Results 1 to 18 of 18
Removing Decals from Bodywork
    Nov 2004
    Boston, MA
    Is there a way to do this easily and cleanly? Any product that can be used and is safe on paint?
    The decals in question are not clearcoated over.
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Lifer imkindafkedup's Avatar
    Jan 2006
    Saugus, MA
    Re: Removing Decals from Bodywork
    heat, a heat gun if you have one if not use a hairdryer, use GooGone or WD40 wd40 and a paper towel afterwards to get rid of any left over glue.
    Southern, NH
    +1 on the googone.....stuff is amazing.
    Nov 2004
    Boston, MA
    Do I peel them off and then use googone on whatever is left?? I don't have a friggin' clue what IM doing in case its not obvious.
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Southern, NH
    I have used it on all the warning stickers
    on the bike and it worked like a charm.
    After you use the heat gun to loosen and heat up the
    glue and peel them off use the GooGone after on the residue.
    good luck
    May 2007
    Southern NH
    As stated earlier, first use a hair dryer...but don't hold it RIGHT up against the decal...stay back an inch or so...and heat it up. Then, peel it off carefully keeping the hair dryer on the decal as you do.
    Finally, use GoobeGone and a soft rag. Then polish as usual.
    Muhammad Ali.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    An old credit card works well to scrape the decals
    off after you've hit them with a bit of heat.
    2008 Honda CBR 600RR
    Leo loridin64's Avatar
    Outside Lowell
    Heat is def your friend when doing this. I used a little brake/carb cleaner once i got all the original decals off when i did my R6 below. You just have to make sure that you dont use a rag thats at all abrasive.
    Lifer Punjistick's Avatar
    Norwell, MA
    Quote Originally Posted by loridin64 View Post
    The brake cleaner didn't hurt the paint?
    Googone is plastic safe>>>>
    Outside Lowell
    not when i did it. i sprayed it into a clean rag and then wiped the extra glue off.
    Senior Member nixoid's Avatar
    Sep 2005
    Watertown, CT
    My bro had good results on an older [8 yr old Yammie] using rubbing alcohol and a clean rag in conjunction with heat. The black paint was fine
    Full Tilt - Full Time Trackday Guru's Avatar
    Dec 2006
    Concord, NH
    WD40 the heck out of it, and wipe it dry. DONE.
    Googone's good, but takes a bit of effort. Use the WD40 and be done with it.
    Mike
    Am #124
    Jan 2006
    Saugus, MA
    this fits the typical stereotype of forums. the whole "just do waht he said" type thing keeps going on haha. I got a good laugh reading back on it and seeing everyone repeat the guy before him pretty much.
    Lifer legalspeed's Avatar
    Somersworth, NH
    Manny, I have tried a lot of ways, go get a real heat gun (mine is from Sears)
    Heat em, peel em, no problem.
    3M makes and excellent adhesive remover for getting the gunk off once you peel, it's called 3M adhesive remover (it may be mineral spirits).
    Those two will save you hours.
    LRRS\CCS\WERA #486
    Apr 2006
    Beverly, MA
    If you have any residue left over from the stickers (thick or thin), use microfiber soaked in WD or goo gone to get it off. Works like a charm, and it's easier (and less harmful) than digging in with a credit card.
    May 2007
    Southern NH
    Quote Originally Posted by imkindafkedup View Post
    Muhammad Ali.
    Nov 2004
    Boston, MA
    Well Im going to try a heat gun, Ive been meaning to get one for adding blades and ends to hockey sticks anyway.
    Im also going to try the googone. Ill post pics.
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
  1. For Sale - Parts & Tools | WTT: R6 street bodywork for race bodywork
    By Mr. Kurtz in forum For Sale
    Last Post: 05-04-14, 11:18 AM
  2. decals
    Last Post: 04-15-09, 03:22 PM
  3. removing throttle?
    By akira700 in forum Bike Maintenance
    Last Post: 09-23-08, 09:25 AM
  4. decals?
    By mikeb in forum General Bike Related
    Last Post: 08-22-06, 11:08 AM
