Page 1 of 3 123 LastLast
Results 1 to 25 of 59
REMINDER - trailer bearings
    Don't forget to repack your bearings with grease on the trailer before round 1 (or track days).
    ...and check your tire pressure
    Large member Larry's Avatar
    Nov 2010
    Limington maine
    Re: REMINDER - trailer bearings
    And fix all the water damage from the leaks you didnt repair in the fall......or am I the only bonehead that did that?
    Tahoe City
    My trailer has been buried behind my dad's house under snow all winter...I'm assuming it has just rusted into the ground at this point. Bike racks should support a motard, right?
    And check the brakes!
    Apr 2011
    NH
    ya know, last year when you posted a reminded about trailer bearing I thought, damn I should do mine. I never did and now I've sold it. I did tell the guy he should repack the bearings though.
    Tim
    LRRS #44
    Superbike Services 44
    Banned G21forme's Avatar
    Lakes
    How exactly do you do this? Probably need to do mine but I've never worked on my trailer.
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    I was wondering how to go about replacing them. How do you know what bearings to buy when the trailer is homemade?
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Old and Slow Sheppo's Avatar
    Westford, Ma
    bearings have a number stamped on the race. Take it to a trailer store and say you need these... and there are inner and outter bearing as well so if you are replacing them take and inner and an outter and get 2 of each.
    Posted by Jane in BoxChat
    Take the cap off the center. Jam a bunch of water proof grease in there. Cap the center. No need to take the wheels off.
    Oct 2004
    Southeastern Taxachusetts
    I did mine a week ago!
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
    Nov 2007
    Good reminder Jimmy... I need to do mine. I should probably replace them at some point, I've never done them on the little utility trailer.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    #331 CBR929RE's Avatar
    Bridgewater, MA
    or if you have grease fittings just attach a grease gun and pump some in
    Westford, Ma
    yea best advice, Bearing Buddy's
    Raymond NH
    Pump in just less than the amount necessary to blow out the seals on the back of the hubs.
    Raymond NH
    If your spindles look like this, the bearings may be running a bit dry.REMINDER - trailer bearings-091-jpg
    xxaarraa
    Guest
    Did this couple months ago! Along with a new tire. After paying $50 at Bennys to get a new tire put on, I saw that Harborfreight is selling entire rim/tire for $50. Doh!
    Lifer BSR6's Avatar
    I dont' trailer my bike, but as a snowmobiler I have a ton of experience with trailers and bearings.
    Before the begining of each season a shot of greese to both wheels, and checking tire pressures (including the spare) is always a must. One extra thing I like to do is break the lug nuts free and tighten them back down to spec. This ensures they will come off with ease if you get a flat. It sounds petty, but I have experienced getting a flat on a trailer where the lug nuts were rusted on and it wasn't fun. If you go long periods of time without removing the wheels it's worth doing once a season.
    Granted, the conditions for a snowmobile trailer are a lot harsher due to the time of year we are using them but you can never be too careful.
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    How about I blow out the seals, take a little grease out, then I'm good to go?
    Lifer Falko's Avatar
    MoonTown
    It looks like you blew a seal.
    What, no, no, it's just ice cream...
    Lol, My first race trailer was abandoned on 106 cause I cut the axle right off. I knew there was something I forgot to do!
    Member Kawi Ken's Avatar
    Jan 2013
    Bridgewater Ma.
    Ya have to break them all down,clean'em up and anaylze and ck for pitting inside brg. and inner race
    If they are odd ball numbers to your parts man you take them to South Shore Brg. @ Furnace pkwy. express in Quincy and they will match them up for you.
    The best grease to use is the Amsoil Synthetic for them also -
    http://www.amsoil.com/shop/by-produc...istant-grease/
    Quote Originally Posted by Kawi Ken View Post
    I've been using the wrong grease for the last 12,000 miles!!!
    Westford, Ma
    Probably the wrong motor oil too, Paul.
    Lifer Punjistick's Avatar
    Norwell, MA
    How much grease should be in the hub area? I'm reading everything from a light coat, 1/3 full, to completely packed. It seems like a 'what kind of oil should I use' type question.
    Whut? Who the hell says "light coat"?
    Fully packed. If you have zerk fittings you should pump grease in there until it oozes out the seams.
    If you don't have zerk fittings you should install them and see above.
  1. For Sale - Other | Trailer hubs with bearings, 5 lug
    By Falko in forum For Sale
    Last Post: 10-02-17, 06:42 PM
  2. Trailer - Bearings and tires?
    By knarlydog in forum General Bike Related
    Last Post: 09-24-13, 12:50 PM
  3. Trailer Bearings?
    Last Post: 03-12-09, 01:36 PM
  4. wheel bearings on a trailer - need help
    By Crash Dummy Denno in forum Bike Maintenance
    Last Post: 05-20-08, 08:09 AM
