Central Maine
    Thanks! I haven't figured out what size the darn thing is yet.
