Results 1 to 11 of 11
Recessed wheel chocks
    Braap Baggey22's Avatar
    Westford, VT
    Just got a new trailer and want to get it set up. I have HF wheel chocks that work fine, but they're a pain to take in and out because I use my trailer for other things than motorcycles. I saw some recessed ones online. Anyone used these before?
    https://www.summitracing.com/parts/p...RoCfZoQAvD_BwE
    http://jfmco.com/product/4-inch-wide-popup-wheel-chock
    Thanks!
    New Haven-ish, CT
    Re: Recessed wheel chocks
    I also have the HF chocks. Instead of bolting them to the trailer deck, use clevis pins, some jumbo washers, and R-clip cotter pins. Takes maybe 45 seconds to install/remove the chock.
    Westford, VT
    Do you have a picture or seven of how you have yours attached?
    Lifer FirstDuc-1098's Avatar
    Central Mass
    http://condor-lift.com/trailer-only-chock
    comes out with 4 thumb screws, leaving just the black plates on trailer bed. Have 2 in my trailer that I take out for loading snowmobiles
    Shit Corey says:
    May 2010
    Somersworth, NH
    I have a HF chock that goes in and out of my trailer as needed for bikes other than the race bike (uses a Pitbull). I drilled holes and used 3/8" threaded T-nuts and have matching Eyebolts with a Nylock 'set' nut quick and easy install and removal.
    High maintenance priss
    Central MA
    The recessed work fine; won't hold the bike up like a clamping chock tho and you can only install them between flooring supports (might limit your location options). And of course: no flexibility because they can't move (longer bike, weight distribution, etc...).
    They do have a chock which quick-attaches into airline track if you want something a bit more flexible and give you floor tie-down options for other uses. LINK
    Cat herder
    Dec 2014
    Low Earth orbit
    I have a Condor Pit Stop/Trailer Stop chock on my HF trailer. When not using the trailer I need to fold it up and put it in the back of the garage, so removing the chock easily is important.
    Condor makes a small, low-profile bracket for the chock that you screw to the trailer floor. The chock then plugs into keyhole slots, and is held there by a thumbscrew. Super-easy to remove, takes just a few seconds, no loose parts.
    The Condor chock itself is really, really good. More adjustable than most and rock-solid.
    http://condor-lift.com/all-products-...t=p.sort_order
    Lifer Pittenger5's Avatar
    Austin
    I use these, only leaves a small mounting bracket when they're not in there.
    https://www.amazon.com/Kage-Racing-M...l%2Bchock&th=1
    Zip Tie Alley #505
    Senior Member dhawks's Avatar
    Apr 2008
    This looks slick.
    /s/ Dustin
    LRRS #767
    '09 R6 / '11 848 Evo / '99 RS250
    New Haven-ish, CT
    Quote Originally Posted by Baggey22 View Post
    From top down:
    3/8" diameter clevis pin, 3/8" ID washer, (chock, trailer deck), 3/8" or 1/2" ID jumbo washer, R-clip.
    Set the chock over the holes in the trailer, drop the pins with the top washers through. Crawl underneath and put on the bottom washers and insert the R-clips. Use the clevis pin hole that's closest to the deck, don't worry if he chock isn't snugged down tight like as if you were bolting it, the weight of the bike strapped down will prevent it from moving. Just use some pretty heavy duty R-clips, because when you're pulling the bike out of the chock, the clips and bottom washer will be holding the chock against the bottom of the deck.
    Attached Thumbnails Attached Thumbnails Recessed wheel chocks-img_7792-jpg
    I use these as well. They work very well.
  1. For Sale - Parts & Tools | FS: Pingel removable wheel chocks - 2x
    By xxaarraa in forum For Sale
    Last Post: 07-27-14, 11:16 AM
  2. Tip for track riders using clamping wheel chocks: air up
    By keeena in forum General Track Day Talk
    Last Post: 08-15-10, 09:28 PM
  3. FS: (New) Haul-Master Wheel Chocks
    By Kitt in forum For Sale
    Last Post: 06-09-09, 10:32 AM
  4. Quick release system for wheel chocks
    By Honclfibr in forum General Bike Related
    Last Post: 08-18-06, 07:19 AM
  5. bike wheel chocks
    By oreo_n2 in forum General Bike Related
    Last Post: 08-05-04, 12:13 PM
