Results 1 to 7 of 7
SS Rear Brake Line... is it worth it?
    Lifer LuvDog's Avatar
    Ashland, MA
    I finally got around to putting on my new rear sets on my bike, and I'm going to replace the banjo bolt with a pressure switch bolt for the rear brake light.
    Since I'm going to flush/fill/bleed the rear brake anyway... should I upgrade the line to SS? or is it not worth it for the rear brake?
    The fronts are still stock.
    2003 ZX7R
    1995 916
    Lifer GMAN226's Avatar
    Coventry RI
    I wouldn't, I have had rubber on all of my race bikes. The front upgrade is a huge difference. Do the front.
    G-man
    Gerard
    Posting Freak SWEET_Z's Avatar
    Jul 2002
    Smallbany, NY
    Yeh, just do the fronts. The only reason I can see doing the rear line in SS is for the bling factor.
    Apr 2004
    boston burbs....
    I'd replace just beacuse 2 year from now you'l have to replace it anyway rubber detioriorates...SS doesnt.
    hmmmm......
    Atlanta, GA
    I asked the same question to an accomplished racer and they told me that not only do they keep rubber on the back, they introduce small volume a bit of air (sponge) into the rear system, so that you basically can stand on the rear brake without locking the rear wheel as easily.
    Andrew
    03 Suzuki SV650
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    the difference SS lines makes under hard breaking in the front is amazing, and I can't imagine having them on the rear ... I would surely lock it up every time
    Dec 2003
    Ma
    Guess it depends on your feel. Some racers put in air bubbles, I would think this would be an inconsistant feel. Some shave out part of the brake pad. I put a braided line on my rear, bleed all the way out. Only time I use it I'm on the gas anyways and it gives a great feel, lets me scrub off some speed if I need to when I'm close in a corner at heavey lean.
  1. SS Brake Line install
    By Garandman in forum Bike Maintenance
    Last Post: 09-10-18, 01:53 PM
  2. Brake Line Setups
    Last Post: 05-19-15, 04:10 PM
  3. Brake line question.....
    By 13 in forum Pit Area
    Last Post: 04-12-07, 04:57 PM
  4. brake line install
    By ri-gixxer in forum Bike Maintenance
    Last Post: 03-26-07, 03:04 PM
  5. Stainless Steel Brake Line
    By craig in forum Bike Maintenance
    Last Post: 08-28-04, 12:01 PM
