Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 200
I present to you, SS LandWhale
  1. #101
    Re: I present to you, SS LandWhale
    Maybe in the near future I'll take you up on that offer via a voyage on the LandWhale.
    Got the shim stock cut and wrapped around the bearing, then tapped in (some resistance, not a ton, not loose) to the hub with Loctite Green. Dried overnight, we'll see how it is today. Used .0015". Have .002, .003 etc if it's still too loose. Got a nice assortment of 6"x12" sheets of stainless on Amazon for $26.
    Got the steering head bearings in, forks are mounted, just trying to get the self cancelling turn signal sensor hooked up. Quite the bear. It threads through the steering stem... and the connectors is halfway up the tube.
    Depends on how today goes with shooting internet access from my roof to my neighbor 1/4 mile away without visual LoS, I might be able to get her all buttoned up and ready to go.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    She's out of dry dock and back out to sea!
    Rock solid handling (well, for the heft of such a rotund girl).
    No head shake anymore. Yay for no more tank slappers into oncoming traffic!
    Shifts easier (likely from less drag on the drive train from the way over-tightening of the rear axle to make up for the bearing slop).
    Stops easier (new fluid all around).
    -Clayton
    2006 Suzuki SV650
    Do you yell "Ahoy, mate. Land Ho!" every time you pull into your driveway?
    It could use a fog horn, that's for sure!
    -Clayton
    2006 Suzuki SV650
    New rear bearing is trashed.
    Guess I'll have to do the GL1500 rear end swap over the winter. Oh well.
    -Clayton
    2006 Suzuki SV650
    That didn't take long.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
  7. #107
    Nope.
    Ah well. Anyone want a cheap 'wing? Be about $160 in used Ebay parts to get it done right and be a solid rider. Everything else is done.
    -Clayton
    2006 Suzuki SV650
    Nope.
    message me.
  9. #109
    Come on bro!!!
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke: ** 2017 KTM 690 Enduro R**
  10. #110
  11. #111
    How do you mean? the bearing itself failed? Or it came loose in the wheel boss again?
    Not sure yet, wheel has a ton of play in it. Haven't opened it up, but I'm assuming the bearing came loose in the hub again.
    -Clayton
    2006 Suzuki SV650
    Stock pegs on the way. No more floorboards or heel/toe!
    -Clayton
    2006 Suzuki SV650
    Awww. Heel toe is kinda fun.
    Almost head-on'd a left turning truck two days ago. Gave all the front break I could while trying like hell to lift my foot up and find the brake pedal/heel rest. Linked brakes + floorboards = no fuckin way.
    -Clayton
    2006 Suzuki SV650
    The brakes are heel toe?
    I rode a giro on a benelli that had heel to shift... on the right! That made for some excitinh errors.
    floorboards
    that's some funny shit right there you sure this thing has 2 wheels? can't quite tell from the pics.
    I think he's saying that floor boards make it harder to find the rear brake and also make it harder to modulate.
    Hypertarded
    I think he means:
    Thought the front brake was bad, and the rear was good, until I read the manual. Front brake lever hits one front caliper, rear pedal hits the rear and the other front caliper. Linked braking. Weird dude, weird.
    Bingo. Just front gives not much for braking. Rear does plenty, but you have to lift your foot up off the floorboard about 5”, find the little “braking peg” with your heel, and then you’ll find the pedal with your toes. Or you’ll push like hell on the fucking cylinder that sits right in front of the pedal. For such a huge bike there is not a lot of foot room between the front brake pedal and the cylinder head so you end up pressing down on the cylinder head instead of the pedal sometimes by mistake. As it turns out, trying to brake using the cylinder head does not result in adequate braking.
    -Clayton
    2006 Suzuki SV650
    Same thing happened with my dad's r100rt beemer. Head was kind of in the way.
    Lifer 01xj's Avatar
    CT
    The stopping power of the rear brake on my 84 after new fluid and pads was seriously impressive. I know it's a linked system but having that much stopping power come from a bike weighing so much was a really bizzare feeling the first time.
    Lifer loudbeard's Avatar
    This is just me musing, but is it possible to retrofit for a traditional brake setup? New front master and some plumbing?
  25. #125
    Easier solution is to go back to stock footpegs/pedal setup. Parts are on the way!
    -Clayton
    2006 Suzuki SV650
