Results 1 to 15 of 15
Rearset Adjustment
    2WT
    Adams, MA
    Rearset Adjustment
    Ok guys I have been riding my bike long enough now to think that my position is off. When I ride and I grip with my knees they are generally around the frame area which tends to get hot. I know your knees are supposed to be on the lower part of the tank so do I need to raise my rear sets to make it so my knees are on the tank? Do I just need to grow, am I just sitting improperly on the bike?
    I was thinking about getting tank grips but then thought how much would they help if my knees were holding onto the frame.
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Re: Rearset Adjustment
    ok, Im short 5'6" and have the same issue. Historically I have always gone up on my toes when I ride aggressively. I do now have adjustable rearsets on my bike which is a first and it helps a little but I still like to go up on my toes when it gets aggresive, mostly habit now. On my RC51 I had the heat issue and actually mounted black mousepads to the frame with 3M mounting tape to save my inner thighs from the blistering frame heat (they actually looked ok once they were cut to shape on the frame).
    Lifer G21forme's Avatar
    Lakes
    I'll give you my experience with adjustable rearsets. I'm 5'10" 145 on a 2003 zx6r and was having trouble with body position on track especially in turn 9. I wore the paint of the right side of the frame and decided to experiment with my rearsets. Moving them forward and down totally helped and I really felt more "hooked on" the bike did already have stomp grip on the tank but I was only able to utilize it when I adjusted the pegs. I say move them forward and if you don't like it move them back.
    2WT
    Adams, MA
    well my rear sets are not adjustable as they are stock, asking this was more of a should I buy a set that would adjust if it would solve my problem.
    Lakes
    Hard to say, rearsets are made to be higher and further back but I may be mistaken though I was under the impression you might be able to adjust them to stock position with the ability to adjust them back and up, I can tell you mine can't be adjusted to stock only further back and higher.
    Posting Freak boloson's Avatar
    Oct 2007
    i believe vortex rearsets have the most adjustibility as far as going further back & up? just measure your stock rear sets position from the peg to the ground now and when/ if u replace with an aftermarket and dont like the position u can always put it back to stock position.
    Lakes
    Quote Originally Posted by boloson View Post
    That is incorrect as it's typically a bike to bike between the adjustability between manufacturers. I think the op it trying to move the pegs forward.
    2WT
    Adams, MA
    I am not entirely sure they need to go forward or backward, however I think going up might help keep my knee on the tank and not the frame. Guess I will have to look at aftermarket rear sets.
    Thanks for the information.
    Lakes
    Do you ride on your toes? If so I would say your pegs need to go up and forward or maybe just one our the other just from having the same problem you have described but ymmv.
    2WT
    Adams, MA
    yea if i go up on my toes my knees are against the tank, as I go up I probably do go forward a bit too.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    get some riding pants with knee armor. heat issue solved.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    I thought the new gsxrs had adjustable rear sets stock?
    Lakes
    Quote Originally Posted by jcrawford View Post
    Well there ya go.
    Oct 2007
    Quote Originally Posted by DaveZX6r View Post
    If my memory serves me right my 06 gsxr had 3 holes for the base of the rear set. Not much adjustment but more then my kawi now that's for sure
    This is what you need........i have to fix my left side and could pull mine off and see if they bolt up to yours
    http://proluxracing.com
  1. Replies: 2
    Last Post: 11-11-12, 07:15 PM
  2. Where to get rearset bolt and pin?
    By virtualbong in forum General Bike Related
    Last Post: 07-19-11, 02:39 PM
  3. OSF rearset spares, anyone got any?
    By jeantarrou in forum Wanted
    Last Post: 04-12-11, 01:45 PM
  4. rearset alternative??
    Last Post: 03-16-07, 02:11 AM
  5. Rearset.
    By BigShel in forum General Bike Related
    Last Post: 11-02-05, 05:22 PM
