Results 1 to 25 of 41
rear brake
    I Dance With Will
    Oct 2002
    unknown
    rear brake
    who else doesn't use rear brake like me?
    just wondering.
    "fuckit!"
    Lifer bentbryan's Avatar
    Rye, NH
    rear brake
    I don't touch the thing. I practice with it alittle in case of certain (off-road, slippery) conditions.
    2003 Yamaha R6
    1999 Yamaha YZ400
    Littering and........
    Jul 2004
    Vermont
    rear brake
    I believe I read on the Tony's Track Days site that Tony doesn't use his rear brake.
    I always use mine, but I dont know how much it helps you stop, I just like to keep the bike from nosediving.
    Check out the Tonys Track Days site - they have a whole bunch of infor about front brake v. back brake tests, etc.
    I Dance With Will
    Oct 2002
    unknown
    rear brake
    i know the purpose. im wondering how many dont have to use it. i post on other board and most poeple is like "it's there so use it" crap.
    "fuckit!"
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    rear brake
    I touch my rear brake once per ride to keep the rust off the rotor
    Use my front brake pretty much exclusively other then that.
    Cheers,
    Chris
    I Dance With Will
    Oct 2002
    unknown
    rear brake
    Cheers,
    Chris
    same here.
    "fuckit!"
    Pimptastic ftrain's Avatar
    NH
    rear brake
    I love my rear brake. makes powerslides fun
    ~ FTrain
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    rear brake
    I only use it when riding 2 up to be smooth and when i'm screwing around...
    Lifer legalspeed's Avatar
    Somersworth, NH
    rear brake
    My rear brake is used to scrub momentum from the sprung weight; keeps the suspension taught; helps to keep the front end from lofting; can be used to slide the rear wheel to one side or the other.
    Your motorcycle can slow down a lot faster when using the entire braking system properly.
    LRRS\CCS\WERA #486
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    rear brake
    doooood? my z1000 didnt come with the rear brake option?!
    i feel ripped off.
    Dec 2003
    Ma
    rear brake
    I didn't realize how much I used it, especially in the corners till I put on new pads that squeeked. Then I was hearing it all the time.
    Lurker Zorlock's Avatar
    Jul 2004
    Hopkinton, New Hampshire
    rear brake
    70/30
    see ya,
    DJD
    NH
    rear brake
    I also use mine to bog down the motor and prevent the bike from going over in a wheelie.
    ~ FTrain
    Posting Freak patricia929's Avatar
    Aug 2003
    Kensington, NH
    rear brake
    i very rarely use my rear brake. the only times i'll use it are if the roads are really wet or sandy OR if i've got to make a really fast hard stop.
    the only normal people are the ones you don't know very well.
    Waterbury, VT
    rear brake
    I use the front brake only for most riding. If I am on a wet road, or dirt then I use the rear also. I have replaced the rear pads with the softest compound I could find so that when I do need them they are there. Normally I don't throw enough heat into them for them to respond.
    SSearchVT
    May 2003
    Lakes Region, NH
    rear brake
    i use mine but only a little. Never stomp on it, Only for added slowing down power when coming to a light that just changed or a car that stopped short in front of me. The times when you need everythin you got to stop but I have only locked it uyp once so far and that was really early last year - learned my lesson.
    I'm fat so I need all the help I can get when it comes to stopping fast
    Bras cause cancer.
    Somersworth, NH
    rear brake
    Originally posted by Zorlock
    70/30
    True dat.
    LRRS\CCS\WERA #486
    crash squid elaineo's Avatar
    Oct 2003
    rear brake
    i never used my rear brake, until the dumbass who put my ex250 back together forgot to tighten the bolts holding the front brake and my front brake fell off while i was riding. then i had to use my rear brake.
    WSMC #940
    rear brake
    I have a SV, don't use either brake much except to stop from less than 10mph. I slow down by rolling off the throttle
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    Exactly..............
    I'm no pro but 70/30 is right on.
    I use my front to perfect my modulation and to help with future panic stops.
    The rear doesn't do much and just what you don't want is locking the rear and swinging it around IMHO.
    BTW: technically my BlackBird has linked brakes so the front actually provides some rear.
    HTH -Suf Daddy
    70/30
    Suf Daddy.
    Mar 2002
    Amherst, NH
    rear brake
    you know, you dont seem to have had the best of luck with motorcycling so far.
    i dont know what to tell ya though, maybe knitting would be safer.
    I Dance With Will
    Oct 2002
    unknown
    rear brake
    so whos the dumbass?
    "fuckit!"
    Lifer odduc's Avatar
    NH
    rear brake
    I don't use my rear brake very often. However, it does come in handy when downshifting from high speeds. When blipping the throttle between downshifts, I sometimes keep light pressure on the rear to assist in slowing down. Of course, you do not want to use the rear brake when leaned over in a corner.
    LRRS#167
    Everybody to the limit!
    Winchester, MA
    rear brake
    Note to self: make sure to loosen rear brake next time, also.
    I Dance With Will
    Oct 2002
    unknown
    rear brake
    now that's funny. haha..
    Elain, dont pick the same dumbass to work on your bike next time.
    "fuckit!"
  1. Rear Brake Help
    By throttlejunkie in forum Bike Maintenance
    Last Post: 08-18-12, 10:07 PM
  2. rear brake
    By PPS26 in forum Pit Area
    Last Post: 02-13-10, 09:49 AM
  3. The rear brake
    By -jro- in forum General Bike Related
    Last Post: 06-05-08, 04:58 PM
  4. rear brake pedal/rear light not working
    By seth399 in forum Bike Maintenance
    Last Post: 04-10-08, 09:57 PM
  5. Sticking rear brake
    By TegRacer324 in forum General Bike Related
    Last Post: 02-18-08, 08:30 PM
