Results 26 to 50 of 53
Sport or Sport-touring tires?
    Re: Sport or Sport-touring tires?
    We've discussed this in the past. Reigning theory is that it has something to do with the crown in the roads. Whutever. I got my fun out of 'em. That I know.
    Nov 2009
    Bristol County
    Since this seems like a fitting place (since quite a few of you guys like the PR3/4's), do you notice any wandering or instability with all of the small sipes? Do they limit road feel? Not that these are tires you're going to be railing tons of twisties with, but I've just wondered. I'm on my third(?) set of Angel ST's, the predecessor to the new GT's, and feel they have been great.
    I'm just testing the waters a bit since I will probably need a new full set early next spring and it will be between the PR and Angel again.
    I haven't noticed any significant wondering with the PR4's. The front doesn't feedback as much as the Angel GT's front did, for better or for worse. They do produce a noticeable road noise, which I think is a result of the unusual siping. But I only hear it at non-highway speeds with the clutch in.
    nedirtriders.com
    Never noticed any instability. You absolutely can rail twisties with them and you can even do it loaded.
    The tires sing out and talk to you but they hold the line you want all day without complaint.
    I just did WV and VA mountains, blue ridge pkwy, tail of the dragon, and random mountain roads around asheville with a two up, overloaded tiger 1050 on PR4s and it was awesome. They did a great job and I was pushing pretty hard (as hard as I dared with a passenger, anyway). So they are pretty capable.
    2022 Husqvarna fe501s
    Concord NH
    I tend to like to get my money's worth from my tires.
    Yeah, you got your money out of that one.
    Thanks for the feedback.
    I've never had a complaint on the Angels and they grip more than I need them to for street riding (sometimes spirited and/or 2-up), but it's always good to consider your options.
    I've still got some more time to think on it, but we'll see. The PR3's look to be just about the same price for a set as the Angel GT's, and the PR4's are just a few bucks more.
    Nov 2009
    Bristol County
    I read user reviews obsessively before buying my latest set. And while I lack the experience some of the other guys here have, between my own experience and the reviews across the PR3, PR4, Angel ST or GT, you really can't go wrong. There are slight variations among them, but they'll all do fine.
    nedirtriders.com
    Raymond NH
    It's because left corners are roughly 30 feet longer than right corners because we drive on the right side of the road.
    Lifer Punjistick's Avatar
    Norwell, MA
    Wirelessly posted (HTC One X+)
    I just ordered a set of the PR4s. I figure even if I replace them before they run out of mileage (start to crack/rot/etc), the added traction in the wet is worth having. They just seem like a better fit for the type of riding I'm doing.
    I just checked. My rear is looking like this again. Fortunately I have another PR2 on the shelf ready to go.
    Lifer Stromper's Avatar
    Eastern Ct
    If you don't routinely scrape parts then T30's are fine
    My SET was $222 delivered from Revzilla... small size
    The calculus of hate
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    Bridgestone's September Battlax Tire Rebate - When you purchase a set (one Front and one Rear) of select Bridgestone Battlax tires (Hypersport S20 or T30) between September 1st and 30th, 2014, you may be eligible to receive up to $40 on a Bridgestone Visa® Prepaid Card by online rebate.*
    Eastern Ct
    Right turns on a 2 lane the drainage crown act like banking virtual zero lean relative to the pavement
    Left turns are the opposite with great lateral force friction force the crown acting as negative banking
    crown of road theory is bunk, roads are crowned 2-3%, 5% max, this would account for the left bias to be maybe 1mm left of center
    the reason is, we drive/ride on the right hand side of the road, left turns are on the outside radius and there for longer and right hand turns are the inside radius and therefore shorter, we spend more time leaned over in left hand turns, simple as that
    very detailed description of what is going on here http://www.rattlebars.com/tirewear/index.html
    my super moto ate a PR2 rear in about 6k miles which was about the same as the 2CT i had on previous. i replaced the rear with a PR4 and ive got probably between 4-5k on it this year and it still seems good. the PR2 on the front is holding up pretty good as well
    I've used Conti Road Attack II's and found them excellent on road, track and rain.
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    And I thought I ham fisted my way through tires.
    Pilot Road 2s on a SV1000 made it just over 13K miles of me commuting, weekend rips, and general knee dragging asshattery. (they also had about 2-3K on them from the PO)
    Pilot road 3s and an VFR1200 Made it about 8K before the rear ate a nail. This is a 600 lb 170 hp pig. The front lasted almost 10K but some some reason that bike CHEWS front tires.
    wish someone would find me an 18" rear touring tire in a 140 or 150 width
    http://www.avonmoto.com/products/street-bias/roadrider
    Getting about 20K on my rear. and just as fun on the track.
    I prefer the feel of the Pirelli (Angel ST/GT) over the PR, although I haven't ridden the PR4 yet. You get a bit less life, but the Angels warm up nice and quick and don't get slimy when super hot. I also love the Metzler Z8's on my ZRX which I opted for as it's designed for heavier bikes. All have been phenomenal and the Metzlers only take a bit of fiddling to adjust to their higher pressure settings. My only experience on-track on some PR3's scared me away from them a bit as they got super slimy and didn't inspire much confidence but YMMV. Find a tire you like, know the pressures to make it happy and enjoy.
    CCS/LRRS #83
    20k?!?!?
    quit lyin' !!
    no solid responses from the fzrarchives, and on the bikebandit reviews, I've seen people say 3k/5k/10k/15k miles...with no info about the kind of bike, or where they got the tire from (some people have complained of tire sidewall cracking...I presume they bought these online and dated?)
    I'd be putting it on a '95 FZR600; which is 90% commuting, 8% canyon, and 2% whoolies...so far the shinko podium 006 (an inexpensive sport? tire) is on the wear bars in under 6,000 miles...and roughly the same on a BT014 (which is softer and considered sticky)...the AM26 is only $99 + FS from motorcycle-superstore.com (which is how much a podium costs anyhow), so if it costs the same, but lasts twice as long (hopefully 12k miles??) then I'd be happy!
    Sorry. 18242 and ticking away
  21. #46
    hawk??
    I'd be stoked to get 18k...but even would be happy with 12k
    ok, you got me Gino...in4one
  22. #47
    Lifer golden chicken's Avatar
    Attleboro, MA
    I got over 18k out of a set of Michelin Pilot Road 2s, and about 13k out of a set of Pilot Power 3s.
  23. #48
    You two are incredible. 10k and I'm happy. I think I'm averaging 8-9k out of a rear. Probably double that for a front.
    yes the Hawk, all commuting duty on this rear
    looking to get another 2K out of it.
  25. #50
    this thread is now useful with pictures
    you rock
    I'm in
    bike has over 51k on the clock (actual ~60k because of speedo gear breaking at some point in time), so I'm guessing this might be the last rear tire I ever buy for the fizzer
    can you still hammer canyons with it?
  1. Wanted - Motorcycles | Wanted for my sanity (seriously) a sport or sport touring bike
    By eforer in forum Wanted
    Last Post: 05-27-16, 09:13 PM
  2. Sport Touring - Best Bike?
    By bostongixxer in forum General Bike Related
    Last Post: 04-16-14, 06:48 PM
  3. Need new sport/touring tires
    By SRTie4k in forum Bike Maintenance
    Last Post: 07-08-09, 09:53 AM
  4. Got my RC51 Sport Touring edition set up
    Last Post: 07-22-07, 12:04 AM
  5. Ride a Sport Bike - Sport Touring ? ( Worcester area )
    By urudufusmisrael in forum Rides & Events
    Last Post: 04-10-06, 09:29 PM
