I just got these --- thought i'd pass them on.
> > Just in case you haven't heard of these. One thing that is not
> > mentioned is too never put more in your gas tank after the
> automatic
> > shutoff (Do not pack it in).
> > Tricks to get your money's worth
> > TIPS ON PUMPING GAS--GOOD INFO
> > I don't know what you guys are paying for gasoline....Here in
> > California we are also paying higher, up to $3.50 per gallon.
> But
> > my line of work is in petroleum for about 31 years now, so here
> are
> > some tricks to get more of your money's worth for every gallon.
> > Here at the Kinder Morgan Pipeline where I work in San Jose , CA
> we
> > deliver about 4 million gallons in a 24-hour period thru the
> > pipeline. One day is diesel the next day is jet fuel, and
> gasoline,
> > regular and premium grades. We have 34-storage tanks here with
> a
> > total capacity of 16,800,000 gallons.
> > Only buy or fill up your car or truck in the early morning when
> the
> > ground temperature is still cold. Remember that all service
> stations
> > have their storage tanks buried below ground. The colder the
> ground
> > the more dense the gasoline, when it gets warmer gasoline
> expands,
> > so buying in the afternoon or in the evening....your gallon is
> not
> > exactly a gallon. In the petroleum business, the specific
> gravity
> > and the temperature of the gasoline, diesel and jet fuel,
> ethanol
> > and other petroleum products plays an important role. A
> 1-degree
> > rise in temperature is a big deal for this business. But the
> service
> > stations do not have temperature compensation at the pumps.
> > When you're filling up do not squeeze the trigger of the nozzle
> to a
> > fast mode. If you look you will see that the trigger has three
> (3)
> > stages: low, middle, and high. In slow mode you should be
> pumping on
> > low speed, thereby minimizing the vapors that are created while
> you
> > are pumping. All hoses at the pump have a vapor return. If you
> are
> > pumping on the fast rate, some of the liquid that goes to your
> tank
> > becomes vapor. Those vapors are being sucked up and back into
> the
> > underground storage tank so you're getting less worth for your
> > money.
> > One of the most important tips is to fill up when your gas tank
> is
> > HALF FULL or HALF EMPTY. The reason for this is, the more gas
> you
> > have in your tank the less air occupying its empty space.
> Gasoline
> > evaporates faster than you can imagine. Ga soline storage tanks
> have
> > an internal floating roof. This roof serves as zero clearance
> > between the gas and the atmosphere, so it minimizes the
> evaporation.
> > Unlike service stations, here where I work, every truck that we
> load
> > is temperature compensated so that every gallon is actually the
> > exact amount.
> > Another reminder, if there is a gasoline truck pumping into the
> > storage tanks when you stop to buy gas, DO NOT fill up--most
> likely
> > the gasoline is being stirred up as the gas is being delivered,
> and
> > you might pick up some of the dirt that normally settles on the
> > bottom.
> > Hope this will help you get the most value for your money.
